Sample &
Buy
Product
Folder
Support &
Community
Tools &
Software
Technical
Documents
ADS4229
SBAS550C – JUNE 2011 – REVISED MAY 2015
ADS4229 Dual-Channel, 12-Bit, 250-MSPS Ultralow-Power ADC
1 Features
3 Description
The ADS4229 is a member of the ADS42xx ultralowpower family of dual-channel, 12-bit and 14-bit
analog-to-digital converters (ADCs). Innovative
design techniques are used to achieve high dynamic
performance, while consuming extremely low power
with a 1.8-V supply. This topology makes the
ADS4229 well-suited for multi-carrier, wide-bandwidth
communications applications.
1
Maximum Sample Rate: 250 MSPS
Ultralow Power with Single 1.8-V Supply:
– 545-mW Total Power at 250 MSPS
High Dynamic Performance:
– 80.8-dBc SFDR at 170 MHz
– 69.4-dBFS SNR at 170 MHz
Crosstalk: > 90 dB at 185 MHz
Programmable Gain Up to 6 dB for
SNR and SFDR Trade-off
DC Offset Correction
Output Interface Options:
– 1.8-V Parallel CMOS Interface
– DDR LVDS With Programmable Swing:
– Standard Swing: 350 mV
– Low Swing: 200 mV
Supports Low Input Clock Amplitude
Down to 200 mVPP
Package: 9-mm × 9-mm, 64-Pin Quad Flat
No-Lead (QFN) Package
The ADS4229 has gain options that can be used to
improve spurious-free dynamic range (SFDR)
performance at lower full-scale input ranges. This
device also includes a dc offset correction loop that
can be used to cancel the ADC offset. Both double
data rate (DDR) low-voltage differential signaling
(LVDS) and parallel complementary metal oxide
semiconductor (CMOS) digital output interfaces are
available in a compact QFN-64 PowerPAD™
package.
The device includes internal references while the
traditional reference pins and associated decoupling
capacitors have been eliminated. The ADS4229 is
specified over the industrial temperature range
(–40°C to +85°C).
Device Information(1)
2 Applications
Wireless Communications Infrastructure
Software Defined Radio
Power Amplifier Linearization
PART NUMBER
ADS4229
PACKAGE
VQFN (64)
BODY SIZE (NOM)
9.00 mm × 9.00 mm
(1) For all available packages, see the orderable addendum at
the end of the datasheet.
ADS4229 Block Diagram
ADS4229
INP_A
INM_A
LVDS
DA0P
DA0M
Sampling
Circuit
DA12P
DA12M
CLKP
CLK
Gen
CLKM
INP_B
INM_B
VCM
12-bit ADC
CLKOUTP
CLKOUTM
DB0P
DB0M
Sampling
Circuit
12-bit ADC
DB12P
DB12M
Reference
1
An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications,
intellectual property matters and other important disclaimers. PRODUCTION DATA.
ADS4229
www.ti.com
Table of Contents
1
2
3
4
5
6
7
Features ..................................................................
Applications ...........................................................
Description .............................................................
Revision History.....................................................
Device Comparison Table.....................................
Pin Configuration and Functions .........................
Specifications.........................................................
1
1
1
2
4
5
9
7.1
7.2
7.3
7.4
7.5
7.6
7.7
7.8
7.9
7.10
7.11
7.12
Absolute Maximum Ratings ...................................... 9
ESD Ratings.............................................................. 9
Recommended Operating Conditions....................... 9
Thermal Information ................................................ 10
Electrical Characteristics: ADS4229 (250 MSPS)... 10
Electrical Characteristics: General .......................... 12
Digital Characteristics ............................................. 13
LVDS and CMOS Modes Timing Requirements..... 14
LVDS Timings at Lower Sampling Frequencies ..... 15
CMOS Timings at Lower Sampling Frequencies .. 15
Serial Interface Timing Characteristics ................. 17
Reset Timing (Only when Serial Interface is
Used)........................................................................ 18
7.13 Typical Characteristics .......................................... 19
8
Detailed Description ............................................ 26
8.1 Overview ................................................................. 26
8.2
8.3
8.4
8.5
8.6
9
Functional Block Diagram .......................................
Feature Description.................................................
Device Functional Modes........................................
Programming...........................................................
Register Maps .........................................................
26
27
29
33
37
Application and Implementation ........................ 47
9.1 Application Information............................................ 47
9.2 Typical Application ................................................. 53
10 Power Supply Recommendations ..................... 55
10.1 Sharing DRVDD and AVDD Supplies ................... 55
10.2 Using DC/DC Power Supplies .............................. 55
10.3 Power Supply Bypassing ...................................... 55
11 Layout................................................................... 55
11.1 Layout Guidelines ................................................. 55
11.2 Layout Example .................................................... 56
12 Device and Documentation Support ................. 57
12.1
12.2
12.3
12.4
12.5
12.6
Device Support......................................................
Documentation Support ........................................
Community Resources..........................................
Trademarks ...........................................................
Electrostatic Discharge Caution ............................
Glossary ................................................................
57
58
59
59
59
59
13 Mechanical, Packaging, and Orderable
Information ........................................................... 59
4 Revision History
NOTE: Page numbers for previous revisions may differ from page numbers in the current version.
Changes from Revision B (August 2012) to Revision C
Page
Added Pin Configuration and Functions section, ESD Rating table, Feature Description section, Device Functional
Modes, Application and Implementation section, Power Supply Recommendations section, Layout section, Device
and Documentation Support section, and Mechanical, Packaging, and Orderable Information section .............................. 1
Changes from Revision A (October 2011) to Revision B
Page
Changed first sub-bullet of High Dynamic Performance Features bullet ............................................................................... 1
Changed footnote 1 in CMOS Timings at Lower Sampling Frequencies............................................................................. 15
Changed row D5 and consolidated the two DB rows in Table 10........................................................................................ 37
Changed Register Address D5h........................................................................................................................................... 46
Changed title of Register Address DBh, consolidated two DBh registers into one.............................................................. 46
Changes from Original (June 2011) to Revision A
Page
Changed ADS4229 Input Common-Mode Voltage parameter in Table 1 .............................................................................. 4
Changed AC power-supply rejection ratio parameter test condition in ADS4229 Electrical Characteristics table .............. 11
Updated Figure 3.................................................................................................................................................................. 16
Updated Figure 25................................................................................................................................................................ 22
Updated Figure 31................................................................................................................................................................ 23
Updated Figure 32................................................................................................................................................................ 23
Changed Time Constant, TCCLK × 1/fS (ms) column and footnote 1 in Table 3 ................................................................... 28
2
Submit Documentation Feedback
Copyright © 2011–2015, Texas Instruments Incorporated
Product Folder Links: ADS4229
ADS4229
www.ti.com
Changed Revised Channel Standby section ........................................................................................................................ 28
Changed High-performance mode parameter description in High-Performance Modes table ............................................ 33
Changed description of bits[7:2] in Register Address 40h ................................................................................................... 41
Updated Register Address D7h and Register Address D8h tables...................................................................................... 46
Updated first paragraph of Analog Input section .................................................................................................................. 48
Updated first paragraph of Driving Circuit subsection .......................................................................................................... 49
3
ADS4229
www.ti.com
5 Device Comparison Table
(1)
65 MSPS
125 MSPS
160 MSPS
250 MSPS
ADS422x
12-bit family (1)
ADS4222
ADS4225
ADS4226
ADS4229
ADS424x
14-bit family (1)
ADS4242
ADS4245
ADS4246
ADS4249
See Table 1 for details on migrating from the ADS62P49 family.
The ADS4229 is pin-compatible with the previous generation ADS62P49 data converter; this similar architecture
enables easy migration. However, there are some important differences between the two device generations,
summarized in Table 1.
