UTGX01419S
UTGX01419S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT HSG FMALE 19POS PNL MT
UTGX01419S 数据手册
B A (Without marking) 7 UTGX0-----P INSERT Solder cup PERFORMANCE CHARACTERISTICS : C (x4) 0.6 0.05 for contact #20 1 0.05 for contact #16 K2 K1 INSERT INSERT INSERT Solder cup L Lenght receptacle D 0.6 0.05 for contact #20 1 0.05 for contact #16 1- Contact to be ordered separately for version UTGX0----- : refer to corresponding catalogue. 2- Insert arrangement refer to: UTO-CONTACT-L-C02 (Female insulator) UTO-DHP-003-C01 (Female insulator #20) UTO-DHP-002-C01 (Female insulator #16) UTO-CONTACT-L-C01 (Male insulator) UTO-DHP-003-C01 (Male insulator #20) UTO-DHP-001-C01 (Male insulator #16) C144-UTS1-A (HiSeal Version) THREAD -IP68 1 bar during 1 week: immersion under 10 m of water. (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement(DIN 40050) PANEL CUT OUT DEFINITION 10 12 14 0.1 P 17.9 3.2 Q R S 15.2 18.3 18.3 22.3 18.3 20.6 20.6 25.1 21.5 23.0 23.0 T 2.8 S FRONT mounting REAR mounting 0 receptacle SHELL SIZE 10 12 14 TYPE OF LAYOUT Standard layout (No digit) D : HISEAL Dispolder contacts E : HISEAL Handsolder contacts ORIENTATIONS Normal (no digit) W,X,Y,Z INSERT ARRANGEMENT See NOTA 2 TYPE OF CONTACTS P: MALE S: FEMALE 2 14/02/2020 ISS 0.4 A 0.2 B 1 10 23.8 18.26 12 26.2 20.62 14 28.6 23.01 0.1 C 0.2 0.2 D E 0.2 F MAX G H 15.2 3.2 11.35 2.3 19.15 22.31 19.5 12.1 J1 15.8 / 17.7 * J2 18.1/ 20 * MAX K1 15.8/ 17.7 * L K2 18.1/ 20 * 32.3 M 11.5 N 11.5 THREAD CLASS 2A 30% (g.) TITLE MASS 9/16-24 UNEF 6 11/16-24 UNEF 10 13/16-20 UNEF 13 Scale 3/2 G F E D * P/N for example -Update drawing -- FORMAT C A2 3 25253J Latest modification - by: J.FEURPRIER PE.LANDAIS Date:10/05/2019 CUSTOMER DRAWING MOD N 2 SQUARE FLANGE RECEPTACLE T0 - SIZE 10 12 14 - Standard and Hiseal version UTGX CONNECTOR Dimensions in mm General linear Tolerances: 0.2 www.souriau.com * -1mm FOR LAYOUT 12D14 H DATE Designed by: MIN / MAX Square flange SHELL TYPE B SHELL SIZE UTGX 0 14 D 19 P - BASIC SERIES MAX 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) P/N : CROSS REF TABLE PANEL THICKNESS 0.15 CountryJurisdiction& Control List FR NOT LISTED T T R 3 SHELL SIZE REAR FRONT mounting mounting 0.1 Q 5 E 3 LOCKING PINS RING SCALE 2/1 P (x4) PANEL CUT OUT DEFINITION 4 SEALING CONDITIONS 5 Sealing in MATED conditions withSealing in MATED conditions with COUNTERPARTand UNMATED COUNTERPART: conditions: -IP68 1 bar during 1 week: immersion under 10 m of water. (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement(DIN 40050) 6 NOTA: F 6 UTGX0-----S H 7 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M under 500V Corrosion salt spray: 500 hours Durability: 500 matings and unmatings Sealing conditions: SEE TABLE SHELL RECEPTACLE N A - SHELL : PA UL94 V0, UL746C F1 Black color 8 - 3 LOCKING PINS RING : Nickel plated Brass + stainless steel. - INSERT (UTGX0-----) : PA UL94 V0, UL746C F1 Black color - INSERT (UTGX0--D/E---) : Polychloroprene - CONTACTS: brass + coated depending on P/N B INSERT B MATERIAL : A (Without marking) M J1 INSERT COMMON QUOTES FOR ALL VERSION UTGX0--E--- J2 C UTGX0--D--- G D E F G H UTGX0----8 B.3; Validé SIDE VIEW FOR EACH VERSION SOURIAU DRG N° UTGX-0001A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTGX01419S
1. 物料型号:文档中提到了多种型号的UTGX连接器,包括UTGX0、UTGX0-D、UTGX0-E和UTGX0-S等。 2. 器件简介:连接器由不同材料制成,如PA UL94 V0塑料、镍镀黄铜和不锈钢等,具有多种引脚配置和密封条件。 3. 引脚分配:文档中提到了接触点#20和#16的引脚分配,以及它们在不同型号中的配置。 4. 参数特性:包括工作温度范围(-40°C至105°C)、绝缘电阻(5000 MΩ min)、盐雾腐蚀测试(500小时)、耐久性(500次插拔)和密封条件。 5. 功能详解:连接器设计用于满足特定的密封等级,如IP68和IP69K,适用于水下和高压水清洗设备的使用环境。 6. 应用信息:连接器适用于需要高密封性能的应用场景,如潜水设备、清洁设备等。 7. 封装信息:提供了连接器的尺寸、安装方式和螺纹规格等封装信息
UTGX01419S 价格&库存
很抱歉,暂时无法提供与“UTGX01419S”相匹配的价格&库存,您可以联系我们找货
