CSJ-RGFB-200-MHF4
CSJ-RGFB-200-MHF4
    LINXTECHNOLOGIES(灵思)
    同轴电缆组件 RP-SMA 至 IPEX MHF4 0.81mm OD 外径同轴缆线 7.874"(200.00mm)
CSJ-RGFB-200-MHF4 数据手册
CSJ-RGFB-200-MHF4 RP-SMA to MHF4 Cable Assembly, .66 ft [.2 m], Black Cable, 6 GHz Operating Frequency, 50 Ω, PFA, 34 AWG, .031 in [.81 mm] Diameter, RP SMA Plug CSJ-RGFB-200-MHF4  ACTIVE TE Internal #: CSJ-RGFB-200-MHF4 RP-SMA to MHF4 Cable Assembly, .66 ft [.2 m], Black Cable, 6 GHz Operating Frequency, 50 Ω, PFA, 34 AWG, .031 in [.81 mm] Diameter, RP SMA Plug View on TE.com > Cable Assemblies > RF Cable Assemblies Connector Type (End A): RP SMA Plug Jacket Material: PFA Cable Assembly Length: .2 m [ .66 ft ] Cable Color: Black Operating Temperature Range: -40 – 90 °C [ -40 – 194 °F ] Features Product Type Features Coax Cable Type .81 mm Connector Type (End A) RP SMA Plug Connector Type (End B) MHF4 Plug Cable Assembly Type RP-SMA to MHF4 Configuration Features Number of Connectorized Ends 2 Electrical Characteristics Impedance 50 Ω Body Features Body Plating Material Gold Jacket Material PFA Cable Color Black Contact Features Center Contact Plating Gold Dimensions  Wire Size 34 AWG Outside Cable Diameter .81 mm[.031 in] Usage Conditions For support call+1 800 522 6752 01/03/2024 12:03AM | Page 1 CSJ-RGFB-200-MHF4 RP-SMA to MHF4 Cable Assembly, .66 ft [.2 m], Black Cable, 6 GHz Operating Frequency, 50 Ω, PFA, 34 AWG, .031 in [.81 mm] Diameter, RP SMA Plug Usage Conditions Operating Temperature Range -40 – 90 °C[-40 – 194 °F] Operation/Application Shielded Yes Operating Frequency 6 GHz Other Dielectric Material FEP Cable Assembly Length .2 m[.66 ft] Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  For support call+1 800 522 6752 01/03/2024 12:03AM | Page 2 CSJ-RGFB-200-MHF4 RP-SMA to MHF4 Cable Assembly, .66 ft [.2 m], Black Cable, 6 GHz Operating Frequency, 50 Ω, PFA, 34 AWG, .031 in [.81 mm] Diameter, RP SMA Plug Compatible Parts TE Part # CONMHF4-SMD-G-T TE Part # CONREVSMA007 TE Part # CONREVSMA007-G TE Part # CONREVSMA011 MHF4 Jack 50 Ohm PCB Surface Mount RP-SMA Plug 50 Ohm Cable Crimp RP-SMA Plug 50 Ohm Cable Crimp RP-SMA Jack 50 Ohm PCB Cable Crimp TE Part # CONREVSMA012-G RP-SMA RA Plug 50 Ohm PCB Cable Crimp Customers Also Bought TE Part #2273009-3 TE Part #DT13-6P-G003 TE Part #TAA754A5501-001 TE Part #165167-1 M8 x 1.0 Angled socket Pigtail HDR, 6P, GRY, RA, AU/NI/CU M12A5-FR-PUR-0.5M PG WIREPIN RED LONG TE Part #G-NSDOG2-021 TE Part #ANT-W63WS1-RPS TE Part #ANT-W63WS4-RPS TE Part #CSJ-RGFB-100-MHF4 AXISENSE-2 USB-90 TILT SENSOR Antenna Blade Wifi6/6E Swivel RPS Antenna Blade Wifi6 Swivel RPS RP-SMA to MHF4 100mm 0.81 OD Documents Product Drawings RP-SMA to MHF4 200mm 0.81 OD English Datasheets & Catalog Pages CBL ASSEMBLY, MHF4 TO FEM BLKHD RP-SMA, 0.81mm CBL English Standard vs. Reverse Polarity (RP) SMA Connectors English  The FCC Road Part 15 From Concept to Approval For support call+1 800 522 6752 01/03/2024 12:03AM | Page 3 CSJ-RGFB-200-MHF4 RP-SMA to MHF4 Cable Assembly, .66 ft [.2 m], Black Cable, 6 GHz Operating Frequency, 50 Ω, PFA, 34 AWG, .031 in [.81 mm] Diameter, RP SMA Plug The FCC Road Part 15 From Concept to Approval English RF Coaxial Connector Gender Naming English RF 101 Information for the RF Challenged English  For support call+1 800 522 6752 01/03/2024 12:03AM | Page 4
CSJ-RGFB-200-MHF4 价格&库存
很抱歉,暂时无法提供与“CSJ-RGFB-200-MHF4”相匹配的价格&库存,您可以联系我们找货
