ADP-SMAF-BNCM
ADP-SMAF-BNCM
    LINXTECHNOLOGIES(灵思)
    同轴连接器(RF) - 适配器 BNC 插头,公引脚 至 SMA 插孔,母插口 50 欧姆
ADP-SMAF-BNCM 数据手册
ADP-SMAF-BNCM Between Series Adapter, Straight, SMA, Jack Side A, BNC, Plug Side B, 1 Position ADP-SMAF-BNCM  ACTIVE TE Internal #: ADP-SMAF-BNCM Between Series Adapter, Straight, SMA, Jack Side A, BNC, Plug Side B, 1 Position View on TE.com > Connectors > Connector Accessories > Connector Adapters & Connector Savers Connector Interface Adapter Type: Between Series Adapter Body Orientation: Straight Side A Interface: SMA Side A Gender: Jack Side B Interface: BNC Features Product Type Features Connector Interface Adapter Type Between Series Adapter Side A Interface SMA Side A Gender Jack Side B Interface BNC Side B Gender Plug Configuration Features Number of Positions 1 Electrical Characteristics Impedance 50 Ω Body Features Body Plating Material Nickel Body Material Brass Contact Features RF Connector Center Contact Plating Material Gold RF Connector Center Contact Material Beryllium Copper Housing Features Body Orientation Straight Usage Conditions  Operating Temperature Range For support call+1 800 522 6752 -55 – 125 °C[-67 – 193 °F] 01/02/2024 11:39PM | Page 1 ADP-SMAF-BNCM Between Series Adapter, Straight, SMA, Jack Side A, BNC, Plug Side B, 1 Position Operating Temperature Range -55 – 125 °C[-67 – 193 °F] Operation/Application Operating Frequency 0 – 4 GHz Other Dielectric Material PTFE Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  For support call+1 800 522 6752 01/02/2024 11:39PM | Page 2 ADP-SMAF-BNCM Between Series Adapter, Straight, SMA, Jack Side A, BNC, Plug Side B, 1 Position TE Part # CONSMA007-G TE Part # CONSMA007-R178 TE Part # CONSMA007-R58 TE Part # CONSMA011-G SMA Plug 50 Ohm Cable Crimp SMA Plug 50 Ohm Cable Crimp SMA Plug 50 Ohm Cable Crimp SMA Jack 50 Ohm Cable Crimp Customers Also Bought TE Part #1367645-6 TE Part #1-2176056-9 TE Part #6651712-1 TE Part #8-322249-1 DWDM Kit Assy, Networking (13. RLP73N 2B R056 5% 5K RL 284-0162-03003=TA CONN,SKT PG SPD FLG 22-16COMM22-18MIL 6 TE Part #4-1423675-0 TE Part #1210334001 TE Part #ADP-SMAF-SMAF-B-G TE Part #ADP-SMAF-SMAF-G W57-XB1A4A10-20=CKTBKR,THERM,P MT5000-3/16-0-SP SMA Jack to SMA Jack Bulkhead SMA Jack to SMA Jack TE Part #ZPF000000000149486 TE Part #EXC902BN 732-8075-00 DUCK,EXC,902-970MHz,1/4W BNCM, 3 INCH Documents Product Drawings SMA Jack to BNC Plug English Datasheets & Catalog Pages ADAPTER, SMA JACK (FEMALE SOCKET) TO BNC PLUG (MALE PIN) English The FCC Road Part 15 From Concept to Approval English  RF Coaxial Connector Gender Naming For support call+1 800 522 6752 01/02/2024 11:39PM | Page 3 ADP-SMAF-BNCM Between Series Adapter, Straight, SMA, Jack Side A, BNC, Plug Side B, 1 Position RF Coaxial Connector Gender Naming English RF 101 Information for the RF Challenged English  For support call+1 800 522 6752 01/02/2024 11:39PM | Page 4
ADP-SMAF-BNCM 价格&库存
很抱歉,暂时无法提供与“ADP-SMAF-BNCM”相匹配的价格&库存,您可以联系我们找货
ADP-SMAF-BNCM
    • 10+171.81790
    • 50+168.39175
    库存:12
    ADP-SMAF-BNCM
      • 1+175.31695
      • 10+171.81790
      • 50+168.39175
      库存:5
