- SHELLS : PA UL94 V0, UL746C F1 Black color
- INSERT : PA UL94 V0, UL746C F1
- BACKSHELLS : PA UL94 V0 F1 Black color
- BACKSHELL Seal : CR
- O'RING : Nitril
- CONTACTS : brass + coated depending on P/N
B
WIRING AREA (between insert and backshell seal
E1
7
UTSX1JC----P
A
B
C
D
E
F
G
H
MATERIAL :
COMMON QUOTES FOR ALL TYPE OF CONTACTS
8
8
PERFORMANCE CHARACTERISTICS :
CAPACITY
C
HEXAGON D
(See tightening torque in
BACKSHELL SEAL
BACKSHELL NUT
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
under 500V
Corrosion salt spray: 500 hours
Durability: 250 matings and unmatings
table)
Sealing in mated conditions with counterpart:
-IP6x : No ingress of dust
-IPx8 1 bar during 1 week :
immersion under 10 m of water.
-IPx9K : exposure to high pressure water of
cleaning equipement (IEC 60529)
5
F Maxi
Total prolongator lenght
6
E2
BACKSHELL BODY
UTSX1JC----S
B.2; Validé
SIDE VIEW FOR EACH TYPE OF CONTACTS
O'RING
7
6
NOTA:
1- Contact to be ordered separately : refer to
corresponding catalogue.
2- Insert arrangement refer to:
UTX_LAYOUT (Standard Version)
5
3- This part shall be used at the place of the
standard seal to accomodate with different cable
4- Plug, backshell and the reducing seal are delivered
a kit. The backshell already includes the standard
SHELL COUPLING RING
SHELL PROLONGATOR
4
3 LOCKING
PINS
COUPE
A
A-A
4
CountryJurisdiction& Control List
FR
NOT LISTED
P/N : CROSS REF TABLE
UTSX 1 JC 14 19 P -
BASIC SERIES
3
SHELL
SIZE
0.2
MAX
STANDARD
REDUCING
SEAL (NOTA.3)
HEXAGON backshell nut
MAX
MAX
D
Tightening
torque (N.m)
E1
E2
F
1.5 / 5
18.5
1
31
38
75
5 / 12
3 / 9
24
2
34
41.5
78
7 / 14
5 / 12
26
2.5
38
45.5
84
A
B
C
10
15.2
26.7
2.5 / 8
12
19.15
30.1
14
22.31
35.1
Free hanging
prolongator
SHELL TYPE
1
BACKSHELL
JC
SHELL SIZE
10
12
14
ORIENTATIONS
Normal (no digit)
W,X,Y,Z
INSERT
ARRANGEMENT
See NOTA 2
TYPE OF
CONTACTS
P: MALE
S: FEMALE
2
B
15/09/2021
ISS
DATE
Designed by:
TITLE
Scale
3/2
* P/N for example
Mass column deleted
25782C
Latest modification - by:
J.GAMBIER
Date:
Q.LECOMTE
21/07/2020
1
H
G
F
E
D
C
FORMAT
A2
CUSTOMER DRAWING
MOD N
2
FREE HANGING PROLONGATOR Type 1, SIZE 10 12 14 - standard version
CONNECTEUR UTSX
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
3
SOURIAU DRG N°
UTSX-0003A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTSX1JC1419P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+150.987441+18.70522
- 10+130.8580810+16.21147
