ANT-2.4-FPC-SF100UF
ANT-2.4-FPC-SF100UF
    LINXTECHNOLOGIES(灵思)
    2.45GHz 蓝牙,ISM,Wi-Fi,Zigbee™ PCB 印制线 RF 天线 2.4GHz ~ 2.5GHz 3.9dBi IPEX MHF1(U.FL) 胶合剂
ANT-2.4-FPC-SF100UF 数据手册
ANT-2.4-FPC-SF100UF Flexible PCB (FPC) Antenna, Single Band, Bluetooth / ISM / Zigbee, Internal /Embedded Mount, Adhesive, MHF / MHF1 / U.FL, Omnidirectional, Single Port ANT-2.4-FPC-SF100UF  ACTIVE TE Internal #: L9000060-01 Flexible PCB (FPC) Antenna, Single Band, Bluetooth / ISM / Zigbee, Internal/Embedded Mount, Adhesive, MHF / MHF1 / U.FL, Omnidirectional, Single Port View on TE.com > Antennas Wireless Application: Bluetooth, ISM, Zigbee Mounting Location: Internal/Embedded Mounting Type: Adhesive Antenna Termination: MHF, MHF1, U.FL, UMCC Antenna Type: Flexible PCB (FPC) Features Product Type Features Antenna Termination MHF, MHF1, U.FL, UMCC Configuration Features Mounting Location Internal/Embedded Antenna Type Flexible PCB (FPC) Band Type Single Band Port Configuration Single Port Signal Characteristics Nominal Frequency Range 2400 – 2500 Peak Gain 3 < 6 dBi Mechanical Attachment Mounting Type Adhesive Operation/Application Directionality Omnidirectional Industry Standards  Wireless Application Bluetooth, ISM, Zigbee Primary Application Bluetooth, ISM, Zigbee Product Compliance For support call+1 800 522 6752 01/03/2024 12:24AM | Page 1 ANT-2.4-FPC-SF100UF Flexible PCB (FPC) Antenna, Single Band, Bluetooth / ISM / Zigbee, Internal /Embedded Mount, Adhesive, MHF / MHF1 / U.FL, Omnidirectional, Single Port Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # CONMHF1-SMD-G-T TE Part # CONMHF1-SMD-T TE Part # CONUFL001-SMD TE Part # CONUFL001-SMD-T U.FL/MHF1 Jack 50 Ohm PCB Surface Mount U.FL/MHF1 Jack 50 Ohm PCB Surface Mount Conn UFL MHF Straight PCB Mount Jack U.FL/MHF1 Jack 50 Ohm PCB Surface Mount Customers Also Bought  For support call+1 800 522 6752 01/03/2024 12:24AM | Page 2 ANT-2.4-FPC-SF100UF Flexible PCB (FPC) Antenna, Single Band, Bluetooth / ISM / Zigbee, Internal /Embedded Mount, Adhesive, MHF / MHF1 / U.FL, Omnidirectional, Single Port TE Part #2199337-5 TE Part #1-1747981-5 TE Part #D61414-000 TE Part #254154-E ASS'Y FOR MICRO SIM H1.18 8POS (EMBOSS) Std HDMI, RA, SMT, Panel grd, Flange B-155-1501 MRDEZT M08 GEHAEUSETEIL FL ABST. 9MM * * TE Part #254737-E TE Part #284074-E TE Part #394863-E TE Part #L9000037-01 MRDEZT M12 GEH.TEIL ML DM 8,35 MRDEZT M08 GEHAEUSETEIL ML MRDEZT M12 GEH.TEIL ML DM 9,55 Antenna 2.4 FPC LH 45x7 100 UFL A=9MM * * ABST. 13MM * A=13MM * TE Part #L9000068-01 TE Part #1759503-1 Antenna 2.4 FPC SH 25x20 100 UFL mini PCI-E 8H Type I PKG G/F Documents Product Drawings Antenna 2.4 FPC SF 25x20 100 UFL English Datasheets & Catalog Pages Flexible Embedded 2.4 GHz FPC Antennas English  For support call+1 800 522 6752 01/03/2024 12:24AM | Page 3
ANT-2.4-FPC-SF100UF 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-FPC-SF100UF”相匹配的价格&库存,您可以联系我们找货
