STE-1179743ZS71
STE-1179743ZS71
    STEUTE
    STEUTE PULL-WIRE SWITCH
STE-1179743ZS71 数据手册
Pull-wire switch ZS 71 Z 1Ö/1S Material no.: 1179743 (material no. old: 71141919) Product features • • • • Dimensions Metal enclosure Wall mounting Snap action: 2 contacts Pull-wire function without latching Notes • One wire thimble is provided. Technical data Applied standards EN 60947-5-1 Cable entry 2 x M20 x 1.5 Enclosure aluminium die-cast, powder-coated Rated impulse withstand voltage Uimp 6 kV Cover thermoplastic, glass-fibre reinforced, shockproof, selfextinguishing UL 94 V-0 Rated insulation voltage Ui 400 V Degree of protection IP65 (IEC/EN 60529) Conventional thermal current Ithe 6A Utilisation category AC-15 Contact material silver Rated operating current/voltage Ie/Ue 6 A/400 VAC Switching elements 1 NC/1 NO contact, type Zb Switching system snap action, positive break NC contacts A Connection screw connection terminals Short-circuit protection 6 A gG/gN fuse Ambient temperature ‒25 °C … +70 °C Mechanical life > 1 million operations Cable cross-section max. 2.5 mm² (incl. conductor ferrules) Errors and omissions excepted. steute Technologies GmbH & Co. KG www.steute-controltec.com Brückenstraße 91 32584 Löhne, Germany +49 5731 745-0 controltec@steute.com Page: 1 / 2 06.12.2023 Pull-wire switch ZS 71 Z 1Ö/1S Material no.: 1179743 (material no. old: 71141919) Technical data (contd.) Actuating force max. 100 N Weight 380 g Approvals dÖ] Switching diagram 0 Contact diagram 9=98N 10 13-14 21-22 21-22 13-14 7=60N Errors and omissions excepted. steute Technologies GmbH & Co. KG www.steute-controltec.com Brückenstraße 91 32584 Löhne, Germany +49 5731 745-0 controltec@steute.com Page: 2 / 2 06.12.2023
STE-1179743ZS71 价格&库存
很抱歉,暂时无法提供与“STE-1179743ZS71”相匹配的价格&库存,您可以联系我们找货