Table 1. Migrating from the ADS62P49
ADS62P49 FAMILY
ADS4229
PINS
Pin 22 is NC (not connected)
Pin 22 is AVDD
Pins 38 and 58 are DRVDD
Pins 38 and 58 are NC (do not connect, must be floated)
Pins 39 and 59 are DRGND
Pins 39 and 59 are NC (do not connect, must be floated)
SUPPLY
AVDD is 3.3 V
AVDD is 1.9 V
DRVDD is 1.8 V
No change
INPUT COMMON-MODE VOLTAGE
VCM is 1.5 V
VCM is 0.95 V
SERIAL INTERFACE
Protocol: 8-bit register address and 8-bit register data
No change in protocol
New serial register map
EXTERNAL REFERENCE
Supported
4
Not supported
ADS4229
www.ti.com
6 Pin Configuration and Functions
DA0P
42
DA0M
DB8M
8
41
NC
40
NC
DB10M 10
39
NC
DB10P 11
38
NC
RESET 12
37
CTRL3
SCLK 13
36
CTRL2
SDATA 14
35
CTRL1
50 DA6
49 DRGND
52 DA8
51 DA7
54 DA10
53 DA9
56 UNUSED
55 DA11
58 NC
57 CLKOUT
60 NC
59 NC
62 DB0
6
43
DA1
DB7
7
42
DA0
DB8
8
41
NC
DB9
9
40
NC
DB10 10
39
NC
DB11 11
38
NC
RESET 12
37
CTRL3
SCLK 13
36
CTRL2
SDATA 14
35
CTRL1
SEN 15
34
AVDD
AVDD 16
33
AVDD
Thermal Pad
(Connected to DRGND)
AGND 17
AGND 31
DA2
DB6
AGND 32
INP_A 29
INM_A 30
AGND 27
AGND 28
CLKP 25
CLKM 26
VCM 23
AGND 24
AVDD 22
AGND 21
INP_B 19
AVDD 16
AVDD
INM_B 20
AVDD
33
AGND 17
34
AGND 18
SEN 15
(1)
44
AGND 31
43
7
9
5
AGND 32
6
DB6P
DB8P
DA3
DB5
DA2M
DB6M
Thermal Pad
45
INP_A 29
44
5
4
INM_A 30
DB4P
DA4
DB4
AGND 27
DA2P
AGND 28
45
46
CLKP 25
4
3
CLKM 26
DB4M
DA5
DB3
VCM 23
DA4M
AGND 24
DA4P
46
DRVDD
47
AVDD 22
47
3
48
2
AGND 21
2
DB2P
1
DB2
INP_B 19
DB2M
DRVDD
INM_B 20
DRVDD
61 NC
64 SDOUT
48
1
63 DB1
50 DA6M
49 DRGND
52 DA8M
51 DA6P
54 DA10M
53 DA8P
56 CLKOUTM
55 DA10P
58 NC
57 CLKOUTP
60 NC
59 NC
62 DB0M
61 NC
RGC Package (CMOS Mode)
64-Pin VQFN
Top View
AGND 18
DRVDD
63 DB0P
64 SDOUT
RGC Package (LVDS Mode)
64-Pin VQFN
Top View
The PowerPAD is connected to DRGND.
NOTE: NC = do not connect; must float.
Pin Functions (LVDS Mode)
PIN
NAME
NO.
I/O
DESCRIPTION
17
18
21
AGND
24
27
I
Analog ground
I
Analog power supply
28
31
32
16
AVDD
22
23
34
CLKM
26
I
Differential clock negative input
CLKP
25
I
Differential clock positive input
CTRL1
35
I
Digital control input pins. Together, they control the various power-down
modes.
CTRL2
36
I
modes.
CTRL3
37
I
modes.
CLKOUTP
57
O
Differential output clock, true
5
ADS4229
www.ti.com
Pin Functions (LVDS Mode) (continued)
PIN
NAME
NO.
CLKOUTM
56
DA0M
42
DA0P
43
DA2M
44
DA2P
45
DA4M
46
DA4P
47
DA6M
50
DA6P
51
DA8M
52
DA8P
53
DA10M
54
DA10P
55
DB0M
62
DB0P
63
DB2M
2
DB2P
3
DB4M
4
DB4P
5
DB6M
6
DB6P
7
DB8M
8
DB8P
9
DB10M
10
DB10P
11
DRGND
DRVDD
49
PAD
1
48
I/O
DESCRIPTION
O
Differential output clock, complement
O
Channel A differential output data pair, D0 and D1 multiplexed
O
Channel A differential output data D2 and D3 multiplexed
O
Channel A differential output data D4 and D5 multiplexed
O
Channel A differential output data D6 and D7 multiplexed
O
Channel A differential output data D8 and D9 multiplexed
O
Channel A differential output data D10 and D11 multiplexed
O
Channel B differential output data pair, D0 and D1 multiplexed
O
Channel B differential output data D2 and D3 multiplexed
O
Channel B differential output data D4 and D5 multiplexed
O
Channel B differential output data D6 and D7 multiplexed
O
Channel B differential output data D8 and D9 multiplexed
O
Channel B differential output data D10 and D11 multiplexed
I
Output buffer ground
I
Output buffer supply
INP_A
29
I
Differential analog positive input, channel A
INM_A
30
I
Differential analog negative input, channel A
INP_B
19
I
Differential analog positive input, channel B
INM_B
I
Differential analog negative input, channel B
38
39
40
NC
41
58
Do not connect, must be floated
59
60
61
RESET
6
12
I
Serial interface RESET input.
When using the serial interface mode, the internal registers must be initialized
through a hardware RESET by applying a high pulse on this pin or by using the
software reset option; refer to the Serial Interface Configuration section.
In parallel interface mode, the RESET pin must be permanently tied high.
SCLK and SEN are used as parallel control pins in this mode. This pin has an
internal 150-kΩ pull-down resistor.
ADS4229
www.ti.com
PIN
I/O
DESCRIPTION
NAME
NO.
SCLK
13
I
This pin functions as a serial interface clock input when RESET is low. It
controls the low-speed mode selection when RESET is tied high; see Table 7
for detailed information. This pin has an internal 150-kΩ pull-down resistor.
SDATA
14
I
Serial interface data input; this pin has an internal 150-kΩ pull-down resistor.
SDOUT
64
O
This pin functions as a serial interface register readout when the READOUT bit
is enabled. When READOUT = 0, this pin is put into a high-impedance state.
VCM
23
O
This pin outputs the common-mode voltage (0.95 V) that can be used
externally to bias the analog input pins
Pin Functions (CMOS Mode)
PIN
NAME
NO.
I/O
DESCRIPTION
17
18
21
AGND
24
27
I
Analog ground
I
Analog power supply
28
31
32
16
AVDD
22
33
34
CLKM
26
I
CLKOUT
57
O
CMOS output clock
CLKP
25
I
CTRL1
35
I
Digital control input pins. Together, they control various power-down modes.
CTRL2
36
I
CTRL3
37
I
DA0
42
DA1
43
DA2
44
DA3
45
DA4
46
DA5
47
DA6
50
O
Channel A ADC output data bits, CMOS levels
DA7
51
DA8
52
DA9
53
DA10
54
DA11
55
7
ADS4229
www.ti.com
Pin Functions (CMOS Mode) (continued)
PIN
NAME
NO.
DB0
62
DB1
63
DB2
2
DB3
3
DB4
4
DB5
5
DB6
6
DB7
7
DB8
8
DB9
9
DB10
10
DB11
11
DRGND
DRVDD
NC
49
PAD
1
48
I/O
DESCRIPTION
O
Channel B ADC output data bits, CMOS levels
I
I
RESET
12
I
In parallel interface mode, the RESET pin must be permanently tied high. SDATA
and SEN are used as parallel control pins in this mode. This pin has an internal
INM_A
30
I
INP_A
29
I
INM_B
I
INP_B
19
I
SCLK
13
I
This pin functions as a serial interface clock input when RESET is low. It controls
the low-speed mode when RESET is tied high; see Table 7 for detailed
SDATA
14
I
SDOUT
64
O
This pin functions as a serial interface register readout when the READOUT bit is
SEN
15
I
This pin functions as a serial interface enable input when RESET is low. It controls
the output interface and data format selection when RESET is tied high; see
Table 8 for detailed information. This pin has an internal 150-kΩ pull-up resistor to
AVDD.
