- SHELLS : PA UL94 V0, UL746C F1 Black color
- 3 LOCKING PINS RING : Nickel plated Brass +
stainless Steels
- INSERT : PA UL94 V0, UL746C F1
- BACKSHELLS : PA UL94 V0 F1 Black color
- BACKSHELL Seal : CR
- O'RING : Nitril
- CONTACTS : brass + coated depending on P/N
B
7
UTGX1JC----P
WIRING AREA (between insert and backshell seal
E1
ECHELLE
CAPACITY
C
B-B
COUPE
ECHELLE
Operating temperature: -40
C up to 105C
resistance: 5000 min
M
under 500V
Corrosion salt spray: 500 hours
Durability: 500 matings and unmatings
Sealing in mated conditions with counterpart:
-IP68 1 bar during 1 week :
immersion under 10 m of water. (IEC 60529)
-IP69K : exposure to high pressure water of
cleaning equipement(DIN 40050)
HEXAGON D
Insulation
(See tightening torque in table)
BACKSHELL NUT
BACKSHELL BODY
UTGX1JC----S
5
F Maxi
Total prolongator lenght
6
E2
O'RING
B-B
4
A
3 LOCKING
PINS RING
COUPE
6
1- Contact to be ordered separately : refer to
corresponding catalogue.
2- Insert arrangement refer to:
UTO-CONTACT-L-C02 (Female insulator)
UTO-DHP-003-C01 (Female insulator #20)
5
UTO-DHP-002-C01 (Female insulator #16)
UTO-CONTACT-L-C01 (Male insulator)
UTO-DHP-003-C01 (Male insulator #20)
UTO-DHP-001-C01 (Male insulator #16)
3- This part shall be used at the place of the
standard seal to accomodate with different cable
4- Plug, backshell and the reducing seal are delivered
a kit. The backshell already includes the standard
SHELL PROLONGATOR
3/2
7
NOTA:
SHELL COUPLING RING
COUPE
ECHELLE
8
PERFORMANCE CHARACTERISTICS :
3/2
BACKSHELL SEAL
3/2
A
B
C
D
E
F
G
H
MATERIAL :
COMMON QUOTES FOR ALL TYPE OF CONTACTS
8
B.3; Validé
SIDE VIEW FOR EACH TYPE OF CONTACTS
A-A
4
CountryJurisdiction& Control List
FR
NOT LISTED
P/N : CROSS REF TABLE
UTGX 1 JC 14 19 P -
BASIC SERIES
3
SHELL
SIZE
0.2
MAX
STANDARD
REDUCING
SEAL (NOTA.3)
HEXAGON backshell nut
MAX
MAX
10% (g.)
D
Tightening
torque (N.m)
E1
E2
F
MASS
1.5 / 5
18.5
1
31
38
75
22
5 / 12
3 / 9
24
2
34
41.5
78
33
7 / 14
5 / 12
26
2.5
38
45.5
84
46
A
B
C
10
15.2
26.7
2.5 / 8
12
19.15
30.1
14
22.31
35.1
Free hanging
prolongator
SHELL TYPE
1
BACKSHELL
JC
SHELL SIZE
10
12
14
ORIENTATIONS
Normal (no digit)
W,X,Y,Z
INSERT
ARRANGEMENT
See NOTA 2
TYPE OF
CONTACTS
P: MALE
S: FEMALE
2
B
14/02/2020
ISS
DATE
Designed by:
TITLE
Scale
2/1
* P/N for example
-Update drawing
25253J
Latest modification - by:
J.FEURPRIER
PE.LANDAIS Date:10/05/19
1
H
G
F
E
D
C
FORMAT
A2
CUSTOMER DRAWING
MOD N
2
FREE HANGING PROLONGATOR Type 1, SIZE 10 12 14 - standard version
UTGX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
3
SOURIAU DRG N°
UTGX-0003A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTGX1JC147P”相匹配的价格&库存,您可以联系我们找货
