ADP-SMAF-SMPF-G
Between Series Adapter, Straight, SMA, Jack Side A, SMP, Jack Side B, 1 Position
ADP-SMAF-SMPF-G
ACTIVE
TE Internal #: ADP-SMAF-SMPF-G
Side B, 1 Position
View on TE.com >
Connectors > Connector Accessories > Connector Adapters & Connector Savers
Connector Interface Adapter Type: Between Series Adapter
Body Orientation: Straight
Side A Interface: SMA
Side A Gender: Jack
Side B Interface: SMP
Features
Product Type Features
Side A Interface
SMA
Side A Gender
Jack
Side B Interface
SMP
Side B Gender
Jack
Connector System
Cable-to-Cable
Sealable
No
Configuration Features
Number of Positions
1
Electrical Characteristics
Impedance
50 Ω
Body Features
Hermetically Sealed
No
Body Plating Material
Gold
Body Material
Brass
Contact Features
Contact Mating Area Plating Material
Gold
RF Connector Center Contact Material
Beryllium Copper
Housing Features
For support call+1 800 522 6752
01/02/2024 11:41PM | Page 1
ADP-SMAF-SMPF-G
Housing Features
Body Orientation
Straight
Usage Conditions
Operating Temperature Range
-65 – 165 °C[-85 – 329 °F]
Operation/Application
Circuit Application
Signal
Other
Dielectric Material
Polytetrafluoroethylene (PTFE)
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
No Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Candidate List Declared Against: JUNE
2023 (235)
Does not contain REACH SVHC
Halogen Content
Low Halogen - Br, Cl, F, I < 900 ppm per
homogenous material. Also BFR/CFR/PVC
Free
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
01/02/2024 11:41PM | Page 2
ADP-SMAF-SMPF-G
Compatible Parts
TE Part # CONSMA007-G
TE Part # CONSMA007-R178
TE Part # CONSMA007-R58
TE Part # CONSMA011-G
SMA Plug 50 Ohm Cable Crimp
SMA Jack 50 Ohm Cable Crimp
TE Part # CONSMP001-1
TE Part # CONSMP001-2-G
TE Part # CONSMP001-G-T
TE Part # CONSMP001-SMD-G-T
SMP Plug 50 Ohm PCB Through Hole
Mount
SMP Plug 50 Ohm PCB Surface Mount
Customers Also Bought
TE Part #38943-22L
TE Part #38941-20L
TE Part #38941-22L
TE Part #1546306-2
CONT SOC ASSY
CONT PIN
CONTACTS
2P .374" DR BARRIER STRIP
TE Part #2176329-5
TE Part #1-2176308-1
TE Part #1624349-1
TE Part #SP44902X-10
CRGP 1210 22R 1%
RP 1E 0.1W 169K 0.1% 25PPM 5K RL
NTC0805 5% 1K0
44902X GSFC 311P18-02A7R6
TE Part #1546306-9
TE Part #1825219-3
9P .374" DR BARRIER STRIP
TT11DGPC104
Documents
Product Drawings
01/02/2024 11:41PM | Page 3
ADP-SMAF-SMPF-G
Product Drawings
SMA Jack to SMP Jack
English
Datasheets & Catalog Pages
Standard vs. Reverse Polarity (RP) SMA Connectors
English
The FCC Road Part 15 From Concept to Approval
English
RF Coaxial Connector Gender Naming
English
RF 101 Information for the RF Challenged
English
SMA Jack to SMP Jack Adapter
English
01/02/2024 11:41PM | Page 4
