MATERIAL :
0.6 0.05 for contact #20
1 0.05 for contact #16
UTSX7--E---
A
(without marking)
7
UTSX7-----P
COMMON QUOTES FOR ALL VERSION
Solder
cup
6
NOTA:
Solder
cup
E
F
O'RING
1- Contact to be ordered separately for version
UTSX7----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
C
6
UTSX7-----S
L
NUT
5
UTX_LAYOUT (Standard Version)
UTX-HS_LAYOUT (HiSeal Version)
THREAD
4,2
ECHELLE
D
CountryJurisdiction& Control List
FR
NOT LISTED
V : Drill diameter
For hold down clip( x2)
P/N : CROSS REF TABLE
HATTING AREA:
Contact on PCB
2/1
T
3
2
SHELL
SIZE A
10
1
12
14
0.2 MAX
B
C
27.00 22.15
31.75 27.15
34.90 30.20
0.2
D
0.3
0.2 MAX
E
F
G
0.25
H
MIN /
MAX
MAX
J
K
0.25
L
MIN /
MAX
M
19.15
2.2
24.5
15.2
6.57
11.5/13.4
7.8
6.57
N
0.15
17.9
11.5/13.4
21.3
22.7
24.4
25.9
22.31
2
P
16.6
15.20
18.1
0.1
Q
0.1
0.1
0.1
0.1
R
S
T
U
3.98
3
9.85
9.20
5.31
4.92
12.17 11.37
6.56
5.29
13.10 12.23
7.06
0.1
UNEF CLASS
2A
V
THREAD
G
F
E
D
SHELL SIZE
10
12
14
TYPE OF
LAYOUT
Standard layout (No digit)
D : HISEAL Dispolder contacts
E : HISEAL Handsolder contacts
ORIENTATIONS
Normal (no digit)
W,X,Y,Z
INSERT
ARRANGEMENT
See NOTA 2
TYPE OF
CONTACTS
P: MALE
S: FEMALE
B
15/09/2021
ISS
DATE
Scale
3/2
7/8 20
FORMAT
C
A2
3
SPECIFICATION
: Without Hold on
32: With Hold on (see definition in table)
Mass column deleted
25782C
Latest modification - by:
J.GAMBIER
Date:
17/07/2020
Q.LECOMTE
CUSTOMER DRAWING
MOD N
2
JAM NUT RECEPTACLE - SIZE 10 12 & 14 - Standard and Hiseal version
CONNECTEUR UTSX
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
* -1mm FOR LAYOUT 12D14
H
Jam nut
receptacle
7
TITLE
1"20
* P/N for example
SHELL TYPE
Designed by:
11/16 24
3.1
UTSX 7 14 D 19 P - --
BASIC SERIES
U
0.2
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
R
Hold on
5
3 LOCKING
PINS
S
P
SHELL
RECEPTACLE
CONNECTOR FRONT VIEW : SPECIFICATION 32
N
4
PANEL CUT OUT and DRILLING
PATTERN DEFINITION
SEALING
CONDITION
Sealing in MATED conditions with
Sealing in MATED conditions with COUNTERPART
COUNTERPART :
and UNMATED conditions:
-IP6x : No ingress of dust
-IPx8 1 bar during 1 week: immersion
under 10 m of water.
-IPx9K : exposure to high pressure water
of cleaning equipement(IEC 60529)
PANEL THICKNESS
Q
7
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 250 matings and unmatings
Sealing conditions: SEE TABLE
B
M
8
SHELL : PA UL94 V0, UL746C F1 Black color
INSERT (UTSX7-----) : PA UL94 V0, UL746C F1
INSERT (UTSX7--D/E---) : Polychloroprene UL94 HB
NUT : Aluminium alloy + Anodic oxidation
O'RING : Nitril
CONTACTS : brass + coated depending on P/N
PERFORMANCE CHARACTERISTICS :
Insert
K
A
H
G
J
B
UTSX7--D---
C
D
E
F
G
H
UTSX7-----
8
B.2; Validé
SIDE VIEW FOR EACH VERSION
SOURIAU DRG N°
UTSX-0002A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTSX712D10PY32”相匹配的价格&库存,您可以联系我们找货
