ANT-5GW-FPC-LH100M4
ANT-5GW-FPC-LH100M4
    LINXTECHNOLOGIES(灵思)
    657.5MHz, 750.5MHz, 842.5MHz, 1.175GHz, 1.593GHz, 1.947GHz, 2.495GHz, 3.75GHz, 4.7GHz 2G,3G,4G,5G,LT...
ANT-5GW-FPC-LH100M4 数据手册
2356607-1 Plug, Cable-to-Cable, 4 Position, .197 in [5 mm] Centerline, Sealable, Black, Wire & Cable, Signal, Cable Mount (Free-Hanging), Superseal Pro 2356607-1  ACTIVE AMP | Superseal Pro TE Internal #: 2356607-1 Plug, Cable-to-Cable, 4 Position, .197 in [5 mm] Centerline, Sealable, Black, Wire & Cable, Signal, Cable Mount (Free-Hanging), Superseal Pro View on TE.com > Connectors > Automotive Connectors > Automotive Housings Connector System: Cable-to-Cable Number of Positions: 4 Connector & Housing Type: Plug Centerline (Pitch): 5 mm [ .197 in ] Sealable: Yes Features Product Type Features Mixed & Hybrid Connector No Connector Shape Rectangular Connector System Cable-to-Cable Connector & Housing Type Plug Sealable Yes Connector & Contact Terminates To Wire & Cable Primary Locking Feature Clean Body Configuration Features Number of Positions 4 Number of Rows 2 Electrical Characteristics Operating Voltage 12 VDC Nominal Voltage Architecture 12 V Body Features  For support call+1 800 522 6752 01/02/2024 09:40PM | Page 1 2356607-1 Plug, Cable-to-Cable, 4 Position, .197 in [5 mm] Centerline, Sealable, Black, Wire & Cable, Signal, Cable Mount (Free-Hanging), Superseal Pro Body Features Cable Exit Angle 180° Primary Product Color Black Connector & Keying Code A Contact Features Contact Size 1.2mm Mating Tab Width 1.2 mm[.047 in] Contact Current Rating (Max) 7.5 A Mechanical Attachment Mating Alignment Type Keyed Mating Alignment With Connector Mounting Type Cable Mount (Free-Hanging) Housing Features Housing Material PBT GF Centerline (Pitch) 5 mm[.197 in] Usage Conditions Operating Temperature (Max) 125 °C[257 °F] Operating Temperature Range -40 – 125 °C[-40 – 257 °F] Operation/Application Circuit Application Signal Other Connector Position Assurance Capable No Product Compliance For compliance documentation, visit the product page on TE.com>  EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Compliant China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Not Low Halogen - contains Br or Cl > 900 ppm. For support call+1 800 522 6752 01/02/2024 09:40PM | Page 2 2356607-1 Plug, Cable-to-Cable, 4 Position, .197 in [5 mm] Centerline, Sealable, Black, Wire & Cable, Signal, Cable Mount (Free-Hanging), Superseal Pro ppm. Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts TE Part # 2356631-1 4POS,MCON 1.2,TAB HSG ASSY,SLD, COD A Also in the Series Superseal Pro Automotive Housings(87) Connector Backshells(14) Connector Caps & Covers(1) Other Automotive Connector Accessories(1) Customers Also Bought  TE Part #206070-8 TE Part #DT04-2P TE Part #W2S TE Part #0460-202-16141 CABLE CLAMP KIT #17 REC, 2P, GRY, N Wedgelocks: DEUTSCH DT DEUTSCH Solid Contacts For support call+1 800 522 6752 01/02/2024 09:40PM | Page 3 2356607-1 Plug, Cable-to-Cable, 4 Position, .197 in [5 mm] Centerline, Sealable, Black, Wire & Cable, Signal, Cable Mount (Free-Hanging), Superseal Pro TE Part #282104-1 TE Part #DT06-2S TE Part #281934-2 AMP SUPERSEAL 1.5MM, CONNECTOR HOUSING PLG, 2P, GRY, N SINGLE WIRE SEAL Documents Product Drawings 4POS,MCON 1.2,REC HSG ASSY,SLD,COD A English 4POS,MCON 1.2,REC HSG ASSY,SLD,COD A English CAD Files 3D PDF 3D Customer View Model ENG_CVM_CVM_2356607-1_C.2d_dxf.zip English Customer View Model ENG_CVM_CVM_2356607-1_C.3d_igs.zip English Customer View Model ENG_CVM_CVM_2356607-1_C.3d_stp.zip English By downloading the CAD file I accept and agree to the Terms and Conditions of use. Product Specifications Superseal Pro Connector series-Applications English Product Specification English Product Specification English  For support call+1 800 522 6752 01/02/2024 09:40PM | Page 4
ANT-5GW-FPC-LH100M4 价格&库存
很抱歉,暂时无法提供与“ANT-5GW-FPC-LH100M4”相匹配的价格&库存,您可以联系我们找货
ANT-5GW-FPC-LH100M4
  • 2+32.63697
  • 10+31.98610
  • 50+31.34565
  • 100+30.71562
库存:682
ANT-5GW-FPC-LH100M4
  • 100+29.16083
  • 200+28.57766
库存:682
ANT-5GW-FPC-LH100M4
  • 10+31.98610
  • 50+31.34565
  • 100+30.71562
库存:682
