UTSX61419SW
UTSX61419SW
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    PLUG, WITHOUT BACKSHELL, FOR 19
UTSX61419SW 数据手册
UTSX6--E--B MATERIAL : - E Solder cup SHELL PLUG SHELL : PA UL94 V0, UL746C F1 Black color COUPLING RING: PA UL94 V0, UL746C F1 Black color INSERT (UTSX0-----) : PA UL94 V0, UL746C F1 INSERT (UTSX0--E---) : Polychloroprene UL94 HB O'RING : NITRIL MATING SEAL : SILICON CONTACTS: brass + coated depending on P/N MATING SEAL 8 7 PERFORMANCE CHARACTERISTICS : F 7 UTSX6-----P A A B C D E F G H UTSX6----- COMMON QUOTES FOR ALL VERSION 8 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M under 500V Corrosion salt spray: 500 hours Durability: 250 matings and unmatings Insert Sealing conditions: SEE TABLE 6 THREAD O'RING 6 NOTA: 1- Contact to be ordered separately for version UTSX0----- : refer to corresponding catalogue. 2- Insert arrangement refer to: C 4 UTSX6-----S 5 D UTX_LAYOUT (Standard Version) UTX-HS_LAYOUT (HiSeal Version) G 5 Solder cup CountryJurisdiction& Control List FR NOT LISTED 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) P/N : CROSS REF TABLE INSERT 3 SEALING CONDITIONS B.2; Validé SIDE VIEW FOR EACH VERSION Sealing in MATED conditions with COUNTERPART Sealing in MATED conditions with COUNTERPART: and UNMATED conditions: -IP6x : No ingress of dust -IP6x : No ingress of dust -IPx8 1 bar during 1 week: immersion under -IPx8 1 bar during 1 week: immersion under 10 m of water. 10 m of water. -IPx9K : exposure to high pressure water of -IPx9K : exposure to high pressure water of cleaning equipement (IEC 60529) cleaning equipement (IEC 60529) 2 MAX SHELL SIZE A B min C D E 10 1 12 33.3 24 25.5 24 23.5 14 0.2 F MAX G SHELL TYPE 6 Plug SHELL SIZE 10 12 14 TYPE OF LAYOUT Standard layout (No digit) E : HISEAL Handsolder contacts ORIENTATIONS Normal (no digit) W,X,Y,Z INSERT ARRANGEMENT See NOTA 2 TYPE OF CONTACTS P: MALE S: FEMALE B 15/09/2021 ISS DATE Designed by: THREAD CLASS 2A TITLE Scale 20.3 26.2 9/16-24 UNEF 23.5 29.7 11/16-24 UNEF 26.7 34.6 13/16-20 UNEF 2/1 G F * P/N for example Mass column deleted -- Latest modification - by: J.GAMBIER Date: E D C A2 3 25782C Q.LECOMTE 20/07/2020 CUSTOMER DRAWING MOD N 2 PLUG T6 WITHOUT BACKSHELL - SIZE 10 12 & 14, Standard and Hiseal version CONNECTEUR UTSX Dimensions in mm General linear Tolerances: 0.2 www.souriau.com FORMAT H UTSX 6 14 E 19 P - BASIC SERIES SOURIAU DRG N° UTSX-0004A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTSX61419SW
物料型号:文档中提到了多种型号,例如UTSX6-----P、UTSX6----、UTSX6--E--等。
器件简介:连接器由不同材料制成,包括PA UL94 V0、UL746C F1黑色塑料、Polychloroprene UL94 HB、NITRIL O'RING、SILICON MATING SEAL和brass CONTACTS。
引脚分配:文档中提到了不同版本的引脚分配,例如UTX_LAYOUT(标准版本)和UTX-HS_LAYOUT(HiSeal版本)。
参数特性:包括工作温度范围(-40°C至105°C)、绝缘电阻(500V下至少5000 MΩ)、盐雾腐蚀测试(500小时)、耐用性(250次插拔)和密封条件。
功能详解:文档详细描述了连接器的密封性能,包括IP6x防尘、IPx8 1bar下1周的水下浸泡和IPx9K高压水清洗。
应用信息:文档中提到了连接器的应用场景,但没有具体说明。
封装信息:提供了连接器的尺寸和公差信息,例如SHELL SIZE 10、12和14,以及螺纹规格。
UTSX61419SW 价格&库存
很抱歉,暂时无法提供与“UTSX61419SW”相匹配的价格&库存,您可以联系我们找货