VCM
23
O
This pin outputs the common-mode voltage (0.95 V) that can be used externally to
UNUSED
56
This pin is not used in the CMOS interface
8
ADS4229
www.ti.com
7 Specifications
7.1 Absolute Maximum Ratings (1)
MIN
MAX
UNIT
Supply voltage, AVDD
–0.3
2.1
V
Supply voltage, DRVDD
–0.3
2.1
V
Voltage between AGND and DRGND
–0.3
0.3
V
Voltage between AVDD to DRVDD (when AVDD leads DRVDD)
–2.4
2.4
V
Voltage between DRVDD to AVDD (when DRVDD leads AVDD)
–2.4
2.4
V
INP_A, INM_A, INP_B, INM_B
–0.3
Minimum
(1.9, AVDD + 0.3)
V
CLKP, CLKM (2)
–0.3
AVDD + 0.3
V
RESET, SCLK, SDATA, SEN,
CTRL1, CTRL2, CTRL3
–0.3
3.9
V
Voltage applied to input pins
Operating free-air temperature, TA
–40
Operating junction temperature, TJ
Storage temperature, Tstg
(1)
(2)
–65
85
°C
125
°C
150
°C
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings
only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended
Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
When AVDD is turned off, it is recommended to switch off the input clock (or ensure the voltage on CLKP, CLKM is less than |0.3 V|).
This configuration prevents the ESD protection diodes at the clock input pins from turning on.
7.2 ESD Ratings
V(ESD)
(1)
Electrostatic discharge
Human body model (HBM), per ANSI/ESDA/JEDEC JS-001 (1)
VALUE
UNIT
2000
V
JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process.
7.3 Recommended Operating Conditions
Over operating free-air temperature range, unless otherwise noted.
MIN
NOM
MAX
UNIT
Analog supply voltage, AVDD
1.7
1.8
1.9
V
Digital supply voltage, DRVDD
1.7
1.8
1.9
V
SUPPLIES
ANALOG INPUTS
Differential input voltage range
2
Input common-mode voltage
VPP
VCM ± 0.05
V
(1)
400
MHz
Maximum analog input frequency with 1-VPP input amplitude (1)
600
MHz
Maximum analog input frequency with 2-VPP input amplitude
CLOCK INPUT
Input clock sample rate
Low-speed mode enabled (2)
Low-speed mode disabled (2) (by default after reset)
Sine wave, ac-coupled
Input clock amplitude differential
(VCLKP – VCLKM)
1
80
MSPS
80
250
MSPS
1.5
VPP
LVPECL, ac-coupled
0.2
1.6
VPP
LVDS, ac-coupled
0.7
VPP
LVCMOS, single-ended, ac-coupled
1.5
V
Input clock duty cycle
35%
50%
65%
40%
50%
60%
(1)
(2)
See Theory of Operation
See Serial Interface Configuration for details on programming the low-speed mode.
9
ADS4229
www.ti.com
Recommended Operating Conditions (continued)
MIN
NOM
MAX
UNIT
DIGITAL OUTPUTS
Maximum external load capacitance from each output pin to DRGND, CLOAD
Differential load resistance between the LVDS output pairs (LVDS mode), RLOAD
5
pF
100
Ω
–40
+85
°C
7.4 Thermal Information
ADS4229
THERMAL METRIC
(1)
RGC (VQFN)
UNIT
64 PINS
RθJA
Junction-to-ambient thermal resistance
23.9
°C/W
RθJC(top)
Junction-to-case (top) thermal resistance
10.9
°C/W
RθJB
Junction-to-board thermal resistance
4.3
°C/W
ψJT
Junction-to-top characterization parameter
0.1
°C/W
ψJB
Junction-to-board characterization parameter
4.4
°C/W
RθJC(bot)
Junction-to-case (bottom) thermal resistance
0.6
°C/W
(1)
For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application
report, SPRA953.
7.5 Electrical Characteristics: ADS4229 (250 MSPS)
Typical values are at +25°C, AVDD = 1.8 V, DRVDD = 1.8 V, 50% clock duty cycle, –1 dBFS differential analog input, LVDS
interface, and 0-dB gain, unless otherwise noted. Minimum and maximum values are across the full temperature range:
TMIN = –40°C to TMAX = +85°C, AVDD = 1.8 V, and DRVDD = 1.8 V.
PARAMETER
TEST CONDITIONS
MIN
TYP
Resolution
Signal-to-noise ratio
12
SNR
dBFS
fIN = 70 MHz
70.3
dBFS
fIN = 100 MHz
70.1
dBFS
fIN = 170 MHz, 0-dB gain
69.8
dBFS
67.8
dBFS
65.5
68.2
dBFS
fIN = 20 MHz
70
dBFS
fIN = 70 MHz
69.7
dBFS
fIN = 100 MHz
69.8
dBFS
68.1
dBFS
67.5
dBFS
67.6
dBFS
fIN = 170 MHz, 3-dB gain
65
fIN = 300 MHz
Spurious-free dynamic
range
SFDR
fIN = 20 MHz
80
dBc
fIN = 70 MHz
79
dBc
fIN = 100 MHz
82
dBc
80
dBc
81
dBc
fIN = 300 MHz
77
dBc
fIN = 20 MHz
78
dBc
fIN = 70 MHz
77
dBc
fIN = 100 MHz
79
dBc
76
dBc
78
dBc
75
dBc
Total harmonic distortion
THD
fIN = 300 MHz
10
Bits
70.5
fIN = 300 MHz
SINAD
UNIT
fIN = 20 MHz
Signal-to-noise and
distortion ratio
MAX
71
69.5
ADS4229
www.ti.com
Electrical Characteristics: ADS4229 (250 MSPS) (continued)
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
fIN = 20 MHz
80
dBc
fIN = 70 MHz
79
dBc
fIN = 100 MHz
81
dBc
80
dBc
81
dBc
fIN = 300 MHz
76
dBc
fIN = 20 MHz
85
dBc
fIN = 70 MHz
87
dBc
fIN = 100 MHz
96
dBc
80
dBc
87
dBc
fIN = 300 MHz
84
dBc
fIN = 20 MHz
92
dBc
fIN = 70 MHz
95
dBc
fIN = 100 MHz
94
dBc
93
dBc
92
dBc
fIN = 300 MHz
89
dBc
f1 = 46 MHz, f2 = 50 MHz,
each tone at –7 dBFS
98
dBFS
f1 = 185 MHz, f2 = 190 MHz,
84
dBFS
Crosstalk
20-MHz full-scale signal on channel under observation;
170-MHz full-scale signal on other channel
95
dB
Input overload recovery
Recovery to within 1%
(of full-scale) for 6 dB overload with sine-wave input
1
Clock cycle
ratio
PSRR For 50-mVPP signal on AVDD supply, up to 10 MHz
30
dB
Effective number of bits
ENOB fIN = 170 MHz
Second-harmonic
distortion
HD2
Third-harmonic distortion
HD3
Worst spur
(other than second and third harmonics)
Two-tone intermodulation
distortion
IMD
Differential nonlinearity
DNL fIN = 170 MHz
Integrated nonlinearity
INL fIN = 170 MHz
71
71
77
11.15
–0.8
LSBs
±0.5
1.5
LSBs
±1.8
±4
LSBs
11
ADS4229
www.ti.com
7.6 Electrical Characteristics: General
Typical values are at +25°C, AVDD = 1.8 V, DRVDD = 1.8 V, 50% clock duty cycle, and –1 dBFS differential analog input,
unless otherwise noted. Minimum and maximum values are across the full temperature range: TMIN = –40°C to TMAX = +85°C,
PARAMETER
MIN
TYP
MAX
UNIT
ANALOG INPUTS
2
VPP
0.75
kΩ
Differential input capacitance (at 200 MHz)
3.7
pF
Analog input bandwidth
(with 50-Ω source impedance, and 50-Ω termination)
550
MHz
Analog input common-mode current
(per input pin of each channel)
1.5
µA/MSPS
Differential input resistance (at 200 MHz)
Common-mode output voltage
VCM
0.95
VCM output current capability
(1)
V
4
mA
DC ACCURACY
Offset error
–15
Temperature coefficient of offset error
2.5
15
0.003
Gain error as a result of internal reference inaccuracy
alone
EGREF
Gain error of channel alone
EGCHAN
Temperature coefficient of EGCHAN
–2
2
±0.1
mV
mV/°C
1
%FS
%FS
Δ%/°C
0.002
POWER SUPPLY
IAVDD
Analog supply current
167
190
mA
IDRVDD
Output buffer supply current
LVDS interface, 350-mV swing with 100-Ω external termination, fIN = 2.5 MHz
136
160
mA
IDRVDD
CMOS interface, no load capacitance, fIN = 2.5 MHz (2)
94
mA
Analog power
301
mW
Digital power
245
mW
Digital power
CMOS interface, 8-pF external load capacitance (2)
fIN = 2.5 MHz
169
mW
Global power-down
(1)
(2)
12
25
mW
VCM changes to 0.87 V when the HIGH PERF MODE[7:2] serial register bits are set.
