UTSX7124PSCR
UTSX7124PSCR
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    4(3 + PE) 针位圆形连接器 插座,公形引脚 螺钉
UTSX7124PSCR 数据手册
7 MATERIAL : - A (without marking) UTSX7-----PSCR G B 1- Contact to be ordered separately for version UTSX7----- : refer to corresponding catalogue. 2- Insert arrangement refer to: UTX_LAYOUT (Standard Version) Only for layout 12-4 and 14-7 E F O'RING 5 SEALING CONDITION SHELL RECEPTACLE 4 3 LOCKING PINS D PANEL THICKNESS L CountryJurisdiction& Control List FR NOT LISTED 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) P/N : CROSS REF TABLE UTSX 7 14 7 P SCR * P/N for example J BASIC SERIES SHELL TYPE DETAIL CONTACT 2 0.2 SHELL SIZE A 0.2 B 31.75 27.15 1 34.90 30.20 0.3 C 19.3 0.2 D 19.15 22.31 0.3 E 2.2 0.2 MAX F 24.5 MAX 0.2 0.15 G H J K 46.5 38.3 21.4 22.7 52.5 44.4 24.5 25.9 2 L 3 UNEF CLASS 2A THREAD Torquing screw advised : 20 N.cm 7/8 20 Cable section acceptance: 0,5 mm2 to 2,5 mm2 3 PANEL CUT OUT 5 THREAD K 6 C 6 UTSX7-----SSCR 7 NOTA: Sealing in MATED conditions with COUNTERPART: -IP6x : No ingress of dust -IPx8 1 bar during 1 week: immersion under 10 m of water. -IPx9K : exposure to high pressure water of cleaning equipement (IEC 60529) 8 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M Corrosion salt spray: 500 hours Durability: 250 matings and unmatings Sealing conditions: SEE TABLE NUT 14 SHELL : PA UL94 V0, UL746C F1 Black color INSERT : PA UL94 V0, UL746C F1 NUT : Aluminium alloy + Anodic oxidation O'RING : Nitril CONTACT SPRING: copper alloy CONTACT BODY : brass, gold and nickel plated SCREW : stainless steel PERFORMANCE CHARACTERISTICS : H 12 A B C D E F G H SIDE VIEW FOR EACH VERSION 8 B.2; Validé COMMON QUOTES FOR ALL VERSION 7 SHELL SIZE 12 14 INSERT ARRANGEMENT See NOTA 2 B 15/09/2021 ISS DATE Designed by: TITLE Scale 3/1 1"20 3 Jam nut receptacle SCREW TERMINATION TYPE OF CONTACTS Mass column deleted -- Latest modification - by: J.GAMBIER 25782C Q.LECOMTE Date: 02/11/2020 H G F E D C FORMAT A2 CUSTOMER DRAWING MOD N 2 JAM NUT RECEPTACLE WITH SCREW CONTACT- SIZE 12 & 14 UTSX CONNECTOR Dimensions in mm General linear Tolerances: 0.2 www.souriau.com Wire strip length = 5,8 mm P: MALE S: FEMALE SOURIAU DRG N° UTSX-0007A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTSX7124PSCR 价格&库存
很抱歉,暂时无法提供与“UTSX7124PSCR”相匹配的价格&库存,您可以联系我们找货
UTSX7124PSCR
  • 1+257.170501+33.07429
  • 10+222.8845210+28.66483
库存:25
