STE-1046932C500
STE-1046932C500
    STEUTE
    STEUTE MINIATURE LIMIT SWITCH
STE-1046932C500 数据手册
Miniature limit switch C 500 R 1Ö/1S Material no.: 1046932 (material no. old: 48009001) Product features Dimensions • Thermoplastic enclosure • Actuator: Roller plunger R Notes • With roller plunger turned 90° available on request Technical data Applied standards EN ISO 13849-1, EN 60947-5-1 Connection screw connection terminals Enclosure thermoplastic, glass-fibre reinforced, shockproof, selfextinguishing UL 94 V-0 Cable cross-section max. 1.5 mm² Actuator plunger: brass Tightening torque enclosure mounting screws: approx. 1 Nm cover screws: approx. 0.6 Nm Rated impulse withstand voltage Uimp 4 kV Rated insulation voltage Ui 400 V Conventional thermal current Ithe 4A Degree of protection IP30 (IEC/EN 60529) Rated operating current/voltage Ie/Ue 4 A/400 VAC B10d (10 % load) 70 000 ‒ with an actuating angle of 30° Utilisation category AC-15 TM max. 20 years Short-circuit protection 4 A gG/gN fuse Degree of pollution 3 Ambient temperature ‒20 °C … +75 °C Contact material silver Mechanical life 70 000 operations ‒ with an actuating angle of 30° Switching system slow action, positive break NC contacts A Operation cycles max. 1800/h Switching elements 1 NC/1 NO contact, type Zb Repeat accuracy of switching points ± 0.1 mm Errors and omissions excepted. steute Technologies GmbH & Co. KG www.steute-controltec.com Brückenstraße 91 32584 Löhne, Germany +49 5731 745-0 controltec@steute.com Page: 1 / 2 15.12.2023 Miniature limit switch C 500 R 1Ö/1S Material no.: 1046932 (material no. old: 48009001) Technical data (contd.) Contact opening max. 2 x 4 mm Weight 25 g Approvals d Contact diagram 11 23 Switching diagram 2,5 0 12 24 1 3 5 23-24 11-12 T Positive break travel/angle Errors and omissions excepted. steute Technologies GmbH & Co. KG www.steute-controltec.com Brückenstraße 91 32584 Löhne, Germany +49 5731 745-0 controltec@steute.com Page: 2 / 2 15.12.2023
STE-1046932C500 价格&库存
很抱歉,暂时无法提供与“STE-1046932C500”相匹配的价格&库存,您可以联系我们找货