In CMOS mode, the DRVDD current scales with the sampling frequency, the load capacitance on output pins, input frequency, and the
supply voltage (see CMOS Interface Power Dissipation).
ADS4229
www.ti.com
7.7 Digital Characteristics
At AVDD = 1.8 V and DRVDD = 1.8 V, unless otherwise noted. DC specifications refer to the condition where the digital
outputs do not switch, but are permanently at a valid logic level '0' or '1'.
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
DIGITAL INPUTS (RESET, SCLK, SDATA, SEN, CTRL1, CTRL2, CTRL3) (1)
High-level input voltage
High-level input current
Low-level input current
1.3
All digital inputs support 1.8-V
and 3.3-V CMOS logic levels
Low-level input voltage
V
0.4
V
SDATA, SCLK (2)
VHIGH = 1.8 V
10
µA
SEN (3)
VHIGH = 1.8 V
µA
SDATA, SCLK
VLOW = 0 V
µA
SEN
VLOW = 0 V
10
µA
DIGITAL OUTPUTS, CMOS INTERFACE (DA[13:0], DB[13:0], CLKOUT, SDOUT)
High-level output voltage
DRVDD – 0.1
DRVDD
Low-level output voltage
V
0.1
V
Output capacitance (internal to device)
pF
DIGITAL OUTPUTS, LVDS INTERFACE
High-level output
differential voltage
VODH
With an external
100-Ω termination
270
350
430
mV
Low-level output
VODL
With an external
100-Ω termination
–430
–350
–270
mV
Output common-mode voltage
VOCM
0.9
1.05
1.25
V
(1)
(2)
(3)
SCLK, SDATA, and SEN function as digital input pins in serial configuration mode.
SDATA, SCLK have internal 150-kΩ pull-down resistor.
SEN has an internal 150-kΩ pull-up resistor to AVDD. Because the pull-up is weak, SEN can also be driven by 1.8 V or 3.3 V CMOS
buffers.
DAn_P
DBn_P
Logic 0
VODL = -350 mV
Logic 1
(1)
VODH = +350 mV
(1)
DAn_M
DBn_M
VOCM
GND
(1)
With external 100-Ω termination.
Figure 1. LVDS Output Voltage Levels
13
ADS4229
www.ti.com
7.8 LVDS and CMOS Modes Timing Requirements (1)
Typical values are at +25°C, AVDD = 1.8 V, DRVDD = 1.8 V, sampling frequency = 250 MSPS, sine wave input clock, CLOAD
= 5 pF, and RLOAD = 100 Ω, unless otherwise noted. Minimum and maximum values are across the full temperature range:
TMIN = –40°C to TMAX = +85°C, AVDD = 1.8 V, and DRVDD = 1.7 V to 1.9 V.
PARAMETER
tA
DESCRIPTION
Aperture delay
tJ
Aperture delay matching
Between the two channels of the same device
Variation of aperture delay
Between two devices at the same temperature and
DRVDD supply
MIN
TYP
MAX
0.5
0.8
1.1
Aperture jitter
Wakeup time
Time to valid data after coming out of STANDBY
mode
Time to valid data after coming out of GLOBAL
power-down mode
UNIT
ns
±70
ps
±150
ps
140
fS rms
50
100
µs
100
500
µs
Default latency after reset
16
Clock
cycles
Digital functions enabled (EN DIGITAL = 1)
24
Clock
cycles
ADC latency (2)
DDR LVDS MODE (3)
Data setup time
Data valid (4) to zero-crossing of CLKOUTP
tH
Data hold time
Zero-crossing of CLKOUTP to data becoming
invalid (4)
tPDI
Clock propagation delay
Input clock rising edge cross-over to output clock
LVDS bit clock duty cycle
Duty cycle of differential clock, (CLKOUTPCLKOUTM)
48%
tRISE,
tFALL
Data rise time,
Data fall time
Rise time measured from –100 mV to +100 mV
Fall time measured from +100 mV to –100 mV
1 MSPS ≤ Sampling frequency ≤ 250 MSPS
0.13
ns
tCLKRISE,
tCLKFALL
Output clock rise time,
Output clock fall time
0.13
ns
tSU
0.6
0.88
ns
0.33
0.55
ns
5
6
7.5
ns
PARALLEL CMOS MODE
Output clock duty cycle
Duty cycle of output clock, CLKOUT
1 MSPS ≤ Sampling frequency ≤ 200 MSPS
tRISE,
tFALL
Data rise time,
Data fall time
Rise time measured from 20% to 80% of DRVDD
Fall time measured from 80% to 20% of DRVDD
0.7
ns
tCLKRISE,
tCLKFALL
0.7
ns
tPDI
(1)
(2)
(3)
(4)
14
4.5
6.2
8.5
ns
50%
Timing parameters are ensured by design and characterization and not tested in production.
At higher frequencies, tPDI is greater than one clock period and overall latency = ADC latency + 1.
Measurements are done with a transmission line of 100-Ω characteristic impedance between the device and the load. Setup and hold
time specifications take into account the effect of jitter on the output data and clock.
Data valid refers to a logic high of +100 mV and a logic low of –100 mV.
ADS4229
www.ti.com
7.9 LVDS Timings at Lower Sampling Frequencies
SAMPLING
FREQUENCY
(MSPS)
MIN
TYP
65
5.9
80
4.5
125
SETUP TIME (ns)
tPDI, CLOCK PROPAGATION
DELAY (ns)
HOLD TIME (ns)
MAX
MIN
TYP
6.6
0.35
5.2
0.35
2.3
2.9
160
1.5
185
200
230
MAX
MIN
TYP
MAX
0.6
5
6
7.5
0.6
5
6
7.5
0.35
0.6
5
6
7.5
2
0.33
0.55
5
6
7.5
1.3
1.6
0.33
0.55
5
6
7.5
1.1
1.4
0.33
0.55
5
6
7.5
0.76
1.06
0.33
0.55
5
6
7.5
7.10 CMOS Timings at Lower Sampling Frequencies
TIMINGS SPECIFIED WITH RESPECT TO CLKOUT
SAMPLING
FREQUENCY
(MSPS)
(1)
SETUP TIME (1) (ns)
MIN
TYP
65
6.1
80
4.7
125
DELAY (ns)
HOLD TIME (1) (ns)
MAX
MIN
TYP
6.7
6.7
5.2
5.3
2.7
3.1
160
1.6
185
200
MAX
MIN
TYP
MAX
7.5
4.5
6.2
8.5
6
4.5
6.2
8.5
3.1
3.6
4.5
6.2
8.5
2.1
2.3
2.8
4.5
6.2
8.5
1.1
1.6
1.9
2.4
4.5
6.2
8.5
1
1.4
1.7
2.2
4.5
6.2
8.5
In CMOS mode, setup time is measured from the beginning of data valid to 50% of the CLKOUT rising edge, whereas hold time is
measured from 50% of the CLKOUT rising edge to data becoming invalid. Data valid refers to a logic high of 1.26 V and a logic low of
0.54 V.
CLKM
Input
Clock
CLKP
tPDI
Output
Clock
CLKOUT
tSU
Output
Data
(1)
DAn,
DBn
tH
Dn
(1)
Dn = bits D0, D1, D2, and so forth, of channels A and B.
Figure 2. CMOS Interface Timing Diagram
15
ADS4229
www.ti.com
N+4
N+3
N+2
N + 18
N + 17
N + 16
N+1
Sample
N
Input
Signal
tA
Input
Clock
CLKP
CLKM
CLKOUTM
CLKOUTP
tPDI
tH
DDR
LVDS
16 Clock Cycles
tSU
(1)
(2)
Output Data
DAnP/M, DBnP/M
E
O
E
O
N - 16
E
O
N - 15
E
O
N - 14
E
O
O
E
N - 13
E
N - 12
O
N-1
O
E
N
O
E
E
O
E
N+1
tPDI
CLKOUT
tSU
Parallel
CMOS
16 Clock Cycles
Output Data
DAn, DBn
N - 16
N - 15
N - 14
tH
(1)
N - 13
N-1
N
N+1
(1)
ADC latency after reset. At higher sampling frequencies, tPDI is greater than one clock cycle, which then makes the
(2)
E = even bits (D0, D2, D4, and so forth); O = odd bits (D1, D3, D5, and so forth).
