UTSX012D10PX
UTSX012D10PX
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    SQUARE FLANGE RECEPTACLE, WITHOU
UTSX012D10PX 数据手册
B A (Without marking) UTSX0-----P 7 INSERT Solder cup NOTA: L Lenght receptacle D 0.6 0.05 for contact #20 1 0.05 for contact #16 1- Contact to be ordered separately for version UTSX0----- : refer to corresponding catalogue. 2- Insert arrangement refer to: UTX_LAYOUT (Standard Version) UTX-HS_LAYOUT (HiSeal Version) 3- Gasket to be ordered separately for version UTSX0----- : refer to corresponding catalogue. 4- In rear mount : Color coding ring is impossible THREAD F 6 UTSX0-----S SHELL RECEPTACLE INSERT INSERT REAR FRONT mounting mounting 0.1 SHELL SIZE 10 12 14 P 3.2 0.15 0.1 17.9 Q R SCALE 2/1 FRONT mounting (See nota 4) Screw head thickness + panel thickness 18.3 18.3 22.3 18.3 20.6 20.6 25.1 21.5 23.0 23.0 Screw head thickness REAR mounting T Q P/N : CROSS REF TABLE T 2.8 Gasket (See nota 3) Gasket (See nota 3) 2 0.4 A 0.2 B 1 10 23.8 18.26 12 26.2 20.62 14 28.6 23.01 0.1 C 0.2 0.2 D E 0.2 F MAX G H 15.2 3.2 11.35 2.3 19.15 22.31 19.5 12.1 J1 15.8 / 17.7 * J2 18.1/ 20 * MAX K1 15.8/ 17.7 * L K2 M N G F SHELL SIZE 10 12 14 TYPE OF LAYOUT Standard layout (No digit) D : HISEAL Dispolder contacts E : HISEAL Handsolder contacts ORIENTATIONS Normal (no digit) W,X,Y,Z INSERT ARRANGEMENT See NOTA 2 TYPE OF CONTACTS P: MALE S: FEMALE B 15/09/2021 ISS DATE Scale 1/1 9/16-24 UNEF 18.1/ 20 * 32.3 11.5 11.5 11/16-24 UNEF D * P/N for example Mass column deleted / nota 4 added / Latest modification - by: J.GAMBIER Q.LECOMTE Date: 06/07/2020 FORMAT C A2 3 25782C Panel cut out definition board modified CUSTOMER DRAWING MOD N 2 SQUARE FLANGE RECEPTACLE T0 - SIZE 10 12 14 - Standard and Hiseal version UTSX CONNECTOR Dimensions in mm General linear Tolerances: 0.2 www.souriau.com 13/16-20 UNEF E Square flange 0 receptacle TITLE THREAD CLASS 2A * -1mm FOR LAYOUT 12D14 H UTSX 0 14 D 19 P - SHELL TYPE Designed by: MIN / MAX 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) BASIC SERIES S SHELL SIZE CountryJurisdiction& Control List FR NOT LISTED T MAX S 15.2 P (x4) 5 3 LOCKING PINS REAR mounting FRONT mounting PANEL CUT OUT DEFINITION 6 E R 3 PANEL CUT OUT DEFINITION 4 SEALING CONDITIONS 5 Sealing in MATED conditions withSealing in MATED conditions with COUNTERPART and UNMATED COUNTERPART: conditions: -IP6x : No ingress of dust -IPx8 1 bar during 1 week: -IP6x : No ingress of dust immersion under 10 m of water. -IPx8 1 bar during 1 week: immersion -IPx9K : exposure to high presunder 10 m of water. sure water of cleaning -IPx9K : exposure to high pressure water equipement (IEC 60529) of cleaning equipement (IEC 60529) 7 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M under 500V Corrosion salt spray: 500 hours Durability: 250 matings and unmatings Sealing conditions: SEE TABLE C (x4) N K1 SHELL : PA UL94 V0, UL746C F1 Black color 8 INSERT (UTSX0-----) : PA UL94 V0, UL746C F1 Black color INSERT (UTSX0--D/E---) : Polychloroprene UL94 HB CONTACTS: brass + coated depending on P/N PERFORMANCE CHARACTERISTICS : 0.6 0.05 for contact #20 1 0.05 for contact #16 K2 A INSERT Solder cup B - B INSERT H MATERIAL : A (Without marking) M J1 INSERT COMMON QUOTES FOR ALL VERSION UTSX0--E--- J2 C UTSX0--D--- G D E F G H UTSX0----8 B.2; Validé SIDE VIEW FOR EACH VERSION SOURIAU DRG N° UTSX-0001A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTSX012D10PX
1. 物料型号:文档中提到了不同的型号,例如UTSX0,但具体的型号列表没有明确列出。 2. 器件简介:文档描述了一种连接器,具有不同的密封条件,如IP6x(防尘)、IPx8(1巴压力下1周的水浸)、IPx9K(高压水清洗设备)。 3. 引脚分配:文档中提到了接触点分配,例如接触点#20和#16,但没有提供详细的引脚分配图或列表。 4. 参数特性:文档列出了一些性能特性,如工作温度范围(-40°C至105°C)、绝缘电阻(500V下至少5000MΩ)、盐雾腐蚀测试(500小时)、耐久性(250次插拔)和密封条件。 5. 功能详解:文档提供了连接器的详细视图和尺寸信息,包括插入件、焊杯、密封条件等。 6. 应用信息:文档提到了连接器的应用,如需要密封保护的环境。 7. 封装信息:文档提供了封装的详细尺寸和安装信息,包括面板切割定义、螺纹规格等。
UTSX012D10PX 价格&库存
很抱歉,暂时无法提供与“UTSX012D10PX”相匹配的价格&库存,您可以联系我们找货
