8D723Z06SN-LC
8D723Z06SN-LC
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D 6C 6#8 SKT J/N
8D723Z06SN-LC 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal A 55.6±0.3 B 39.67+0.1/-0.15 R 32.5Max S 52.4±0.4 W 3+0.9/-0.1 VV THREAD M34x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Aluminium -Shell Plating : Black Zinc Nickel -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D723Z06SNL -Delivered without Souriau contacts -Temperature Range -Salt Spray : -65°C to +175°C : 500 hours A 01-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D SHELL TYPE : Jam nut Receptacle CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 23 PLATING : Z = Jurisdiction & Control List Not Listed 7 - 23 Z 06 S N SCALE L Delivered W/O Contacts ORIENTATION : N NA SOURIAU Latest modification - by Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Black Zinc Nickel CONTACT LAYOUT : 23-06 FORMAT A3 MOD N° CUSTOMER DRAWING Date: SOURIAU DRG N° 8D723Z06SNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout Panel cutout Dim B ØC Nominal 40.26+0/-0.25 41.53+0.25/-0 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D723Z06SNL A 01-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Aluminium Receptacle 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D723Z06SNL-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D723Z06SN-LC 价格&库存
很抱歉,暂时无法提供与“8D723Z06SN-LC”相匹配的价格&库存,您可以联系我们找货
8D723Z06SN-LC
