B
A
(Without marking)
7
UTGX0-----P
INSERT
Solder
cup
PERFORMANCE CHARACTERISTICS :
C (x4)
0.6 0.05 for contact #20
1 0.05 for contact #16
K2
K1
INSERT
INSERT
INSERT
Solder
cup
L
Lenght receptacle
D
1- Contact to be ordered separately for version
UTGX0----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
UTO-CONTACT-L-C02 (Female insulator)
UTO-DHP-003-C01 (Female insulator #20)
UTO-DHP-002-C01 (Female insulator #16)
UTO-CONTACT-L-C01 (Male insulator)
UTO-DHP-003-C01 (Male insulator #20)
UTO-DHP-001-C01 (Male insulator #16)
C144-UTS1-A (HiSeal Version)
THREAD
-IP68 1 bar during 1 week: immersion
under 10 m of water. (IEC 60529)
-IP69K : exposure to high pressure water
of cleaning equipement(DIN 40050)
PANEL CUT OUT DEFINITION
10
12
14
0.1
P
17.9
3.2
Q
R
S
15.2
18.3
18.3
22.3
18.3
20.6
20.6
25.1
21.5
23.0
23.0
T
2.8
S
FRONT mounting
REAR mounting
0 receptacle
SHELL SIZE
10
12
14
TYPE OF
LAYOUT
Standard layout (No digit)
D : HISEAL Dispolder contacts
E : HISEAL Handsolder contacts
ORIENTATIONS
Normal (no digit)
W,X,Y,Z
INSERT
ARRANGEMENT
See NOTA 2
TYPE OF
CONTACTS
P: MALE
S: FEMALE
2
14/02/2020
ISS
0.4
A
0.2
B
1
10
23.8
18.26
12
26.2
20.62
14
28.6
23.01
0.1
C
0.2
0.2
D
E
0.2
F
MAX
G
H
15.2
3.2
11.35
2.3
19.15
22.31
19.5
12.1
J1
15.8 /
17.7
J2
18.1/
MAX
K1
15.8/
17.7
L
K2
18.1/
M
11.5
N
11.5
THREAD
CLASS 2A
30% (g.)
TITLE
MASS
9/16-24 UNEF
6
11/16-24 UNEF
10
13/16-20 UNEF
13
Scale
3/2
G
F
E
D
* P/N for example
-Update drawing
FORMAT
C
A2
3
25253J
Latest modification - by:
J.FEURPRIER
PE.LANDAIS Date:10/05/2019
CUSTOMER DRAWING
MOD N
2
SQUARE FLANGE RECEPTACLE T0 - SIZE 10 12 14 - Standard and Hiseal version
UTGX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
* -1mm FOR LAYOUT 12D14
H
DATE
Designed by:
MIN /
MAX
Square flange
SHELL TYPE
B
SHELL
SIZE
UTGX 0 14 D 19 P -
BASIC SERIES
MAX
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
P/N : CROSS REF TABLE
PANEL
THICKNESS
0.15
CountryJurisdiction& Control List
FR
NOT LISTED
T
T
R
3
SHELL
SIZE
REAR
FRONT
mounting
mounting
0.1
Q
5
E
3 LOCKING
PINS RING
SCALE 2/1
P (x4)
PANEL CUT OUT
DEFINITION
4
SEALING
CONDITIONS
5
Sealing in MATED conditions withSealing in MATED conditions with COUNTERPARTand UNMATED
COUNTERPART:
conditions:
immersion under 10 m of water.
(IEC 60529)
-IP69K : exposure to high pressure water of cleaning
6
NOTA:
F
6
UTGX0-----S
H
7
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
under 500V
Corrosion salt spray: 500 hours
Durability: 500 matings and unmatings
Sealing conditions: SEE TABLE
SHELL
RECEPTACLE
N
A
- SHELL : PA UL94 V0, UL746C F1 Black color
8
- 3 LOCKING PINS RING : Nickel plated Brass + stainless
steel.
- INSERT (UTGX0-----) : PA UL94 V0, UL746C F1 Black color
- INSERT (UTGX0--D/E---) : Polychloroprene
- CONTACTS: brass + coated depending on P/N
B
INSERT
B
MATERIAL :
A
(Without marking)
M
J1
INSERT
COMMON QUOTES FOR ALL VERSION
UTGX0--E---
J2
C
UTGX0--D---
G
D
E
F
G
H
UTGX0----8
B.3; Validé
SIDE VIEW FOR EACH VERSION
SOURIAU DRG N°
UTGX-0001A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTGX014D12S”相匹配的价格&库存,您可以联系我们找货
