UTGX0JC102W2S
UTGX0JC102W2S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT HSG F 4P INLINE PNL MT
UTGX0JC102W2S 数据手册
7 UTGX0JC-----P WIRING AREA (between insert and backshell seal I1 MATERIAL : N - SHELL : PA UL94 V0, UL746C F1 Black color 8 - 3 LOCKING PINS RING : Nickel plated Brass + stainless steel. - BACKSHELLS : PA UL94 V0 F1 Black color - BACKSHELL Seal : CR - INSERT (UTGX0JC-----) : PA UL94 V0, UL746C F1 Black color - INSERT (UTGX0JC--/E---) : Polychloroprene - CONTACTS: brass + coated depending on P/N WIRING AREA (between insert and backshell seal I2 7 REAR mounting PERFORMANCE CHARACTERISTICS : WIRING AREA (between insert and backshell seal I4 6 NOTA: 1- Contact to be ordered separately for version UTGX0JC----- : refer to corresponding catalogue. 2- Insert arrangement refer to: UTO-CONTACT-L-C02 (Female insulator) UTO-DHP-003-C01 (Female insulator #20) UTO-DHP-002-C01 (Female insulator #16) UTO-CONTACT-L-C01 (Male insulator) UTO-DHP-003-C01 (Male insulator #20) UTO-DHP-001-C01 (Male insulator #16) C144-UTS1-A (HiSeal Version) M PANEL CUT OUT DEFINITION 5 Sealing in MATED conditions with COUNTERPART: Sealing in MATED conditions with COUNTERPART and UNMATED conditions: -IP68 1 bar during 1 week: immersion under 10 m of water. (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement(DIN 40050) BACKSHELL NUT BACKSHELL SEAL 10 12 14 REAR mounting 0.1 J 3.2 0.1 K 0.15 L M 17.9 18.3 18.3 22.3 20.6 20.6 25.1 23.0 23.0 PANEL THICKNESS MAX N 2.8 CountryJurisdiction& Control List FR NOT LISTED A (Without marking) B SHELL TYPE 2 A B 1 10 23.8 18.26 12 26.2 20.62 14 28.6 23.01 H 0.1 C 0.2 0.2 D E 15.2 3.2 19.15 11.35 22.31 G MAX F HEXAGON backshell nut G Tightening torque (N.m) H 30% (g.) I1 I2 I3 I4 67 18.5 1 2.5 / 8 1.5 / 5 20.5 32 28 32 15 70 24 2 5 / 12 3 / 9 24 36 32 36 25 76 26 2.5 7 / 14 5 / 12 28 39.5 36 39.5 35 F E D Normal (no digit) W,X,Y,Z SHELL SIZE 10 12 14 TYPE OF CONTACTS P: MALE S: FEMALE TYPE OF LAYOUT Standard layout (No digit) E : HISEAL Handsolder contacts INSERT ARRANGEMENT See NOTA 2 22/09/2020 DATE TITLE MASS Square flange receptacle 0 JC Designed by: MINI * P/N for example BACKSHELL ISS 0.2 UTGX 0 JC 14 E 19 P BASIC SERIES A 0.4 4 P/N : CROSS REF TABLE C (x4) REDUCING STANDARD SEAL (NOTA.3) 5 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) B CAPACITY H 3 BACKSHELL BODY HEXAGON G (See tightening torque in table) F MAX E SHELL SHELL SIZE -IP68 1 bar during 1 week: immersion under 10 m of water. (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement(DIN 40050) D 4 COMMON DIMENSIONS SEALING FOR ALL VERSION CONDITIONS Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M under 500V Corrosion salt spray: 500 hours Durability: 500 matings and unmatings Sealing conditions: SEE TABLE L WIRING AREA (between insert and backshell seal I3 K A (Without marking) 6 UTGX0JC-----S J (x4) SHELL SIZE A UTGX0JC--E--- B C D E F G H UTGX0JC----- PANEL CUT OUT DEFINITION 8 A.3; Validé SIDE VIEW FOR EACH VERSION Scale 3/2 -New drawing -- . Latest modification - by: -- J.FEURPRIERDate:22/09/2020 C A2 2 SQUARE FLANGE RECEPTACLE WITH BACKSHELL - SIZE 10 12 14 - Std and Hiseal version UTGX CONNECTOR Dimensions in mm General linear Tolerances: 0.2 www.souriau.com FORMAT CUSTOMER DRAWING MOD N 3 SOURIAU DRG N° UTGX-0011A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTGX0JC102W2S 价格&库存
很抱歉,暂时无法提供与“UTGX0JC102W2S”相匹配的价格&库存,您可以联系我们找货
