ANT-DB1-LPD-125
Terminal/Duck Antenna, Dual Band, Wi-Fi, External Mount, Connector, N-type,
Omnidirectional, Single Port, Gain 3 < 6 dBi
ANT-DB1-LPD-125
ACTIVE
TE Internal #: ANT-DB1-LPD-125
Connector, N-type, Omnidirectional, Single Port, Gain 3 < 6 dBi
View on TE.com >
Antennas
Wireless Application: Wi-Fi
Mounting Location: External
Mounting Type: Connector
Antenna Termination: N-type
Antenna Type: Terminal/Duck
Features
Product Type Features
Antenna Termination
N-type
Configuration Features
Antenna Style
Whip
Mounting Location
External
Antenna Type
Terminal/Duck
Band Type
Dual Band
Port Configuration
Single Port
Electrical Characteristics
VSWR (Max)
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
Not Yet Reviewed
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Not Yet Reviewed
Halogen Content
Not Yet Reviewed for halogen content
Solder Process Capability
Not reviewed for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in
articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for
substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished
product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An
Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the
product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling
based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be
updating its statements accordingly.
Compatible Parts
For support call+1 800 522 6752
01/02/2024 11:45PM | Page 2
ANT-DB1-LPD-125
Compatible Parts
TE Part # CONMHF1-SMD-G-T
TE Part # CONMHF1-SMD-T
TE Part # CONUFL001-SMD
TE Part # CONUFL001-SMD-T
U.FL/MHF1 Jack 50 Ohm PCB Surface
Mount
Mount
Conn UFL MHF Straight PCB Mount
Jack
Mount
Customers Also Bought
TE Part #3-640443-4
TE Part #4-2176056-2
TE Part #796636-4
TE Part #796634-4
04P MTA100 CONN ASSY GRN
RLP73K 2B R51 5% 5K RL
4POS 5.08MM CE VRT HDR,TRM BLK
4 POS 5.08MM R/A PLUG,TRM BLK
TE Part #796638-4
TE Part #5645235-4
TE Part #5188232-1
TE Part #103643-E
4POS 5.08MM CE R/A HDR,TRM BLK
CONN SEC II 18 POS 100C/L
2MMHM PIN HDR MOD C 55 POS
ERBIC BUS E BUS-SYSTEM SYS CAN
HO AB CU
TE Part #CSJ-SGFB-100-MHF3
TE Part #HUM-A-900-PRO-CAS
SMA to MHF3 100mm 0.81 OD
Module HUM-PRO-A 900MHz FHSS
FM XCVR FCC
Documents
Product Drawings
Antenna Dipole Swivel 2.4/5.8GHz UFL
English
Datasheets & Catalog Pages
VHETH Antenna Series Ground Plane Optimization
English
Sub-6 Cellular LTE-5G NR Frequency Band Guide
01/02/2024 11:45PM | Page 3
ANT-DB1-LPD-125
English
Considerations for Operation within the 260-470MHz Band
English
Understanding Antenna Specifications and Operation
English
Antennas Design, Application and Performance
English
Antenna Color Codes
English
The FCC Road Part 15 From Concept to Approval
English
RF 101 Information for the RF Challenged
English
Panel-Mount Dipole WiFi/WLAN Antenna
English
Virtual Antenna
English
Microsplatch Ground Plane Optimization
English
01/02/2024 11:45PM | Page 4
