电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
CPE14PLSAY
CPE14PLSAY
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    针位圆形连接器 插件壳 自由悬挂 防紫外线
CPE14PLSAY 数据手册
A B C D E F G H C :critical dimension M :major dimension 8 8 1 2 N1 3 N2 (29/1,102)(b) Sur plats / On flats 4 (ACME 30x2.54) ( 24/0.944) 25/0.984 Maxi 7 34/1.338 Maxi 7 23/0.906 Maxi Multicontacts insert ( 25,75/0.984) B.2; Développement CountryJurisdiction & Control List FR NOT LISTED 6 6 (20/0.787) (11/0.433) MARQUAGE/MARKING Bande témoin d'accouplement Mating witness marking 5 (25,3/0984) (b) **** JUPITER FR PCE14PLY 5 SEMAINE/WEEK ANNEE/YEAR 61,3/2.401 Maxi N1 : MONTAGE AVEC GRAISSE MOUNTING WITH GREASE N2 4 REFERENCE COMMERCIALE PART NUMBER : ISOLANT HORS FOURNITURE INSERT NOT SUPPLIED 4 CPE14PLY 3 3 2 4 ISOLANT / INSERT 3 JOINT TORIQUE ISOLANT / O'RING INSERT 2 BAGUE DE RETENUE / RETAINING RING 1 PROLONGATEUR PCE / IN-LINE RECEPTACLE REP DESIGNATION SCALE 2/1 B A 25/04/18 Iss Date 28/02/18 Modification of flats + add of retaining Initial drawing 1 E D Designed by Checked by MOD N $ TREATMENT PROTECTION/PLATING -- -- -- -- -- CODE -- DIMENSIONS ARE DEFINED BEFORE PLATING TITLE General machining Voir Référence Commerciale / See Part Number SOURIAU 3, RUE DU VALLON -- ZAC N $ 2 94440 MAROLLES-EN-BRIE Surface texture This document is the property of SOURIAU it must not be reproduced or communicated without permission. C PL54 SERIE PL - TAILLE 14 Material Reference 2 PROJECT PROLONGATEUR PCE SA / IN-LINE RECEPTACLE SA TYPE (FRANCE) TEL. 33 (0)1 45 10 78 00 Geometrical Tolerances: NF EN ISO 1101 F Nat. DIFF DIFF MATERIAL -- Scale 3/1 G A C MODIFICATIONS Generales tolerances ISO 2768 H SYakoubi MEFFRE _ _ SYakoubi MEFFRE FORMAT A2 B SOURIAU DRG N $ 543P0030A8C Iss B A SHEET 1/1 1
CPE14PLSAY 价格&库存
很抱歉,暂时无法提供与“CPE14PLSAY”相匹配的价格&库存,您可以联系我们找货
