AEK-LTE-CER
AEK-LTE-CER
    LINXTECHNOLOGIES(灵思)
    - ANT-LTE-CER 天线 698MHz ~ 960MHz,1.71GHz ~ 2.17GHz,2.3GHz ~ 2.4GHz,2.5GHz ~ 2.7GHz 评估板
AEK-LTE-CER 数据手册
AEK-LTE-CER Eval Kit CERamic LTE Antenna AEK-LTE-CER  ACTIVE TE Internal #: AEK-LTE-CER TE Internal Description: Eval Kit CERamic LTE Antenna View on TE.com > Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  For support call+1 800 522 6752 01/02/2024 11:42PM | Page 1 AEK-LTE-CER Eval Kit CERamic LTE Antenna TE Part # ANT-LTE-CER-T Antenna CER LTE 37x5 SMT T&R Customers Also Bought TE Part #T4110402021-000 TE Part #T4132412021-000 TE Part #1825006-3 TE Part #2108994-1 M12,FEMALE,STRAIGHT,B CODE,2P, PG9,GOLD M12,FRONT MOUNT,MALE,B,2P, SOLDER WIRE GDS02S04=DIP SW,SLIDE,SMT 4G LTE Antenna (PCB Type), T&R PKG TE Part #2331389-1 TE Part #001-0012 TE Part #2108783-1 TE Part #ADP-SMAM-MMXM DET SW4.2X3.6X1.2 JB VERT.(DW) NC AG RL ANTENNA,2.4/5.5 GHz Dipole,IP67 PCB ANTENNA, SMD, 617-3800MHz SMA Plug to MMCX Plug TE Part #L9000126-01 TE Part #AEK-SP610 Antenna Adh LPWA 698-960MHz 1.13 100 UFL Eval Kit SP610 LTE Antenna Documents Datasheets & Catalog Pages VHETH Antenna Series Ground Plane Optimization English Sub-6 Cellular LTE-5G NR Frequency Band Guide English Considerations for Operation within the 260-470MHz Band English ANT-LTE-CER  English For support call+1 800 522 6752 01/02/2024 11:42PM | Page 2 AEK-LTE-CER Eval Kit CERamic LTE Antenna English Proper PCB Design for Embedded Antennas English Understanding Antenna Specifications and Operation English Antennas Design, Application and Performance English The FCC Road Part 15 From Concept to Approval English Solder Reflow Practices - Connectors English RF 101 Information for the RF Challenged English Virtual Antenna English Microsplatch Ground Plane Optimization English  For support call+1 800 522 6752 01/02/2024 11:42PM | Page 3
AEK-LTE-CER 价格&库存
很抱歉,暂时无法提供与“AEK-LTE-CER”相匹配的价格&库存,您可以联系我们找货
AEK-LTE-CER
    • 1+216.02464
    库存:3
