ANT-GNCP-C257L160
ANT-GNCP-C257L160
    LINXTECHNOLOGIES(灵思)
    1.561GHz,1.575GHz,1.601GHz Beidou,COMPASS,GALILEO,GLONASS,GPS,IRNSS,NavIC,Qzss 陶瓷贴片 RF 天线 1.559GHz ~...
ANT-GNCP-C257L160 数据手册
ANT-GNCP-C257L160 Patch Antenna, Multi Band, GNSS / GPS, Internal/Embedded Mount, Adhesive, MHF / U.FL / UMCC, Directional, Single Port, Gain > 6 dBi ANT-GNCP-C257L160  ACTIVE TE Internal #: ANT-GNCP-C257L160 Patch Antenna, Multi Band, GNSS / GPS, Internal/Embedded Mount, Adhesive, MHF / U.FL / UMCC, Directional, Single Port, Gain > 6 dBi View on TE.com > Antennas Wireless Application: GNSS, GPS Mounting Location: Internal/Embedded Mounting Type: Adhesive Antenna Termination: MHF, MHF1, U.FL, UMCC Antenna Type: Patch Features Product Type Features Antenna Termination MHF, MHF1, U.FL, UMCC Configuration Features Mounting Location Internal/Embedded Antenna Type Patch Band Type Multi Band Port Configuration Single Port Signal Characteristics Nominal Frequency Range 1164 – 1610 Peak Gain > 6 dBi Mechanical Attachment Mounting Type Adhesive Operation/Application Directionality Directional Industry Standards  Wireless Application GNSS, GPS Primary Application GNSS, GPS Product Compliance For support call+1 800 522 6752 01/02/2024 11:46PM | Page 1 ANT-GNCP-C257L160 Patch Antenna, Multi Band, GNSS / GPS, Internal/Embedded Mount, Adhesive, MHF / U.FL / UMCC, Directional, Single Port, Gain > 6 dBi Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) SVHC > Threshold: Pb (3.26% in Component Part) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # CONMHF1-SMD-G-T TE Part # CONMHF1-SMD-T TE Part # CONUFL001-SMD TE Part # CONUFL001-SMD-T U.FL/MHF1 Jack 50 Ohm PCB Surface Mount U.FL/MHF1 Jack 50 Ohm PCB Surface Mount Conn UFL MHF Straight PCB Mount Jack U.FL/MHF1 Jack 50 Ohm PCB Surface Mount Customers Also Bought  For support call+1 800 522 6752 01/02/2024 11:46PM | Page 2 ANT-GNCP-C257L160 Patch Antenna, Multi Band, GNSS / GPS, Internal/Embedded Mount, Adhesive, MHF / U.FL / UMCC, Directional, Single Port, Gain > 6 dBi TE Part #440146-4 TE Part #1734598-4 TE Part #L9000173-01 TE Part #ANT-GNCP-C25L15100 1.25mm WTB Socket,Housing,4p AMP HPI 1.25 mm Headers Antenna GNSS L1L2L5 25x25 LNA 1.13 UFL Antenna GNSS L1L5 25x25 LNA 1.13 UFL TE Part #440146-5 TE Part #440146-8 TE Part #RXM-GPS-RM-T 1.25mm WTB Socket,Housing,5p 1.25mm WTB Socket,Housing,8p Module RM L1 GPS RX RCVR T&R Documents Product Drawings Antenna GNSS L1 25x25 LNA 1.13 UFL English Datasheets & Catalog Pages VHETH Antenna Series Ground Plane Optimization English Sub-6 Cellular LTE-5G NR Frequency Band Guide English Considerations for Operation within the 260-470MHz Band English Understanding Antenna Specifications and Operation English Antennas Design, Application and Performance English The FCC Road Part 15 From Concept to Approval English RF 101 Information for the RF Challenged English Virtual Antenna English Microsplatch Ground Plane Optimization English L1 Active Ceramic Patch GNSS Antenna English  For support call+1 800 522 6752 01/02/2024 11:46PM | Page 3 ANT-GNCP-C257L160 Patch Antenna, Multi Band, GNSS / GPS, Internal/Embedded Mount, Adhesive, MHF / U.FL / UMCC, Directional, Single Port, Gain > 6 dBi  For support call+1 800 522 6752 01/02/2024 11:46PM | Page 4
ANT-GNCP-C257L160 价格&库存
很抱歉,暂时无法提供与“ANT-GNCP-C257L160”相匹配的价格&库存,您可以联系我们找货
