电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
CRER14PLY
CRER14PLY
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    针位圆形连接器 插件壳 面板安装 防紫外线
CRER14PLY 数据手册
4 5 (14/0.551) 6 A 3 N4 B 2 N3 C D E F G H 1 N2 N1 (30/1,18) Sur plats / On flats C :critical dimension M :major dimension (23/0,905) Sur plats / On flats (23/0.905) 8 8 34/1.338 Max. 7 7 ( 33/1,299) 6 6 5 N1 : SERRAGE SUR PANNEAU COUPLE 5.5 N.m TIGHTENING ON PANEL TORQUE 5.5 N.m N2 N3 4 N4 2.5/0.098 Max. Multicontacts insert (5/0.196) (37/1,456) **** JUPITER Bande témoin d'accouplement Mating witness marking SEMAINE/WEEK : MONTAGE SANS GRAISSE MOUNTING WITHOUT GREASE +0,1 0 23,2 +0.004 -0 /0.913 FR RER14PLY REFERENCE COMMERCIALE PART NUMBER ANNEE/YEAR : MONTAGE AVEC GRAISSE MOUNTING WITH GREASE : ISOLANT HORS FOURNITURE INSERT NOT SUPPLIED 5 MARQUAGE/MARKING CRER14PLY CUT Cassage d'angle 0.2 Maxi Breaking edge 0.008in Max. A-A 0.1 K 4 6 ISOLANT / INSERT 5 JOINT TORIQUE ISOLANT / O'RING INSERT 4 JOINT TORIQUE PANNEAU / O'RING PANEL 3 ECROU DE FIXATION / JAM NUT 2 BAGUE DE RETENUE / RETAINING RING 1 EMBASE RER / RECEPTACLE RER REP DESIGNATION 3 3 K 34Mini pour Ra1.2µm Maxi A.3; Validé CountryJurisdiction & Control List FR NOT LISTED +0.004 25,2+0,1 0 /0.992-0 A Iss 05/09/16 2 1.2 1 H G E D MOD N $ -- -- -- -- -- CODE -- DIMENSIONS ARE DEFINED BEFORE PLATING TITLE Voir Référence Commerciale / See Part Number SOURIAU 3, RUE DU VALLON -- ZAC N $ 2 94440 MAROLLES-EN-BRIE Surface texture This document is the property of SOURIAU it must not be reproduced or communicated without permission. C PL54 SERIE PL - TAILLE 14 General machining 2 PROJECT EMBASE RER / RECEPTACLE RER (FRANCE) TEL. 33 (0)1 45 10 78 00 Geometrical Tolerances: NF EN ISO 1101 F Designed by Checked by PROTECTION/PLATING Scale 4/1 SCALE 4/1 Nat. DIFF TREATMENT Generales tolerances ISO 2768 9Maxi/0.354Max. 4Mini/0.157Min. A C MEFFRE MATERIAL -- Material Reference DECOUPE DU PANNEAU PANEL CUT OUT _ _ ORAIN MODIFICATIONS Date Ra SCALE 2/1 Initial drawing FORMAT A2 B SOURIAU DRG N $ 543E0030A8C Iss A A SHEET 1/1 1
CRER14PLY 价格&库存
很抱歉,暂时无法提供与“CRER14PLY”相匹配的价格&库存,您可以联系我们找货
