CSG-UFFR-100-UFFR
CSG-UFFR-100-UFFR
    LINXTECHNOLOGIES(灵思)
    同轴电缆组件 U.FL(UMCC)转 U.FL(UMCC) 1.37mm OD 外径同轴缆线 3.940"(100.08mm)
CSG-UFFR-100-UFFR 数据手册
CSG-UFFR-100-UFFR .328 ft [.1 m], 6 GHz Operating Frequency, 50 Ω, UMCC Plug, UMCC Plug CSG-UFFR-100-UFFR  ACTIVE TE Internal #: CSG-UFFR-100-UFFR .328 ft [.1 m], 6 GHz Operating Frequency, 50 Ω, UMCC Plug, UMCC Plug View on TE.com > Cable Assemblies > RF Cable Assemblies Connector Type (End A): UMCC Plug Cable Assembly Length: .1 m [ .328 ft ] Connector Type (End B): UMCC Plug Impedance: 50 Ω Operating Frequency: 6 GHz Features Product Type Features Coax Cable Type 1.37 mm Connector Type (End A) UMCC Plug Connector Type (End B) UMCC Plug Configuration Features Number of Connectorized Ends 2 Electrical Characteristics Impedance 50 Ω Body Features Body Plating Material Gold Contact Features Center Contact Plating Gold Operation/Application Operating Frequency 6 GHz Other Cable Assembly Length .1 m[.328 ft] Product Compliance For compliance documentation, visit the product page on TE.com>  EU800 RoHS Directive 2011/65/EU For support call+1 522 6752 Compliant with Exemptions 01/03/2024 12:01AM | Page 1 CSG-UFFR-100-UFFR .328 ft [.1 m], 6 GHz Operating Frequency, 50 Ω, UMCC Plug, UMCC Plug EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) SVHC > Threshold: Pb (3.9% in Component Part) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Low Bromine/Chlorine - Br and Cl < 900 ppm per homogenous material. Also BFR /CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # CONMHF1-SMD-G-T TE Part # CONMHF1-SMD-T TE Part # CONUFL001-SMD TE Part # CONUFL001-SMD-T U.FL/MHF1 Jack 50 Ohm PCB Surface Mount U.FL/MHF1 Jack 50 Ohm PCB Surface Mount Conn UFL MHF Straight PCB Mount Jack U.FL/MHF1 Jack 50 Ohm PCB Surface Mount Customers Also Bought  For support call+1 800 522 6752 01/03/2024 12:01AM | Page 2 CSG-UFFR-100-UFFR .328 ft [.1 m], 6 GHz Operating Frequency, 50 Ω, UMCC Plug, UMCC Plug TE Part #1-1825002-7 TE Part #2301994-1 TE Part #2316102-3 TE Part #20009605-48 ADF1004=DIP SWT,FLUSH,THRU/HL RJ45 JACK INT.MAG. 10/100 1X1 INV. 3P,2MM,REC,HSG,SR,CRIMP,PLAIN, BOX Compact Compression Load Cell TE Part #ADP-SMAM-UFLF TE Part #CSH-SGFB-100-UFFR TE Part #4-2176477-3 TE Part #7-1768423-3 SMA Plug to U.FL/MHF1 Jack SMA to U.FL/MHF1 100mm 1.32 OD RA73F 2A 1K5 0.1% 1K RL LBG-U-03512/EETM TE Part #9-1768415-6 LBG-U-03290/EET2067 Documents Product Drawings U.FL/MHF1 to U.FL/MHF1 100mm 1.37 OD English Datasheets & Catalog Pages The FCC Road Part 15 From Concept to Approval English RF Coaxial Connector Gender Naming English RF 101 Information for the RF Challenged English U.FL Plug to U.FL Plug Cable Assembly English  For support call+1 800 522 6752 01/03/2024 12:01AM | Page 3
CSG-UFFR-100-UFFR 价格&库存
很抱歉,暂时无法提供与“CSG-UFFR-100-UFFR”相匹配的价格&库存,您可以联系我们找货
CSG-UFFR-100-UFFR
  • 1+51.92340
  • 10+47.78910
  • 25+42.14480
库存:214
