电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
CPE10PLSAY
CPE10PLSAY
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    针位圆形连接器 插件壳 自由悬挂 防紫外线
CPE10PLSAY 数据手册
A B C D E F G H C :critical dimension M :major dimension 8 8 1 2 N2 N1 3 (21/0.827) (b) Sur plats / on flats 4 7 (ACME 22x2.54) ( 17,8/0.669) 16,5/0.649 Maxi Coaxial insert 23/0.906 Maxi Multicontacts insert 26/1.024 Maxi 7 18,75/0.708 Maxi B.2; Développement CountryJurisdiction & Control List FR NOT LISTED 6 6 (20/0.787) (11/0.433) 5 5 Bande témoin d'accouplement Mating witness marking (25,3/0.984) (b) 61,3/2.401 Maxi MARQUAGE/MARKING **** JUPITER FR PCE10PLY 4 4 SEMAINE/WEEK ANNEE/YEAR REFERENCE COMMERCIALE PART NUMBER N1 : MONTAGE AVEC GRAISSE MOUNTING WITH GREASE CPE10PLSAY N2 : ISOLANT HORS FOURNITURE INSERT NOT SUPPLIED 3 3 B A 2 4 ISOLANT / INSERT 3 JOINT TORIQUE ISOLANT / O'RING INSERT 2 BAGUE DE RETENUE / RETAINING RING 1 PROLONGATEUR PCE / IN-LINE RECEPTACLE REP Iss DESIGNATION 23/04/18 28/02/18 Modification of flats + add of retaining Initial drawing -- -- -- -- -- CODE 1 D -- DIMENSIONS ARE DEFINED BEFORE PLATING Generales tolerances ISO 2768 General machining Voir Référence Commerciale / See Part Number SOURIAU 3, RUE DU VALLON -- ZAC N $ 2 94440 MAROLLES-EN-BRIE Surface texture This document is the property of SOURIAU it must not be reproduced or communicated without permission. C PL54 SERIE PL - TAILLE 10 Material Reference 2 PROJECT PROLONGATEUR PCE SAY/ IN-LINE RECEPTACLE SAY TYPE (FRANCE) TEL. 33 (0)1 45 10 78 00 Geometrical Tolerances: NF EN ISO 1101 E MOD N $ PROTECTION/PLATING Scale 4/1 F Designed by Checked by DIFF TREATMENT SCALE 2/1 G Nat. DIFF MATERIAL -- TITLE H _ _ S.YakoubiMEFFRE A C MODIFICATIONS Date S.YakoubiMEFFRE FORMAT A2 B SOURIAU DRG N $ 542P0030A8C Iss B A SHEET 1/1 1
CPE10PLSAY 价格&库存
很抱歉,暂时无法提供与“CPE10PLSAY”相匹配的价格&库存,您可以联系我们找货