Figure 3. Latency Timing Diagram
16
ADS4229
www.ti.com
CLKOUTM
CLKOUTP
DA0, DB0
D0
D1
D0
D1
DA2, DB2
D2
D3
D2
D3
DA4, DB4
D4
D5
D4
D5
DA6, DB6
D6
D7
D6
D7
DA8, DB8
D8
D9
D8
D9
DA10, DB10
D10
D11
D10
D11
Sample N
Sample N + 1
Figure 4. LVDS Interface Timing Diagram
7.11 Serial Interface Timing Characteristics
See
(1)
PARAMETER
MIN
TYP
UNIT
MHz
SCLK frequency (equal to 1/tSCLK)
tSLOADS
SEN to SCLK setup time
25
ns
tSLOADH
SCLK to SEN hold time
25
ns
tDSU
SDATA setup time
25
ns
tDH
SDATA hold time
25
ns
(1)
> DC
MAX
fSCLK
Typical values at +25°C; minimum and maximum values across the full temperature range: TMIN = –40°C to TMAX = +85°C,
AVDD = 1.8 V, and DRVDD = 1.8 V, unless otherwise noted.
Register Address
SDATA
A7
A6
A5
A4
A3
Register Data
A2
A1
A0
D7
D6
D5
tSCLK
D4
tDSU
D3
D2
D1
D0
tDH
SCLK
tSLOADS
tSLOADH
SEN
RESET
Figure 5. Serial Interface Timing Diagram
17
ADS4229
www.ti.com
7.12 Reset Timing (Only when Serial Interface is Used)
See
(1)
PARAMETER
TEST CONDITIONS
MIN
t1
Power-on delay
Delay from AVDD and DRVDD power-up to active RESET
pulse
t2
Reset pulse width
Active RESET signal pulse width
t3
Register write delay
Delay from RESET disable to SEN active
(1)
TYP
MAX
1
UNIT
ms
10
ns
1
100
µs
ns
Typical values at +25°C; minimum and maximum values across the full temperature range: TMIN = –40°C to TMAX = +85°C, unless
otherwise noted.
Power Supply
AVDD, DRVDD
t1
RESET
t3
t2
SEN
NOTE: A high pulse on the RESET pin is required in the serial interface mode when initialized through a hardware
reset. For parallel interface operation, RESET must be permanently tied high.
Figure 6. Reset Timing Diagram
18
ADS4229
www.ti.com
7.13.1 Typical Characteristics: ADS4229
At TA = +25°C, AVDD = 1.8 V, DRVDD = 1.8 V, maximum rated sampling frequency, sine wave input clock, 1.5 VPP
differential clock amplitude, 50% clock duty cycle, –1-dBFS differential analog input, High-Performance Mode enabled, 0-dB
gain, DDR LVDS output interface, and 32k point FFT, unless otherwise noted.
SFDR = 85.9 dBc
SNR = 70.6 dBFS
SINAD = 70.3 dBFS
THD = 82.1 dBc
−20
−20
−40
Amplitude (dB)
Amplitude (dB)
−40
−60
−60
−80
−80
−100
−100
−120
SFDR = 80.9 dBc
SNR = 69.7 dBFS
SINAD = 69.3 dBFS
THD = 78.8 dBc
50
75
Frequency (MHz)
100
−120
125
Figure 7. Input Signal (10 MHz)
100
125
SFDR = 78.3 dBc
SNR = 68.2 dBFS
SINAD = 67.8 dBFS
THD = 77.2 dBc
−20
Each Tone at
−7 dBFS Amplitude
fIN1 = 185.1 MHz
fIN2 = 190.1 MHz
Two−Tone IMD = 81 dBFS
SFDR = 93.2 dBFS
−20
−40
Amplitude (dB)
−40
Amplitude (dB)
50
75
Frequency (MHz)
Figure 8. Input Signal (150 MHz)
−60
−60
−80
−80
−100
−100
−120
25
50
75
Frequency (MHz)
100
−120
125
Figure 9. Input Signal (300 MHz)
50
75
Frequency (MHz)
100
125
Figure 10. Two-Tone Input Signal
86
Each Tone at
−36 dBFS Amplitude
fIN1 = 185.1 MHz
fIN2 = 190.1 MHz
Two−Tone IMD = 99.9 dBFS
SFDR = 104.8 dBFS
−20
82
80
SFDR (dBc)
Amplitude (dB)
−40
−60
78
76
−80
74
−100
72
−120
50
75
Frequency (MHz)
100
125
70
100
150
200
250
300
350
400
Input Frequency (MHz)
Figure 11. Two-Tone Input Signal
Figure 12. SFDR vs Input Frequency
19
ADS4229
www.ti.com
Typical Characteristics: ADS4229 (continued)
73
88
72
86
71
84
70
82
SFDR (dBc)
SNR (dBFS)
69
68
67
80
78
76
66
74
65
64
72
63
70
100
150
200
250
300
350
400
70 MHz
150 MHz
1
Figure 13. SNR vs Input Frequency
1.5
2
2.5 3 3.5 4
Digital Gain (dB)
220 MHz
400 MHz
4.5
5
5.5
6
Figure 14. SFDR vs Gain and Input Frequency
70
73
110
Input Frequency = 40 MHz
72.5
100
69
90
72
80
71.5
70
71
60
70.5
50
70
67
66
SNR (dBFS)
SFDR (dBc,dBFS)
SINAD (dBFS)
68
65
64
63
SFDR (dBc)
SFDR (dBFS)
SNR
40
70 MHz
150 MHz
1
1.5
220 MHz
400 MHz
2
2.5 3 3.5 4
Digital Gain (dB)
4.5
5
5.5
30
−50
6
Figure 15. SINAD vs Gain and Input Frequency
71
72
80
71.5
70
71
60
70.5
50
70
82
70.5
81
70
80
69.5
79
69
SNR (dBFS)
90
SFDR (dBc)
72.5
SNR (dBFS)
SFDR (dBc,dBFS)
−10
83
Input Frequency = 150 MHz
100
69.5
40
−50
−40
−30
−20
Amplitude (dBFS)
−10
68.5
78
SFDR (dBc)
SFDR (dBFS)
SNR
30
69
Figure 17. Performance vs Input Amplitude
−30
−20
Amplitude (dBFS)
Figure 16. Performance vs Input Amplitude
73
110
−40
69.5
SFDR
SNR
77
0.8
0.85
0.9
0.95
Input CommonMode Voltage (V)
1
68
Figure 18. Performance vs Input Common-Mode Voltage
ADS4229
www.ti.com
72
89
83
71.5
87
82
71
81
70.5
80
70
79
69.5
78
69
84
85
SFDR (dBc)
SNR (dBFS)
SFDR (dBc)
83
81
79
77
73
0.85
0.9
0.95
1
68
71
−40
Figure 19. Performance vs Input Common-Mode Voltage
−15
AVDD = 1.9 V
AVDD = 1.95 V
AVDD = 2 V
10
35
Temperature (°C)
71.5
82
71.5
81
71
71
80
70.5
79
70
78
69.5
SFDR (dBc)
SNR (dBFS)
85
Figure 20. SFDR vs Temperature and AVDD Supply
72
70.5
70
AVDD = 1.7 V
AVDD = 1.75 V
AVDD = 1.8 V
AVDD = 1.85 V
69.5
69
−40
−15
AVDD = 1.9 V
AVDD = 1.95 V
AVDD = 2 V
10
35
Temperature (°C)
69
77
SFDR
SNR
60
76
1.7
85
Figure 21. SNR vs Temperature and AVDD Supply
1.75
1.8
1.85
1.9
DRVDD Supply (V)
1.95
2
68.5
Figure 22. Performance vs DRVDD Supply Voltage
72.5
89
70.5
83
72
82
70
85
71.5
81
69.5
83
71
80
69
81
70.5
79
68.5
79
70
78
68
77
69.5
77
67.5
69
76
75
SFDR (dBc)
87
SNR (dBFS)
SFDR (dBc)
60
67
SFDR
SNR
73
0.2
0.4
0.6
0.8
1
1.2
1.4
1.6
1.8
2
SNR (dBFS)
76
0.8
AVDD = 1.7 V
AVDD = 1.75 V
AVDD = 1.8 V
AVDD = 1.85 V
68.5
SFDR
SNR
SNR (dBFS)
77
75
SFDR
SNR
68.5
2.2
75
0.2
Differential Clock Amplitude (VPP)
0.4
0.6
0.8
1
1.2
1.4
1.6
1.8
2
66.5
2.2
Differential Clock Amplitudes (VPP)
