COM-10438
COM-10438
    SPARKFUNELECTRONICS
    THERMAL PRINTER
COM-10438 数据手册
Feature: Application: ※ Smart appearance ※ Easy paper loading ※ Low noise thermal printing ※ Different interfaces optional ◆ Oiling Machine print proposal ◆ Queue machine Print proposal ◆ Recording Meter print proposal ◆ Self-service Print proposal ฀฀฀฀฀฀฀฀฀฀฀฀฀ ※ Front panel make paper replacement easily ◆ Ticket Machine print proposal ※ Easily embedded to any kinds of instruments and meters ◆ Medical instrument print proposal ◆ Weight Machine Print proposal ◆ Electric Instrument Print proposal ◆ Test Instrument Print proposal ฀฀฀฀฀฀฀฀฀฀฀ ฀฀฀฀฀฀฀฀฀฀฀฀฀ ฀฀ ฀฀฀฀ Specification: Print Character Paper Spec Reliability Printing Method Thermal Dot Line Printing Speed 50-80mm/s Resolution 8 dots/mm, 384 dots/line Effective Printing Width Character Set 48mm ASCII,GB2312-80(Chinese) Print Font ANK:5×7, Chinese: 12x24,24×24 Paper Type Thermal paper Paper Width 57.5± 0.5mm Paper Roll Diameter Max: 39mm MCBF 5 million lines Interface Serial(RS-232,TTL), Parallel Insert Depth 50mm Power Supply (Adapter) DC5V-9V Physical Environment Outline Dimension (WxDxH) 111x65x57mm Installation Port Size 103 x 57mm Color Beige/Black Operating Temp 5°C ~ 50°C Operating Humidity 10% ~ 80% Storage Temp -20°C ~ 60°C Storage Humidity 10% ~ 90% ฀฀฀฀฀฀฀฀฀฀฀฀฀฀฀฀฀฀ Model No.: A2 Micro Pannel Thermal Printer ฀฀฀฀฀฀฀ ฀฀฀฀ ฀฀฀฀฀
COM-10438
物料型号:A2 Micro Pannel Thermal Printer
器件简介:该打印机具有智能外观、易于装载纸张、低噪音热打印、可选不同接口、易于嵌入各种仪器和仪表、前面板使纸张更换变得容易。
引脚分配参数特性功能详解应用信息封装信息的具体内容在文档中没有直接提及,但以下是一些相关的信息:
- 打印方式:热点线式 - 打印速度:50-80mm/s - 分辨率:8点/mm, 384点/线 - 有效打印宽度:48mm - 字符集:ASCII, GB2312-80(中文) - 打印字体:ANK:5×7, 中文: 12x24,24×24 - 纸张类型:热敏纸 - 纸张宽度:57.5±0.5mm - 纸卷直径:最大39mm - MCBF:500万行 - 可靠性:500万行 - 电源适配器:DC5V-9V - 接口:串行(RS-232, TTL), 并行 - 插入深度:50mm - 物理尺寸(WxDxH):111x65x57mm - 安装端口尺寸:103 x 57mm - 颜色:米色/黑色 - 工作温度:5°C ~ 50°C - 工作湿度:10% ~ 80% - 存储温度:-20°C ~ 60°C - 存储湿度:10% ~ 90%
COM-10438 价格&库存
很抱歉,暂时无法提供与“COM-10438”相匹配的价格&库存,您可以联系我们找货
