CRER10PLY
CRER10PLY
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    针位圆形连接器 插件壳 面板安装 防紫外线
CRER10PLY 数据手册
A B C D E F G H N1 8 1 2 3 N2 4 (14/0.551) N3 5 N4 C :critical dimension M :major dimension 8 (22/0.866) Sur plats / on flats (16/0.630) Sur plats / on flats 6 (23/0.905) 26/1.024 Max. 7 7 ( 24/0.945) 6 6 5 2.5/0.098 Max. Multicontacts insert 10/0.394 Max. Coaxial insert (4/0.157) MARQUAGE/MARKING (37/1.456) Bande témoin d'accouplement Mating witness marking **** JUPITER FR REFERENCE COMMERCIALE PART NUMBER 4 N2 : MONTAGE SANS GRAISSE MOUNTING WITHOUT GREASE N3 : MONTAGE AVEC GRAISSE MOUNTING WITH GREASE 6 ISOLANT / INSERT 5 JOINT TORIQUE ISOLANT / O'RING INSERT : ISOLANT HORS FOURNITURE INSERT NOT SUPPLIED 4 JOINT TORIQUE PANNEAU / O'RING PANEL 3 ECROU DE FIXATION / JAM NUT 2 BAGUE DE RETENUE / RETAINING RING 1 EMBASE RER / RECEPTACLE RER N4 CRER10PLY CUT +0.004 16,2+0,1 0 /0.637-0 Cassage d'angle 0.2 Maxi Edge breaking 0.008in Max. A-A REP 3 0.1 K K +0.004 /0.716-0 18,2+0,1 0 A Iss 05/09/16 2 Ra 1.2 1 G _ _ ORAIN D Nat. Designed by Checked by DIFF MOD N $ PROTECTION/PLATING -- -- -- -- -- CODE -- DIMENSIONS ARE DEFINED BEFORE PLATING General machining Voir Référence Commerciale / See Part Number SOURIAU 3, RUE DU VALLON -- ZAC N $ 2 94440 MAROLLES-EN-BRIE Surface texture This document is the property of SOURIAU it must not be reproduced or communicated without permission. C PL54 SERIE PL - TAILLE 10 Material Reference 2 PROJECT EMBASE RER / RECEPTACLE RER (FRANCE) TEL. 33 (0)1 45 10 78 00 Geometrical Tolerances: NF EN ISO 1101 E A C MEFFRE TREATMENT SCALE 2/1 F 3 MATERIAL -- TITLE 9Maxi/0.354Max. 4Mini/0.157Min. SCALE 4/1 DESIGNATION MODIFICATIONS Date Scale 4/1 DECOUPE DU PANNEAU PANEL CUT OUT 4 Initial drawing Generales tolerances ISO 2768 H 5 RER10PLY SEMAINE/WEEK ANNEE/YEAR N1 : SERRAGE SUR PANNEAU COUPLE 3.5 N.m TIGHTENING ON PANEL TORQUE 3.5 N.m 25Mini pour Ra1.2µm Maxi A.3; Validé CountryJurisdiction & Control List FR NOT LISTED FORMAT A2 B SOURIAU DRG N $ 542E0030A8C Iss A A SHEET 1/1 1
CRER10PLY 价格&库存
很抱歉,暂时无法提供与“CRER10PLY”相匹配的价格&库存,您可以联系我们找货
