BERC14PLY
BERC14PLY
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    连接器 帽盖(盖),密封 14 米色
BERC14PLY 数据手册
A B C D E F G H C :critical dimension M :major dimension 37.5/1.476 Max. 8 8 1 2 N1 3 4 7 7 SCALE 2/1 6 34/1.338 Max. A.2; Développement CountryJurisdiction & Control List FR NOT LISTED 6 5 5 MARQUAGE/MARKING **** JUPITER FR BER14PLY SEMAINE/WEEK ANNEE/YEAR COSSE DE FIXATION / FIXING RING REFERENCE COMMERCIALE PART NUMBER 6 MANCHON / SLEEVE 5 CORDELETTE / FIXING ROPE BER14PLY 4 JOINT TORIQUE ACCOUPLEMENT / O'RING COUPLING (Sans cordelette / Without fixing rope) 3 DOUILLE D'ACCOUPLEMENT / COUPLING RING BERC14PLY 2 CIRCLIPS / RETAINING CLIP 1 BOUCHON D'EMBASE / RECEPTACLE CAP 4 7 (Avec cordelette / With fixing rope) 3 N2 REP 5 A Iss 20/09/16 DESIGNATION Initial Drawing 49 .4 /9 40 ) 2 6 7 ( n4,2/0.165) 1 H -- -- -- -- CODE E D __ DIMENSIONS ARE DEFINED BEFORE PLATING Voir Référence Commerciale / See Part Number SOURIAU 3, RUE DU VALLON -- ZAC N $ 2 94440 MAROLLES-EN-BRIE Surface texture This document is the property of SOURIAU it must not be reproduced or communicated without permission. C PL54 SERIE PL - TAILLE 14 General machining 2 PROJECT BOUCHON D'EMBASE (BER) / RECEPTACLE CAP (BER) (FRANCE) TEL. 33 (0)1 45 10 78 00 Geometrical Tolerances: NF EN ISO 1101 F MOD N $ -- Scale 4/1 G Designed by Checked by PROTECTION/PLATING Generales tolerances ISO 2768 : UNIQUEMENT POUR LA REFERENCE BERC14PLY ONLY FOR PART NUMBER BERC14PLY Nat. DIFF TREATMENT Material Reference N2 A C MEFFRE MATERIAL __ TITLE N1 : MONTAGE AVEC GRAISSE MOUNTING WITH GREASE 3 _ _ ORAIN MODIFICATIONS Date (2 N2 N2 4 FORMAT A2 B SOURIAU DRG N $ 543B0030B9C Iss A A SHEET 1/1 1
BERC14PLY 价格&库存
很抱歉,暂时无法提供与“BERC14PLY”相匹配的价格&库存,您可以联系我们找货
