HUM-A-900-PRO-UFL
HUM-A-900-PRO-UFL
    LINXTECHNOLOGIES(灵思)
    SMD44模块
    通用 ISM < 1GHz 专有 RF 收发器模块 902MHz ~ 928MHz 不含天线,U.FL 表面贴装型
HUM-A-900-PRO-UFL 数据手册
HUM-A-900-PRO-UFL Module HUM-PRO-A 900MHz FHSS FM XCVR FCC HUM-A-900-PRO-UFL  ACTIVE TE Internal #: HUM-A-900-PRO-UFL TE Internal Description: Module HUM-PRO-A 900MHz FHSS FM XCVR FCC View on TE.com > Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  For support call+1 800 522 6752 01/03/2024 12:21AM | Page 1 HUM-A-900-PRO-UFL Module HUM-PRO-A 900MHz FHSS FM XCVR FCC TE Part # EVM-A-900-PRO-UFL TE Part # MDEV-900-PRC TE Part # MDEV-DEMO-RC-A TE Part # MDEV-DEMO-RC-B EVAL-MODULE HUM-PRO-A UFL FHSS XCVR UFL DEV-KIT HUM-PRC 900MHZ FHSS DEVELOPMENT DEV-KIT HUM REMOTE CONTROL EVAL SIDE-A DEV-KIT HUM REMOTE CONTROL EVAL SIDE-B TE Part # MDEV-PGDOCK TE Part # MDEV-PROTO TE Part # OTX-900-HH-LR8-PRC DEV-KIT HUM PGDOCK DEV-KIT HUM PROTO PROTOTYPE Remote HUM-PRC 900MHz FHSS 8Btn PROGRAMMING DOCK BOARD XCVR FCC Customers Also Bought TE Part #796636-4 TE Part #796634-4 TE Part #796638-4 TE Part #5645235-4 4POS 5.08MM CE VRT HDR,TRM BLK 4 POS 5.08MM R/A PLUG,TRM BLK 4POS 5.08MM CE R/A HDR,TRM BLK CONN SEC II 18 POS 100C/L TE Part #20005836-01 TE Part #L9000068-01 TE Part #ANT-916-CW-HW TE Part #ANT-916-OC-LG-SMA 820M1-0025 Uniaxial 25g Tray 50pcs Antenna 2.4 FPC SH 25x20 100 UFL Antenna 1/2 Wave Dipole Whip 916MHz RPS Antenna Whip Coil 916MHz Swivel SMA TE Part #HUM-A-900-PRO-CAS TE Part #OTX-433-HH-KF5-MS Module HUM-PRO-A 900MHz FHSS FM XCVR FCC Remote MS 433MHz OOK AM 5Btn KF TX EU Documents  Product Drawings For support call+1 800 522 6752 01/03/2024 12:21AM | Page 2 HUM-A-900-PRO-UFL Module HUM-PRO-A 900MHz FHSS FM XCVR FCC Product Drawings Module HUM-PRO-A 900MHz FHSS FM XCVR FCC English Datasheets & Catalog Pages Modulation Techniques for Low-Cost RF Data Links English Considerations for Operation within the 260-470MHz Band English Data and Bidirectional Transmissions under Part 15.231 English Considerations for Sending Data Over a Wireless Link English Considerations for Operation within the 902-928MHz Band English Use and Design of T-Attenuation Pads English The FCC Road Part 15 From Concept to Approval English Addressing Linx OEM Product English Encoder and Decoder Comparison English RF 101 Information for the RF Challenged English Amplified HumPRO TM Series 900MHz RF Transceiver Module English  For support call+1 800 522 6752 01/03/2024 12:21AM | Page 3
HUM-A-900-PRO-UFL 价格&库存
很抱歉,暂时无法提供与“HUM-A-900-PRO-UFL”相匹配的价格&库存,您可以联系我们找货
