XIAMEN OCULAR
GDM1602K
LED BKL
Feature
1. 5X8 dots with cursor
2. Built-in controller (KS0066U or Equivalent)
3. +5V power supply(Also available for +3.0V)
4. 1/16 duty
5. BKL to be driven by pin1,pin2,or pin15,pin16,or A,K
6. N.V.optional
PIN NO
Symbol
Fuction
Mechanical Data
Item
Standard
Unit
Module dimension
80.0x36.0
mm
Viewing area
64.5x16.4
mm
Dot size
0.56x0.61
mm
Character size
3.00x5.23
mm
Absolute Maximum Rating
Item
Symbol
1
VSS
GND
2
VDD
+5V
3
V0
Contrast adjustment
4
RS
H/L Register select signal
5
R/W
H/L Read/Write signal
6
E
H/L Enable signal
Input voltage
VDD
DB0
H/L Data bus line
Supply current
IDD
7
5.5
Input voltage
VI
-0.3
VDD
Item
Symbol
H/L Data bus line
10
DB3
H/L Data bus line
11
DB4
H/L Data bus line
LED forward voltage
VF
DB5
H/L Data bus line
LED forward current
H/L Data bus line
EL power supply
current
15
A
16
K
H/L Data bus line
+4.2V for LED
Power supply for BKL(0V)
Unit
V
Electronical characteristics
DB2
DB7
Max
9
14
Typ
-0.3
H/L Data bus line
DB6
Min
VDD-VSS
DB1
13
Standard
Power supply
8
12
Display Pattern
EL BKL/ or
without BKL
Recommended
LCD riling voltage
for normal temp
version module
VDD-V0
Condition
Standard
Min
Typ
Max
Unit
+5V
4.7
5.0
5.5
V
+3.3V
2.7
3.0
5.3
V
VDD=5V
1.5
4
-20ºC
0 ºC
4.7
5.0
5.5
25ºC
4.3
4.5
4.7
mA
V
50ºC
4.1
4.3
4.5
70ºC
25ºC
4.2
4.6
V
IF
25ºC
120
160
mA
IEL
VEL=110V
AC 400Hz
mA
Display character address code:
Display position
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
DDRAM address 00 01 02 --- --- --- --- --0FH
DDRAM address 40 41 42 --- --- --- --- --4FH
很抱歉,暂时无法提供与“LCD-18160”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+348.96960
- 200+139.24440
- 500+134.58960
- 1000+132.28920
