UTSX1JC1412PW
UTSX1JC1412PW
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    IN LINE RECEPTACLE, WITH CABLE G
UTSX1JC1412PW 数据手册
- SHELLS : PA UL94 V0, UL746C F1 Black color - INSERT : PA UL94 V0, UL746C F1 - BACKSHELLS : PA UL94 V0 F1 Black color - BACKSHELL Seal : CR - O'RING : Nitril - CONTACTS : brass + coated depending on P/N B WIRING AREA (between insert and backshell seal E1 7 UTSX1JC----P A B C D E F G H MATERIAL : COMMON QUOTES FOR ALL TYPE OF CONTACTS 8 8 PERFORMANCE CHARACTERISTICS : CAPACITY C HEXAGON D (See tightening torque in BACKSHELL SEAL BACKSHELL NUT Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M under 500V Corrosion salt spray: 500 hours Durability: 250 matings and unmatings table) Sealing in mated conditions with counterpart: -IP6x : No ingress of dust -IPx8 1 bar during 1 week : immersion under 10 m of water. -IPx9K : exposure to high pressure water of cleaning equipement (IEC 60529) 5 F Maxi Total prolongator lenght 6 WIRING AREA (between insert and backshell seal E2 BACKSHELL BODY UTSX1JC----S B.2; Validé SIDE VIEW FOR EACH TYPE OF CONTACTS O'RING 7 6 NOTA: 1- Contact to be ordered separately : refer to corresponding catalogue. 2- Insert arrangement refer to: UTX_LAYOUT (Standard Version) 5 3- This part shall be used at the place of the standard seal to accomodate with different cable 4- Plug, backshell and the reducing seal are delivered a kit. The backshell already includes the standard SHELL COUPLING RING SHELL PROLONGATOR 4 3 LOCKING PINS COUPE A A-A 4 CountryJurisdiction& Control List FR NOT LISTED P/N : CROSS REF TABLE UTSX 1 JC 14 19 P - BASIC SERIES 3 SHELL SIZE 0.2 MAX STANDARD REDUCING SEAL (NOTA.3) HEXAGON backshell nut MAX MAX D Tightening torque (N.m) E1 E2 F 1.5 / 5 18.5 1 31 38 75 5 / 12 3 / 9 24 2 34 41.5 78 7 / 14 5 / 12 26 2.5 38 45.5 84 A B C 10 15.2 26.7 2.5 / 8 12 19.15 30.1 14 22.31 35.1 Free hanging prolongator SHELL TYPE 1 BACKSHELL JC SHELL SIZE 10 12 14 ORIENTATIONS Normal (no digit) W,X,Y,Z INSERT ARRANGEMENT See NOTA 2 TYPE OF CONTACTS P: MALE S: FEMALE 2 B 15/09/2021 ISS DATE Designed by: TITLE Scale 3/2 * P/N for example Mass column deleted -- 25782C Latest modification - by: J.GAMBIER Date: Q.LECOMTE 21/07/2020 1 H G F E D C FORMAT A2 CUSTOMER DRAWING MOD N 2 FREE HANGING PROLONGATOR Type 1, SIZE 10 12 14 - standard version CONNECTEUR UTSX Dimensions in mm General linear Tolerances: 0.2 www.souriau.com SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) 3 SOURIAU DRG N° UTSX-0003A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTSX1JC1412PW 价格&库存
很抱歉,暂时无法提供与“UTSX1JC1412PW”相匹配的价格&库存,您可以联系我们找货
