4
5
6
A
3
N1
B
2
C
D
E
F
G
H
1
N1
N2
7
C
:critical dimension
M
:major dimension
8
8
7
( n24/0.944)
7
25/0.984 Max.
23 Max.
Multicontacts insert
( n25,75/0.984)
A.2; Validé
CountryJurisdiction
& Control List
FR
NOT LISTED
6
6
(20/0.787)
3.5/0.118 Min.
MARQUAGE/MARKING
5
52.5/2.047 Max.
JUPITER
FR
5
FED14PLY
SEMAINE/WEEK
ANNEE/YEAR
4
N1 : MONTAGE AVEC GRAISSE
MOUNTING WITH GREASE
REFERENCE COMMERCIALE
PART NUMBER
N2
CFE14PLY
3
7
ISOLANT / INSERT
6
JOINT TORIQUE ISOLANT / O'RING INSERT
5
JOINT TORIQUE ACCOUPLEMENT / O'RING COUPLING
4
BAGUE DE RETENUE / RETAINING RING
3
DOUILLE D'ACCOUPLEMENT / COUPLING RING
2
CIRCLIPS / RETAINING CLIP
A
1
FICHE DROITE FED / STRAIGHT PLUG FED
Iss
REP
: ISOLANT HORS FOURNITURE
INSERT NOT SUPPLIED
3
DESIGNATION
05/09/16
Initial drawing
_ _ ORAIN
2
CODE
DIMENSIONS ARE DEFINED BEFORE PLATING
Voir Référence Commerciale / See Part Number
SOURIAU
3, RUE DU VALLON
1
Surface texture
This document is the property of
SOURIAU
it must not be reproduced or
communicated without permission.
ZAC N $ 2
94440 MAROLLES-EN-BRIE
(FRANCE)
TEL. 33 (0)1 45 10 78 00
Geometrical Tolerances: NF EN ISO 1101
C
PL54
SERIE PL - TAILLE 14
General machining
2
PROJECT
FICHE DROITE FED SA / STRAIGHT PLUG FED SA TYPE
Generales tolerances
ISO 2768
D
MOD N $
PROTECTION/PLATING
Scale
4/1
E
Designed by Checked by
DIFF
TREATMENT
SCALE 2/1
F
Nat.
MEFFRE
MATERIAL --
Material Reference
G
A C
MODIFICATIONS
Date
TITLE
H
4
FORMAT
A2
B
SOURIAU DRG N $
543F0130A8C
Iss
A
A
SHEET
1/1
1
很抱歉,暂时无法提供与“CFE14PLSAY”相匹配的价格&库存,您可以联系我们找货
