UTSX7142G1P
UTSX7142G1P
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    3(2 + PE) 针位圆形连接器 插座外壳 面板安装 防紫外线
UTSX7142G1P 数据手册
MATERIAL : 0.6 0.05 for contact #20 1 0.05 for contact #16 UTSX7--E--- - A (without marking) 7 UTSX7-----P COMMON QUOTES FOR ALL VERSION Solder cup 0.6 0.05 for contact #20 1 0.05 for contact #16 6 NOTA: Solder cup E F O'RING 1- Contact to be ordered separately for version UTSX7----- : refer to corresponding catalogue. 2- Insert arrangement refer to: C 6 UTSX7-----S L NUT 5 UTX_LAYOUT (Standard Version) UTX-HS_LAYOUT (HiSeal Version) THREAD 4,2 ECHELLE D CountryJurisdiction& Control List FR NOT LISTED V : Drill diameter For hold down clip( x2) P/N : CROSS REF TABLE HATTING AREA: Contact on PCB 2/1 T 3 2 SHELL SIZE A 10 1 12 14 0.2 MAX B C 27.00 22.15 31.75 27.15 34.90 30.20 0.2 D 0.3 0.2 MAX E F G 0.25 H MIN / MAX MAX J K 0.25 L MIN / MAX M 19.15 2.2 24.5 15.2 6.57 11.5/13.4 7.8 * 6.57 N 0.15 17.9 11.5/13.4 21.3 * 22.7 24.4 25.9 22.31 2 P 16.6 15.20 18.1 0.1 Q 0.1 0.1 0.1 0.1 R S T U 3.98 3 9.85 9.20 5.31 4.92 12.17 11.37 6.56 5.29 13.10 12.23 7.06 0.1 UNEF CLASS 2A V THREAD G F E D SHELL SIZE 10 12 14 TYPE OF LAYOUT Standard layout (No digit) D : HISEAL Dispolder contacts E : HISEAL Handsolder contacts ORIENTATIONS Normal (no digit) W,X,Y,Z INSERT ARRANGEMENT See NOTA 2 TYPE OF CONTACTS P: MALE S: FEMALE B 15/09/2021 ISS DATE Scale 3/2 7/8 20 FORMAT C A2 3 SPECIFICATION : Without Hold on 32: With Hold on (see definition in table) Mass column deleted -- 25782C Latest modification - by: J.GAMBIER Date: 17/07/2020 Q.LECOMTE CUSTOMER DRAWING MOD N 2 JAM NUT RECEPTACLE - SIZE 10 12 & 14 - Standard and Hiseal version CONNECTEUR UTSX Dimensions in mm General linear Tolerances: 0.2 www.souriau.com * -1mm FOR LAYOUT 12D14 H Jam nut receptacle 7 TITLE 1"20 * P/N for example SHELL TYPE Designed by: 11/16 24 3.1 UTSX 7 14 D 19 P - -- BASIC SERIES U 0.2 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) R Hold on 5 3 LOCKING PINS S P SHELL RECEPTACLE CONNECTOR FRONT VIEW : SPECIFICATION 32 N 4 PANEL CUT OUT and DRILLING PATTERN DEFINITION SEALING CONDITION Sealing in MATED conditions with Sealing in MATED conditions with COUNTERPART Sealing in MATED conditions with COUNTERPART COUNTERPART : and UNMATED conditions: and UNMATED conditions: -IP6x : No ingress of dust -IP6x : No ingress of dust -IP6x : No ingress of dust -IPx8 1 bar during 1 week: immersion -IPx8 1 bar during 1 week: immersion -IPx8 1 bar during 1 week: immersion under 10 m of water. under 10 m of water. under 10 m of water. -IPx9K : exposure to high pressure water -IPx9K : exposure to high pressure water -IPx9K : exposure to high pressure water of cleaning equipement(IEC 60529) of cleaning equipement(IEC 60529) of cleaning equipement(IEC 60529) PANEL THICKNESS Q 7 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M Corrosion salt spray: 500 hours Durability: 250 matings and unmatings Sealing conditions: SEE TABLE B M 8 SHELL : PA UL94 V0, UL746C F1 Black color INSERT (UTSX7-----) : PA UL94 V0, UL746C F1 INSERT (UTSX7--D/E---) : Polychloroprene UL94 HB NUT : Aluminium alloy + Anodic oxidation O'RING : Nitril CONTACTS : brass + coated depending on P/N PERFORMANCE CHARACTERISTICS : Insert K A H G J B UTSX7--D--- C D E F G H UTSX7----- 8 B.2; Validé SIDE VIEW FOR EACH VERSION SOURIAU DRG N° UTSX-0002A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTSX7142G1P
物料型号:UTSX7-----P, UTSX7----UTSX7--D--UTSX7--E--
器件简介:文档描述了一种连接器,具有不同的密封等级,包括IP6x(防尘)、IPx8(1巴压力下1周水浸10米)和IPx9K(高压水清洗设备,符合IEC 60529标准)。
引脚分配:文档提供了详细的尺寸和引脚分配,例如对于接触点#20和#16,有特定的尺寸要求。
参数特性:操作温度范围为-40°C至105°C,绝缘电阻至少为5000MΩ,耐盐雾腐蚀500小时,耐用性为250次插拔。
功能详解:文档详细描述了连接器的密封性能和材料规格,包括外壳、插入件、螺母、O型圈和接触点的材料。
应用信息:适用于需要高密封性能的应用场景,如水下或高压水清洗环境。
封装信息:提供了连接器的尺寸规格和安装要求,例如面板厚度、钻孔直径等。
UTSX7142G1P 价格&库存
很抱歉,暂时无法提供与“UTSX7142G1P”相匹配的价格&库存,您可以联系我们找货
UTSX7142G1P
  • 1+93.644501+11.91148
  • 10+81.1568710+10.32306
库存:13
