ADP-BNCF-BNCF-B
In-Series Adapter, Straight, BNC, Jack Side A, BNC, Jack Side B, 2 Position
ADP-BNCF-BNCF-B
ACTIVE
TE Internal #: ADP-BNCF-BNCF-B
Position
View on TE.com >
Connectors > Connector Accessories > Connector Adapters & Connector Savers
Connector Interface Adapter Type: In-Series Adapter
Body Orientation: Straight
Side A Interface: BNC
Side A Gender: Jack
Side B Interface: BNC
Features
Product Type Features
In-Series Adapter
Side A Interface
BNC
Side A Gender
Jack
Side B Interface
BNC
Side B Gender
Jack
Connector System
Cable-to-Cable
Sealable
No
Configuration Features
Number of Positions
2
Electrical Characteristics
Impedance
50 Ω
Body Features
Hermetically Sealed
No
Body Plating Material
Nickel
Body Material
Brass
Contact Features
Contact Mating Area Plating Material
Gold
Mechanical Attachment
RF Contact Captivation Method
For support call+1 800 522 6752
Mechanical
01/02/2024 11:39PM | Page 1
ADP-BNCF-BNCF-B
Mechanical
Connector Mounting Type
Panel Mount
Housing Features
Body Orientation
Straight
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Candidate List Declared Against: JUNE
2023 (235)
SVHC > Threshold:
Pb (2.86% in Component Part)
Article Safe Usage Statements:
Do not eat, drink or smoke when using this product. Wash thoroughly after
handling. Recycle if possible and dispose of the article by following all applicable
governmental regulations relevant to your geographic location.
Halogen Content
Low Bromine/Chlorine - Br and Cl < 900
ppm per homogenous material. Also BFR
/CFR/PVC Free
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
01/02/2024 11:39PM | Page 2
ADP-BNCF-BNCF-B
TE Part # CAT-076-BNCJKISG50
TE Part # 5227671-1
BNC RF Connector: Jack Assembly,
Isolated Ground Protection, 50 Ohm
BNC PCB VERTICAL W/PINS
Customers Also Bought
TE Part #5553811-2
TE Part #745191-7
TE Part #1676221-1
TE Part #2022104-1
ASSY, EMI RCPT,24 POSN, SCR LK
50 RCPT SP/MS STD
RN 0805 1K0 0.1% 10PPM CUT
LENGTH
XT17017
TE Part #3-2176403-8
TE Part #6-2176304-3
TE Part #2-327946-4
TE Part #1-1393248-0
3550 36R 1%
RP 1E 0.1W 44R2 0.1% 25PPM 5K RL
TERMINAL,PIDG RECT 16-14 8
W33-S1N1Q-20=W33
TE Part #CONSMA008-G
SMA Jack 50 Ohm Through Hole PCB
Documents
Product Drawings
BNC Jack to BNC Jack Bulkhead
English
Datasheets & Catalog Pages
The FCC Road Part 15 From Concept to Approval
English
RF Coaxial Connector Gender Naming
English
RF 101 Information for the RF Challenged
01/02/2024 11:39PM | Page 3
ADP-BNCF-BNCF-B
English
BNC Jack to BNC Jack Adapter
English
01/02/2024 11:39PM | Page 4
