ANT-868-MHW-SMA-S
Module Antenna, Single Band, LoRaWAN / LPWAN, Remote Mount, Adhesive, SMA,
Omnidirectional, Single Port, Gain 3 < 6 dBi
ANT-868-MHW-SMA-S
ACTIVE
TE Internal #: ANT-868-MHW-SMA-S
Mount, Adhesive, SMA, Omnidirectional, Single Port, Gain 3 < 6 dBi
View on TE.com >
Antennas
Wireless Application: LoRaWAN, LPWAN, Wi-Fi
Mounting Location: Remote
Mounting Type: Adhesive
Antenna Termination: SMA
Antenna Type: Module
Features
Product Type Features
Antenna Termination
SMA
Configuration Features
Antenna Style
Whip
Mounting Location
Remote
Antenna Type
Module
Band Type
Single Band
Port Configuration
Single Port
Electrical Characteristics
VSWR (Max)
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Not Yet Reviewed
Halogen Content
Not Yet Reviewed for halogen content
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
For support call+1 800 522 6752
01/02/2024 11:45PM | Page 2
ANT-868-MHW-SMA-S
Compatible Parts
TE Part # CONSMA001
TE Part # CONSMA002-L-G
TE Part # CONSMA002-SMD-G
TE Part # CONSMA008-G
SMA Jack 50 Ohm PCB Through Hole
SMA Jack 50 Ohm PCB Surface Mount
SMA Jack 50 Ohm Through Hole PCB
Customers Also Bought
TE Part #T4110402021-000
TE Part #L9000030-01
TE Part #ANT-868-CW-RCL-SMA
TE Part #ANT-868-CW-RCS-SMA
M12,FEMALE,STRAIGHT,B CODE,2P,
Antenna 1/4 Wave R-Angle 2.4GHz
Antenna 1/2 Wave R-Angle 868MHz
Antenna 1/4 Wave R-Angle 868MHz
PG9,GOLD
SMA
SMA
SMA
TE Part #ANT-868-MHW-SMA-L
TE Part #HCF69273BN-60A
TE Part #3-1768395-8
TE Part #5-1768384-4
Antenna 868MHz Dipole MHW Long
M2M,HCF,LTE ULINK,SMA TOP
LBF-5115411A-001
LBF-166950A02
SMA
LOADED MONOPLO
TE Part #6-1768062-4
TE Part #8-1768064-3
LBF-204068A02
LBF-142434A03
Documents
Product Drawings
Antenna 868MHz Dipole MHW Short SMA
English
Datasheets & Catalog Pages
VHETH Antenna Series Ground Plane Optimization
English
Sub-6 Cellular LTE-5G NR Frequency Band Guide
01/02/2024 11:45PM | Page 3
ANT-868-MHW-SMA-S
English
Considerations for Operation within the 260-470MHz Band
English
Understanding Antenna Specifications and Operation
English
Antennas Design, Application and Performance
English
Antenna Color Codes
English
The FCC Road Part 15 From Concept to Approval
English
RF 101 Information for the RF Challenged
English
868 MHz Helical Dipole LPWA Antenna
English
Virtual Antenna
English
Microsplatch Ground Plane Optimization
English
01/02/2024 11:45PM | Page 4
