STE-1048069ZS71
STE-1048069ZS71
    STEUTE
    STEUTE PULL-WIRE SWITCH
STE-1048069ZS71 数据手册
Pull-wire switch ZS 71 1Ö/1S / 55 N Material no.: 1048069 (material no. old: 71141001) Product features • • • • • • • Dimensions Metal enclosure 2 contacts Compact design Wire length up to 5 m Spring force variant: 55 N Wire pull and breakage detection Without mechanical latching Notes • At 3 m distance intermediate wire supports are required. One wire thimble is provided. Technical data Applied standards EN 60947-5-1, EN ISO 13849-1, GS-ET-15 Connection screw connection terminals Enclosure aluminium die-cast, powder-coated Cable cross-section max. 2.5 mm² (incl. conductor ferrules) Cover thermoplastic, glass-fibre reinforced, shockproof, selfextinguishing UL 94 V-0 Cable entry 2 x M20 x 1.5 Degree of protection IP65 (IEC/EN 60529) Rated impulse withstand voltage Uimp 6 kV Rated insulation voltage Ui 400 V B10d (10 % load) 2 million Conventional thermal current Ithe 6A TM max. 20 years Utilisation category AC-15 Contact material silver Switching system snap action, positive break NC contacts A Switching elements 1 NC/1 NO contact Rated operating current/voltage Ie/Ue 6 A/400 VAC Short-circuit protection 6 A gG/gN fuse Errors and omissions excepted. steute Technologies GmbH & Co. KG www.steute-controltec.com Brückenstraße 91 32584 Löhne, Germany +49 5731 745-0 controltec@steute.com Page: 1 / 2 06.12.2023 Pull-wire switch ZS 71 1Ö/1S / 55 N Material no.: 1048069 (material no. old: 71141001) Technical data (contd.) Ambient temperature ‒25 °C … +70 °C Approvals dÖ] Mechanical life > 1 million operations Weight 334 g Max. wire length 5m Switching diagram 0 5 Contact diagram 5 13-14 21-22 V 3 3 W V Wire breakage detection W Wire pull detection Errors and omissions excepted. steute Technologies GmbH & Co. KG www.steute-controltec.com Brückenstraße 91 32584 Löhne, Germany +49 5731 745-0 controltec@steute.com Page: 2 / 2 06.12.2023
STE-1048069ZS71 价格&库存
很抱歉,暂时无法提供与“STE-1048069ZS71”相匹配的价格&库存,您可以联系我们找货
STE-1048069ZS71
  • 1+1881.611021+243.43661
库存:2