Figure 23. Performance vs Input Clock Amplitude
Figure 24. Performance vs Input Clock Amplitude
21
ADS4229
www.ti.com
88
50 mVPP Signal Superimposed on VCM
−5
84
71
−10
82
70.5
−15
80
70
−20
78
69.5
76
69
74
68.5
72
68
−40
70
67.5
−45
68
67
−50
66.5
−55
66
−60
SNR
THD
66
64
25
30
35
40
45
50
55
60
Input Clock Duty Cycle (%)
65
70
75
CMRR (dB)
71.5
SNR (dBFS)
THD (dBc)
Input Frequency = 10 MHz
86
Figure 25. Performance vs Input Clock Duty Cycle
−25
−30
−35
−10
−15
-60
fIN - fCM = 30 MHz
fCM = 10 MHz
50 mVPP Signal Superimposed on AVDD Supply
−5
PSRR (dB)
Amplitude (dB)
-40
300
fIN = 40 MHz
fCM = 10 MHz, 50 mVPP
SFDR = 81.7 dBc
Amplitude (fIN) = -1 dBFS
Amplitude (fCM) = -102.7 dBFS
Amplitude (fIN + fCM) = -93.9 dBFS
Amplitude (fIN - fCM) = 92.1 dBFS
-20
50
100
150
200
250
Frequency of Input Common−Mode Signal (MHz)
Figure 26. CMRR vs Test Signal Frequency
fIN = 40 MHz
fIN + fCM = 40 MHz
-80
−20
−25
−30
−35
−40
-100
−45
−50
-120
75
50
125
100
Frequency (MHz)
fIN = 10 MHz
fPSRR = 2 MHz, 50 mVPP
Amplitude (fPSRR) = -95.1 dBFS
Amplitude (fIN + fPSRR) = -96.4 dBFS
Amplitude (fIN - fPSRR) = -96.8 dBFS
-20
AVDD = 1.8 V
Input Frequency = 2.5 MHz
310
270
Analog Power (mW)
Amplitude (dB)
-40
-60
fPSRR
fIN - fPSRR
300
Figure 28. PSRR vs Test Signal Frequency
Figure 27. CMRR Plot
fIN
100
150
200
250
Frequency of Signal on Supply (MHz)
fIN + fPSRR
230
190
-80
150
-100
110
70
-120
10
15
30
35
40
45
50
Frequency (MHz)
Figure 29. PSRR Plot
22
50
75 100 125 150 175
Sampling Speed (MSPS)
200
225
250
Figure 30. Analog Power vs Sampling Frequency
ADS4229
www.ti.com
260
320
Fin = 2.5 MHz
240
220
280
260
180
DRVDD Power (mW)
DRVDD Power (mW)
200
160
140
120
100
80
240
220
200
180
160
140
60
40
120
LVDS, 350mV Swing
LVDS, 200mV Swing
CMOS
Default
EN Digital = 1
EN Digital = 1, Offset Correction Enabled
300
50
75 100 125 150 175
200
225
100
250
G001
Figure 31. Digital Power LVDS CMOS
80
50
75 100 125 150 175
200
225
250
G001
Figure 32. Digital Power in Various Modes
23
ADS4229
www.ti.com
7.13.2 Typical Characteristics: Contour
All graphs are at +25°C, AVDD = 1.8 V, DRVDD = 1.8 V, maximum rated sampling frequency, sine wave input clock. 1.5 VPP
250
240
82
Sampling Frequency (MSPS)
220
200
82
82
82
79
75
82
79
180
82
160
85
140
75
82
79
85
88
120
88
85
71
82
82
100
88
80
91
60
79
75
85
100
150
200
250
300
350
400
76
74
72
70
78
80
82
84
86
88
90
SFDR (dBc)
Figure 33. Spurious-Free Dynamic Range (0-dB Gain)
250
240
82
85
76
76
85
220
79
79
82
200
82
85
180
79
82
160
85
85
85
140
79
82
87
120
87
89
100
80
91
87
89
85
79
82
60
100
150
200
250
300
350
400
74
76
78
80
82
84
86
88
90
SFDR (dBc)
Figure 34. Spurious-Free Dynamic Range (6-dB Gain)
24
ADS4229
www.ti.com
Typical Characteristics: Contour (continued)
250
240
69.8
70.6
220
68.6
69.8
70.2
67.7
68.2
69.4
200
69
180
160
69.8
70.2
140
67.7
68.6 68.2
69.4
70.6
67.2
69
120
100
70.2
80
69.8 69.4
70.6
68.2
68.6
67.2
67.7
60
100
150
200
250
300
350
400
67.5
67
68
68.5
69
69.5
70
70.5
SNR (dBFS)
Figure 35. Signal-to-Noise Ratio (0-dB Gain)
250
240
220
65.9
66.2
66.5
66.2
200
64.5
65.3
65.6 65
65.9
66.2
64.5
180
64
65.9
66.2
160
64.5
66.2
65.6
65.3
65
65.9
140
66.5
66.2
120
100
80
65.6
65.9
66.5
65.3
65
60
100
150
200
250
300
350
400
64.5
64
65
65.5
66
66.5
SNR (dBFS)
Figure 36. Signal-to-Noise Ratio (6-dB Gain)
25
ADS4229
www.ti.com
8 Detailed Description
8.1 Overview
The ADS4229 belongs to TI's ultra low-power family of dual-channel, 12-bit analog-to-digital converters (ADCs).
High performance is maintained while reducing power for power sensitive applications. In addition to its low
power and high performance, the ADS4229 has a number of digital features and operating modes to enable
design flexibility.
8.2 Functional Block Diagram
AVDD
AGND
DRVDD
DRGND
LVDS Interface
DA0P
DA0M
DA2P
DA2M
DA4P
INP_A
Sampling
Circuit
INM_A
Digital and
DDR
Serializer
12-Bit
ADC
DA4M
DA6P
DA6M
DA8P
DA8M
DA10P
DA10M
CLKP
Output
Clock Buffer
CLOCKGEN
CLKM
CLKOUTP
CLKOUTM
DB0P
DB0M
DB2P
DB2M
DB4P
INP_B
Sampling
Circuit
INM_B
Digital and
DDR
Serializer
12-Bit
ADC
DB4M
DB6P
DB6M
DB8P
DB8M
DB10P
DB10M
26
CTRL3
CTRL1
SDOUT
CTRL2
SEN
SCLK
RESET
ADS4229
SDATA
Control
Interface
Reference
VCM
ADS4229
www.ti.com
8.3 Feature Description
8.3.1 Digital Functions
The device has several useful digital functions (such as test patterns, gain, and offset correction). These
functions require extra clock cycles for operation and increase the overall latency and power of the device. These
digital functions are disabled by default after reset and the raw ADC output is routed to the output data pins with
a latency of 16 clock cycles. Figure 37 shows more details of the processing after the ADC. In order to use any
of the digital functions, the EN DIGITAL bit must be set to '1'. After this, the respective register bits must be
programmed as described in the following sections and in the Serial Register Map section.
Output
Interface
12-Bit
ADC
12-Bit
Digital Functions
(Gain, Offset Correction, Test Patterns)
DDR LVDS
or CMOS
EN DIGITAL Bit
Figure 37. Digital Processing Block
8.3.2 Gain for SFDR/SNR Trade-off
The ADS4229 includes gain settings that can be used to get improved SFDR performance (compared to no
gain). The gain is programmable from 0 dB to 6 dB (in 0.5-dB steps). For each gain setting, the analog input fullscale range scales proportionally, as shown in Table 2.
