UTSX6JC147PSCR
UTSX6JC147PSCR
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    PLUG, WITH CABLE GLAND BACKSHELL
UTSX6JC147PSCR 数据手册
6 UTSX6JC-----PSCR UTSX6JC-----SSCR 7 - A-A SHELL : PA UL94 V0, UL746C F1 Black color COUPLING RING: PA UL94 V0 F1 Black color BACKSHELLS : PA UL94 V0 F1 Black color BACKSHELL Seal : CR INSERT : PA UL94 V0, UL746C F1 O'RING : NITRIL MATING SEAL : SILICON CONTACT SPRING: copper alloy CONTACT BODY : brass, gold and nickel plated SCREW : stainless steel WIRING AREA (between insert and backshell seal) E2 6 NOTA : 1- Contact to be ordered separately for version UTSX0----- : refer to corresponding catalogue. 2- Insert arrangement refer to: A-A COUPE UTX_LAYOUT (Standard Version) Only for layout 12-4 and 14-7 COUPLING RING BACKSHELL BODY THREAD BACKSHELL SEAL BACKSHELL NUT A SHELL PLUG A A MATING SEAL INSERT O'RING CountryJurisdiction& Control List FR NOT LISTED A MAX P/N : CROSS REF TABLE BASIC SERIES SHELL TYPE 2 A min STANDARD B REDUCING SEAL (NOTA.3) C HEXAGON backshell nut MAX D Tightening torque (N.m) E1 E2 12 29.7 66.7 5 / 12 3 / 9 24 2 15.1 22.8 14 34.6 71.5 7 / 14 5 / 12 26 2.5 18.95 26.7 Torquing screw advised : 20 N.cm UTSX 6 JC 14 7 P SCR 6 JC SHELL SIZE 12 14 INSERT ARRANGEMENT See NOTA 2 15/09/2021 ISS DATE Designed by: TITLE Scale 3/2 1 Wire strip length = 5,8 mm G F E D FORMAT C A2 for example 3 RACCORD B * P/N Plug SCREW TERMINATION TYPE OF CONTACTS P: MALE S: FEMALE Mass column deleted -- 25782C Latest modification - by: J.GAMBIER Date: Q.LECOMTE 29/10/2020 CUSTOMER DRAWING MOD N 2 PLUG T6 WITH BACKSHELL JC AND SCREW CONTACT - SIZE 12 & 14 CONNECTEUR UTSX Dimensions in mm General linear Tolerances: 0.2 www.souriau.com H 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) B min MAX 5 3- This part shall be used at the place of the standard seal to accomodate with different cable 4- Plug, backshell and the reducing seal are delivered as a kit. The backshell already includes the standard seal. Cable section acceptance: 0,5 mm2 to 2,5 mm2 3 HEXAGON D (See tightening torque in table) 4 COMMON QUOTES FOR ALL VERSION Sealing in MATED conditions with COUNTERPART: -IP6x : No ingress of dust -IPx8 1 bar during 1 week: immersion under 10 m of water. -IPx9K : exposure to high pressure water of cleaning equipement (IEC 60529) CAPACITY C CONDITIONS 7 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M Corrosion salt spray: 500 hours Durability: 250 matings and unmatings Sealing conditions: SEE TABLE 5 SEALING 8 PERFORMANCE CHARACTERISTICS : DETAIL CONTACT SHELL SIZE A MATERIAL : WIRING AREA (between insert and backshell seal) E1 COUPE B C D E F G H 8 B.2; Validé SIDE VIEW FOR EACH VERSION SOURIAU DRG N° UTSX-0006A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTSX6JC147PSCR 价格&库存
很抱歉,暂时无法提供与“UTSX6JC147PSCR”相匹配的价格&库存,您可以联系我们找货
