UTGX6--E---
MATERIAL :
E
A
Solder
cup
8
SHELL : PA UL94 V0, UL746C F1 Black color
COUPLING RING: PA + Nickel-plated brass
INSERT (UTGX0-----) : PA UL94 V0, UL746C F1
INSERT (UTGX0--E---) : Polychloroprene
O'RING : NITRIL
MATING SEAL : SILICON
CONTACTS: brass + coated depending on P/N
7
PERFORMANCE CHARACTERISTICS :
F
7
UTGX6-----P
B
SHELL
PLUG
A
B
C
D
E
F
G
H
UTGX6-----
COMMON QUOTES FOR ALL VERSION
8
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
under 500V
Corrosion salt spray: 500 hours
Durability: 500 matings and unmatings
MATING
SEAL
Insert
6
THREAD
Sealing conditions: SEE TABLE
O'RING
6
NOTA:
5
C
1- Contact to be ordered separately for version
UTGX0----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
UTO-CONTACT-L-C02 (Female insulator)
UTO-DHP-003-C01 (Female insulator #20)
UTO-DHP-002-C01 (Female insulator #16)
UTO-CONTACT-L-C01 (Male insulator)
UTO-DHP-003-C01 (Male insulator #20)
UTO-DHP-001-C01 (Male insulator #16)
C144-UTS1-A (HiSeal Version)
D
4
UTGX6-----S
G
Solder
cup
CountryJurisdiction& Control List
FR
NOT LISTED
5
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
P/N : CROSS REF TABLE
INSERT
3
SEALING
CONDITIONS
A.6; Validé
SIDE VIEW FOR EACH VERSION
Sealing in MATED conditions with COUNTERPART
Sealing in MATED conditions with COUNTERPART:
and UNMATED conditions:
-IP68 1 bar during 1 week: immersion under
10 m of water. (IEC 60529)
10 m of water. (IEC
-IP69K : exposure to high pressure water of
cleaning equipement(DIN 40050)
cleaning equipement
60529)
(DIN 40050)
SHELL TYPE
6 Plug
SHELL SIZE
10
12
14
TYPE OF
LAYOUT
Standard layout (No digit)
E : HISEAL Handsolder contacts
ORIENTATIONS
Normal (no digit)
W,X,Y,Z
INSERT
ARRANGEMENT
See NOTA 2
TYPE OF
CONTACTS
P: MALE
S: FEMALE
2
A
12/02/2020
ISS
MAX
SHELL
SIZE
A
B
min
C
D
E
10
1
12
33.3
24
25.5
24
23.5
14
0.2
F
MAX
G
THREAD
CLASS 2A
TITLE
MASS
26.2
9/16-24 UNEF
29.7
11/16-24 UNEF
25
26.7
34.6
13/16-20 UNEF
35
Scale
2/1
G
F
* P/N for example
New drawing
E
D
C
A2
3
25253J
Latest modification - by:
J.FEURPRIERDate:12/02/2020
CUSTOMER DRAWING
MOD N
2
PLUG T6 WITHOUT BACKSHELL - SIZE 10 12 & 14, Standard and Hiseal version
UTGX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
FORMAT
H
DATE
Designed by:
10% (g.)
20.3
UTGX 6 14 E 19 P -
BASIC SERIES
SOURIAU DRG N°
UTGX-0004A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTGX61210S”相匹配的价格&库存,您可以联系我们找货