The SFDR improvement is achieved at the expense of SNR; for each gain setting, the SNR degrades
approximately between 0.5 dB and 1 dB. The SNR degradation is reduced at high input frequencies. As a result,
the gain is very useful at high input frequencies because the SFDR improvement is significant with marginal
degradation in SNR. Therefore, the gain can be used as a trade-off between SFDR and SNR. Note that the
default gain after reset is 0 dB.
Table 2. Full-Scale Range Across Gains
GAIN (dB)
TYPE
FULL-SCALE (VPP)
Default after reset
2
1
Fine, programmable
1.78
2
Fine, programmable
1.59
3
Fine, programmable
1.42
4
Fine, programmable
1.26
5
Fine, programmable
1.12
6
Fine, programmable
1
8.3.3 Offset Correction
The ADS4229 has an internal offset corretion algorithm that estimates and corrects dc offset up to ±10 mV. The
correction can be enabled using the ENABLE OFFSET CORR serial register bit. Once enabled, the algorithm
estimates the channel offset and applies the correction every clock cycle. The time constant of the correction
loop is a function of the sampling clock frequency. The time constant can be controlled using the OFFSET CORR
TIME CONSTANT register bits, as described in Table 3.
After the offset is estimated, the correction can be frozen by setting FREEZE OFFSET CORR = 0. Once frozen,
the last estimated value is used for the offset correction of every clock cycle. Note that offset correction is
disabled by default after reset.
27
ADS4229
www.ti.com
Table 3. Time Constant of Offset Correction Algorithm
(1)
OFFSET CORR TIME CONSTANT
TIME CONSTANT, TCCLK
(Number of Clock Cycles)
TIME CONSTANT, TCCLK × 1/fS (ms) (1)
0000
1M
4
0001
2M
8
0010
4M
16
0011
8M
32
0100
16 M
64
0101
32 M
128
0110
64 M
256
0111
128 M
512
1000
256 M
1024
1001
512 M
2048
1010
1G
4096
1011
2G
8192
1100
Reserved
1101
Reserved
1110
Reserved
1111
Reserved
Sampling frequency, fS = 250 MSPS.
8.3.4 Power-Down
The ADS4229 has two power-down modes: global power-down and channel standby. These modes can be set
using either the serial register bits or using the control pins CTRL1 to CTRL3 (as shown in Table 4).
Table 4. Power-Down Settings
CTRL1
CTRL2
CTRL3
Low
Low
Low
Default
DESCRIPTION
Low
Low
High
Not available
Low
High
Low
Not available
Low
High
High
Not available
High
Low
Low
Global power-down
High
Low
High
Channel A powered down, channel B is active
High
High
Low
Not available
High
High
High
MUX mode of operation, channel A and B data is
multiplexed and output on DB[10:0] pins
8.3.4.1 Global Power-Down
In this mode, the entire chip (including ADCs, internal reference, and output buffers) are powered down, resulting
in reduced total power dissipation of approximately 20 mW when the CTRL pins are used and 3mW when the
PDN GLOBAL serial register bit is used. The output buffers are in high-impedance state. The wake-up time from
global power-down to data becoming valid in normal mode is typically 100 µs.
8.3.4.2 Channel Standby
In this mode, each ADC channel can be powered down. The internal references are active, resulting in a quick
wake-up time of 50 µs. The total power dissipation in standby is approximately 250 mW at 250 MSPS.
8.3.4.3 Input Clock Stop
In addition to the previous modes, the converter enters a low-power mode when the input clock frequency falls
below 1 MSPS. The power dissipation is approximately 160 mW.
28
ADS4229
www.ti.com
8.3.5 Output Data Format
Two output data formats are supported: twos complement and offset binary. The format can be selected using
the DATA FORMAT serial interface register bit or by controlling the DFS pin in parallel configuration mode.
In the event of an input voltage overdrive, the digital outputs go to the appropriate full-scale level. For a positive
overdrive, the output code is FFFh for the ADS4229 in offset binary output format; the output code is 7FFh for
the ADS4229 in twos complement output format. For a negative input overdrive, the output code is 0000h in
offset binary output format and 800h for the ADS4229 in twos complement output format.
8.4 Device Functional Modes
8.4.1 Output Interface Modes
The ADS4229 provides 12-bit digital data for each channel and an output clock synchronized with the data.
8.4.1.1 Output Interface
Two output interface options are available: double data rate (DDR) LVDS and parallel CMOS. They can be
selected using the serial interface register bit or by setting the proper voltage on the SEN pin in parallel
configuration mode.
8.4.1.2 DDR LVDS Outputs
In this mode, the data bits and clock are output using low-voltage differential signal (LVDS) levels. Two data bits
are multiplexed and output on each LVDS differential pair, as shown in Figure 38.
Pins
CLKOUTP
CLKOUTM
DB0_P
LVDS Buffers
DB0_M
DB2_P
DB2_M
DB4_P
12-Bit ADC Data,
Channel B
DB4_M
DB6_P
DB6_M
DB8_P
DB8_M
DB10_P
DB10_M
Output
Clock
Data Bits
D0, D1
Data Bits
D2, D3
Data Bits
D4, D5
Data Bits
D6, D7
Data Bits
D8, D9
Data Bits
D10, D11
Figure 38. LVDS Interface
Even data bits (D0, D2, D4, and so forth) are output at the CLKOUTP rising edge and the odd data bits (D1, D3,
D5, and so forth) are output at the CLKOUTP falling edge. Both the CLKOUTP rising and falling edges must be
used to capture all the data bits, as shown in Figure 39.
29
ADS4229
www.ti.com
Device Functional Modes (continued)
CLKOUTM
CLKOUTP
DA0, DB0
D0
D1
D0
D1
DA2, DB2
D2
D3
D2
D3
DA4, DB4
D4
D5
D4
D5
DA6, DB6
D6
D7
D6
D7
DA8, DB8
D8
D9
D8
D9
DA10, DB10
D10
D11
D10
D11
Sample N
Sample N + 1
Figure 39. DDR LVDS Interface Timing
8.4.1.3 LVDS Buffer
The equivalent circuit of each LVDS output buffer is shown in Figure 40. After reset, the buffer presents an
output impedance of 100Ω to match with the external 100-Ω termination.
VDIFF
High
Low
OUTP
External
100-W Load
OUTM
VOCM
ROUT
VDIFF
Low
High
NOTE: Default swing across 100-Ω load is ±350 mV. Use the LVDS SWING bits to change the swing.
Figure 40. LVDS Buffer Equivalent Circuit
The VDIFF voltage is nominally 350 mV, resulting in an output swing of ±350 mV with 100-Ω external termination.
The VDIFF voltage is programmable using the LVDS SWING register bits from ±125 mV to ±570 mV.
Additionally, a mode exists to double the strength of the LVDS buffer to support 50-Ω differential termination, as
shown in Figure 41. This mode can be used when the output LVDS signal is routed to two separate receiver
chips, each using a 100-Ω termination. The mode can be enabled using the LVDS DATA STRENGTH and LVDS
CLKOUT STRENGTH register bits for data and output clock buffers, respectively.
The buffer output impedance behaves in the same way as a source-side series termination. By absorbing
reflections from the receiver end, it helps to improve signal integrity.
30
ADS4229
www.ti.com
Receiver Chip # 1
(for example, GC5330)
DAnP/M
CLKIN1
100 W
CLKIN2
100 W
CLKOUTP
CLKOUTM
DBnP/M
Receiver Chip # 2
Device
Make LVDS CLKOUT STRENGTH = 1
Figure 41. LVDS Buffer Differential Termination
31
ADS4229
www.ti.com
8.4.1.4 Parallel CMOS Interface
In the CMOS mode, each data bit is output on separate pins as CMOS voltage level, every clock cycle, as
Figure 42 shows. The rising edge of the output clock CLKOUT can be used to latch data in the receiver. It is
recommended to minimize the load capacitance of the data and clock output pins by using short traces to the
receiver. Furthermore, match the output data and clock traces to minimize the skew between them.
