ANT-W63-SPNF1
ANT-W63-SPNF1
    LINXTECHNOLOGIES(灵思)
    2.45GHz,5.5225GHz,6.5375GHz 802.11b/g/n/c/ax,蓝牙,ISM,U-NII,Wi-Fi 4,Wi-Fi 5,Wi-Fi 6,Wi-Fi 6E,Zigbee 圆顶...
ANT-W63-SPNF1 数据手册
ANT-W63-SPNF1 Dome/Puck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi ANT-W63-SPNF1  ACTIVE TE Internal #: ANT-W63-SPNF1 Dome/Puck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi View on TE.com > Antennas Wireless Application: Vehicular, Wi-Fi Mounting Location: External Mounting Type: Connector Antenna Termination: N-type Antenna Type: Dome/Puck Features Product Type Features Antenna Termination N-type Configuration Features Mounting Location External Antenna Type Dome/Puck Band Type Triple Band Port Configuration Single Port Signal Characteristics Nominal Frequency Range 2400 – 7125 Peak Gain > 6 dBi Mechanical Attachment Mounting Type Connector Operation/Application Directionality Omnidirectional Industry Standards Wireless Application Vehicular, Wi-Fi Primary Application Wi-Fi Product Compliance For compliance documentation, visit the product page on TE.com>  For support call+1 800 522 6752 01/02/2024 11:48PM | Page 1 ANT-W63-SPNF1 Dome/Puck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # CONN001-W TE Part # CONN002-W TE Part # CONN003-W TE Part # CONN007-1-W N Type Jack 50 Ohm PCB Through Hole N Type Jack 50 Ohm Panel Mount N Type Jack 50 Ohm Panel Mount N Type Plug 50 Ohm Cable Crimp TE Part # CONN007-2-W TE Part # CONN007-3-W TE Part # CONN007-4-W TE Part # CONN008-W N Type Plug 50 Ohm Cable Crimp N Type Plug 50 Ohm Cable Crimp N Type Plug 50 Ohm Cable Crimp N Type Plug 50 Ohm Panel Mount Crimp Customers Also Bought  For support call+1 800 522 6752 01/02/2024 11:48PM | Page 2 ANT-W63-SPNF1 Dome/Puck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi Customers Also Bought TE Part #5205980-5 TE Part #L9000021-01 TE Part #L9000023-01 TE Part #ANT-868-CW-QW SCREW RETAINER KIT,BULK PACK Antenna 1/2 Wave Whip 2.4GHz SMA Antenna 1/2 Wave Whip 2.4GHz RPS Antenna 1/4 Wave Whip 868MHz TE Part #ANT-868-CW-QW-SMA TE Part #ANT-916-CW-QW TE Part #ANT-DB1-WRT-RPS TE Part #ANT-LTE-WS-SMA Antenna 1/4 Wave Whip 868MHz SMA Antenna 1/4 Wave Whip 916MHz Antenna Dome WiFi6 2.4/5.8GHz Antenna Blade NBIOT LTE-M Swivel RG174 RPS SMA TE Part #B8965C TE Part #RJ45-ECS WHIP,MC,CC,896-970MHz TUN,5,CH, RJ45,ECS,12in GP, Documents Product Drawings Antenna WiFi6/6E Dome N Jack English Antenna WiFi6/6E Dome N Jack English Datasheets & Catalog Pages VHETH Antenna Series Ground Plane Optimization English Sub-6 Cellular LTE-5G NR Frequency Band Guide English Considerations for Operation within the 260-470MHz Band English Understanding Antenna Specifications and Operation English Antennas Design, Application and Performance English Antenna Color Codes  English For support call+1 800 522 6752 01/02/2024 11:48PM | Page 3 ANT-W63-SPNF1 Dome/Puck Antenna, Triple Band, Wi-Fi, External Mount, Connector, N-type, Omnidirectional, Single Port, Gain > 6 dBi Antenna Color Codes English The FCC Road Part 15 From Concept to Approval English RF 101 Information for the RF Challenged English Virtual Antenna English Microsplatch Ground Plane Optimization English Panel Mount WiFi 6/6E Antenna English  For support call+1 800 522 6752 01/02/2024 11:48PM | Page 4
ANT-W63-SPNF1 价格&库存
很抱歉,暂时无法提供与“ANT-W63-SPNF1”相匹配的价格&库存,您可以联系我们找货
ANT-W63-SPNF1
    • 1+438.60960
    • 200+175.01400
    • 500+169.16040
    • 1000+166.27680
