UTSX6JC1492PY
UTSX6JC1492PY
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    PLUG, WITH CABLE GLAND BACKSHELL
UTSX6JC1492PY 数据手册
- UTSX6JC-----P 8 7 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M Corrosion salt spray: 500 hours Durability: 250 matings and unmatings Sealing conditions: SEE TABLE WIRING AREA (between insert and backshell seal) E4 WIRING AREA (between insert and backshell seal) E3 6 NOTA: 1- Contact to be ordered separately for version UTSX6----- : refer to corresponding catalogue. 2- Insert arrangement refer to: 4 3 COMMON QUOTES FOR ALL VERSION Sealing in MATED conditions with COUNTERPART: -IP6x : No ingress of dust -IPx8 1 bar during 1 week: immersion under 10 m of water. -IPx9K : exposure to high pressure water of cleaning equipement (IEC 60529) COUPLING RING THREAD BACKSHELL BODY -IPx9K : exposure to high pressure water of (IEC 60529) BACKSHELL SEAL BACKSHELL NUT SHELL PLUG MATING SEAL O'RING B MAX cleaning equipement CountryJurisdiction& Control List FR NOT LISTED A MAX INSERT MAX MAX STANDARD P/N : CROSS REF TABLE SHELL TYPE HEXAGON backshell nut MAX THREAD CLASS 2A 1 E1 E2 E3 E4 1.5 / 5 18.5 1 21 34.1 29 33.5 9/16-24 UNEF 5 / 12 3 / 9 24 2 25 38.1 33 37.5 11/16-24 UNEF 7 / 14 5 / 12 26 2.5 29 42.1 36 40.5 13/16-20 UNEF C 10 26.2 66 2.5 / 8 12 29.7 69 14 34.6 75.5 G F E D Plug Normal (no digit) W,X,Y,Z JC SHELL SIZE 10 12 14 TYPE OF CONTACTS P: MALE S: FEMALE TYPE OF LAYOUT Standard layout (No digit) E : HISEAL Handsolder contacts INSERT ARRANGEMENT See NOTA 2 B 15/09/2021 ISS DATE TITLE Scale 3/2 Mass column deleted -- 25782C Latest modification - by: J.GAMBIER Date: Q.LECOMTE 29/10/2020 C A2 CUSTOMER DRAWING MOD N 3 2 PLUG T6 WITH BACKSHELL JC - SIZE 10 12 & 14, Standard and Hiseal version UTSX CONNECTOR Dimensions in mm General linear Tolerances: 0.2 www.souriau.com FORMAT H 6 * P/N for example BACKSHELL Designed by: Tightening torque (N.m) B UTSX 6 JC 14 E 19 P BASIC SERIES D A 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) 2 SHELL SIZE REDUCING SEAL (NOTA.3) 5 3- This part shall be used at the place of the Sealing in MATED conditions with COUNTERPART and UNMATED conditions:standard seal to accomodate with different cable 4- Plug, backshell and the reducing seal are delivered a -IP6x : No ingress of dust a kit. The backshell already includes the standard seal. -IPx8 1 bar during 1 week: immersion under 10 m of water. HEXAGON D (See tightening torque in table) 5 UTX_LAYOUT (Standard Version) UTX-HS_LAYOUT (HiSeal Version) CAPACITY C 6 CONDITIONS SHELL :PA UL94 V0, UL746C F1 Black color COUPLING RING: PA UL94 V0 F1 Black color BACKSHELLS : PA UL94 V0 F1 Black color BACKSHELL Seal : CR INSERT (UTSX0-----) : PA UL94 V0, UL746C F1 INSERT (UTSX0--E---) : Polychloroprene UL94 HB O'RING : NITRIL MATING SEAL : SILICON CONTACTS: brass + coated depending on P/N PERFORMANCE CHARACTERISTICS : UTSX6JC-----S 7 SEALING A UTSX6JC--E--WIRING AREA (between insert and backshell seal) E2 WIRING AREA (between insert and backshell seal) E1 B C D E F G H UTSX6JC----- MATERIAL : 8 B.2; Validé SIDE VIEW FOR EACH VERSION SOURIAU DRG N° UTSX-0005A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTSX6JC1492PY
物料型号:UTSX6JC系列
器件简介:文档描述了连接器的材质和结构,包括外壳、耦合环、后壳、密封圈、接触件等。
引脚分配:文档中提到了不同版本的连接器布局,但未提供具体的引脚分配图。
参数特性:工作温度范围为-40°C至105°C,绝缘电阻至少为5000MΩ,耐盐雾腐蚀500小时,耐用性为250次插拔,密封条件见表格。
功能详解:连接器在连接状态下具有防尘(IP6x)、浸水(IPx8)和高压水清洗设备(IPx9K)的密封性能。
应用信息:适用于需要高密封性能的场合,例如水下或清洁设备。
封装信息:提供了连接器的尺寸和公差信息,以及后壳螺母的规格。
UTSX6JC1492PY 价格&库存
很抱歉,暂时无法提供与“UTSX6JC1492PY”相匹配的价格&库存,您可以联系我们找货