DB0
¼
¼
DB1
12-Bit ADC Data,
Channel B
DB10
DB11
SDOUT
CLKOUT
DA0
¼
¼
DA1
12-Bit ADC Data,
Channel A
DA10
DA11
Figure 42. CMOS Outputs
8.4.1.5 CMOS Interface Power Dissipation
With CMOS outputs, the DRVDD current scales with the sampling frequency and the load capacitance on every
output pin. The maximum DRVDD current occurs when each output bit toggles between 0 and 1 every clock
cycle. In actual applications, this condition is unlikely to occur. The actual DRVDD current would be determined
by the average number of output bits switching, which is a function of the sampling frequency and the nature of
the analog input signal. This relationship is shown by the formula:
32
ADS4229
www.ti.com
Digital current as a result of CMOS output switching = CL × DRVDD × (N × FAVG)
where
CL = load capacitance,
N × FAVG = average number of output bits switching.
(1)
8.4.1.6 Multiplexed Mode of Operation
In this mode, the digital outputs of both channels are multiplexed and output on a single bus (DB[11:0] pins), as
shown in Figure 43. The channel A output pins (DA[11:0]) are in 3-state. Because the output data rate on the DB
bus is effectively doubled, this mode is recommended only for low sampling frequencies (less than 80 MSPS).
This mode can be enabled using the POWER-DOWN MODE register bits or using the CTRL[3:1] parallel pins.
CLKM
Input
Clock
CLKP
tPDI
Output
Clock
CLKOUT
tSU
Output
Data
DBn
Channel A
(1)
DAn
(2)
tH
Channel B
DBn
(2)
(1)
In multiplexed mode, both channels outputs come on the channel B output pins.
(2)
Dn = bits D0, D1, D2, and so forth.
Channel A
DAn
(2)
Figure 43. Multiplexed Mode Timing Diagram
8.5 Programming
Table 5 shows all the high-performance modes for the ADS4229 device.
Table 5. High-Performance Modes (1) (2)
PARAMETER
DESCRIPTION
Set the HIGH PERF MODE[2:1] register bit to obtain best performance across sample clock and input signal
frequencies.
Register address = 03h, data = 03h
High-frequency mode
Set the HIGH FREQ MODE CH A and HIGH FREQ MODE CH B register bits for high input signal frequencies
greater than 200 MHz.
Register address = 4Ah, data = 01h
Register address = 58h, data = 01h
High-speed mode
Set the HIGH PERF MODE[2:7] bits to obtain best performance across input signal frequencies for sampling
rates greater than 160 MSPS.
Note that this mode changes VCM to 0.87 V from its default value of 0.95 V.
Register address = 2h, data = 40h
Register address = D5h, data = 18h
Register address = D7h, data = 0Ch
Register address = DBh, data = 20h
(1)
(2)
It is recommended to use these modes to obtain best performance.
See the Serial Interface Configuration section for details on register programming.
33
ADS4229
www.ti.com
8.5.1 Device Configuration
The ADS4229 can be configured independently using either parallel interface control or serial interface
programming.
8.5.2 Parallel Configuration Only
To put the device into parallel configuration mode, keep RESET tied high (AVDD). Then, use the SEN, SCLK,
CTRL1, CTRL2, and CTRL3 pins to directly control certain modes of the ADC. The device can be easily
configured by connecting the parallel pins to the correct voltage levels (as described in Table 6 to Table 9).
There is no need to apply a reset and SDATA can be connected to ground.
In this mode, SEN and SCLK function as parallel interface control pins. Some frequently-used functions can be
controlled using these pins. Table 6 describes the modes controlled by the parallel pins.
Table 6. Parallel Pin Definition
PIN
CONTROL MODE
SCLK
Low-speed mode selection
SEN
Output data format and output interface selection
CTRL1
CTRL2
Together, these pins control the power-down modes
CTRL3
8.5.3 Serial Interface Configuration Only
To enable this mode, the serial registers must first be reset to the default values and the RESET pin must be
kept low. SEN, SDATA, and SCLK function as serial interface pins in this mode and can be used to access the
internal registers of the ADC. The registers can be reset either by applying a pulse on the RESET pin or by
setting the RESET bit high. The Serial Register Map section describes the register programming and the register
reset process in more detail.
8.5.4 Using Both Serial Interface and Parallel Controls
For increased flexibility, a combination of serial interface registers and parallel pin controls (CTRL1 to CTRL3)
can also be used to configure the device. To enable this option, keep RESET low. The parallel interface control
pins CTRL1 to CTRL3 are available. After power-up, the device is automatically configured according to the
voltage settings on these pins (see Table 9). SEN, SDATA, and SCLK function as serial interface digital pins and
are used to access the internal registers of the ADC. The registers must first be reset to the default values either
by applying a pulse on the RESET pin or by setting the RESET bit to '1'. After reset, the RESET pin must be kept
low. The Serial Register Map section describes register programming and the register reset process in more
detail.
8.5.5 Parallel Configuration Details
The functions controlled by each parallel pin are described in Table 7, Table 8, and Table 9. A simple way of
configuring the parallel pins is shown in Figure 44.
Table 7. SCLK Control Pin
VOLTAGE APPLIED ON SCLK
DESCRIPTION
Low
Low-speed mode is disabled
High
Low-speed mode is enabled
Table 8. SEN Control Pin
VOLTAGE APPLIED ON SEN
(+50mV/0mV)
(3/8) AVDD
(±50mV)
34
DESCRIPTION
Twos complement and parallel CMOS output
Offset binary and parallel CMOS output
ADS4229
www.ti.com
Table 8. SEN Control Pin (continued)
DESCRIPTION
(5/8) 2AVDD
(±50mV)
Offset binary and DDR LVDS output
AVDD
(0mV/–50mV)
Twos complement and DDR LVDS output
Table 9. CTRL1, CTRL2, and CTRL3 Pins
CTRL1
CTRL2
CTRL3
Low
Low
Low
Normal operation
DESCRIPTION
Low
Low
High
Not available
Low
High
Low
Not available
Low
High
High
Not available
High
Low
Low
Global power-down
High
Low
High
Channel A standby, channel B is active
High
High
Low
Not available
High
High
High
MUX mode of operation, channel A and B data are
multiplexed and output on the DB[11:0] pins.
AVDD
(5/8) AVDD
3R
(5/8) AVDD
GND
AVDD
2R
(3/8) AVDD
3R
(3/8) AVDD
To Parallel Pin
Figure 44. Simple Scheme to Configure the Parallel Pins
8.5.6 Serial Interface Details
The ADC has a set of internal registers that can be accessed by the serial interface formed by the SEN (serial
interface enable), SCLK (serial interface clock), and SDATA (serial interface data) pins. Serial shift of bits into the
device is enabled when SEN is low. Serial data SDATA are latched at every SCLK falling edge when SEN is
active (low). The serial data are loaded into the register at every 16th SCLK falling edge when SEN is low. When
the word length exceeds a multiple of 16 bits, the excess bits are ignored. Data can be loaded in multiples of 16bit words within a single active SEN pulse. The first eight bits form the register address and the remaining eight
bits are the register data. The interface can work with SCLK frequencies from 20 MHz down to very low speeds
(of a few hertz) and also with non-50% SCLK duty cycle.
8.5.6.1 Register Initialization
After power-up, the internal registers must be initialized to the default values. Initialization can be accomplished
in one of two ways:
1. Through a hardware reset by applying a high pulse on the RESET pin (of width greater than 10 ns), as
shown in Figure 5 and Serial Interface Timing Characteristics; or
2. By applying a software reset. When using the serial interface, set the RESET bit high. This setting initializes
the internal registers to the default values and then self-resets the RESET bit low. In this case, the RESET
pin is kept low. See Reset Timing (Only when Serial Interface is Used) and Figure 6 for reset timing.
8.5.6.2 Serial Register Readout
The device includes a mode where the contents of the internal registers can be read back. This readback mode
may be useful as a diagnostic check to verify the serial interface communication between the external controller
and the ADC. To use readback mode, follow this procedure:
35
ADS4229
www.ti.com
1. Set the READOUT register bit to '1'. This setting disables any further writes to the registers.
2. Initiate a serial interface cycle specifying the address of the register (A7 to A0) whose content has to be
read.
3. The device outputs the contents (D7 to D0) of the selected register on the SDOUT pin (pin 64).
4. The external controller can latch the contents at the SCLK falling edge.
5. To enable register writes, reset the READOUT register bit to '0'.
The serial register readout works with both CMOS and LVDS interfaces on pin 64. See Figure 45 for serial
readout timing diagram.
When READOUT is disabled, the SDOUT pin is in high-impedance state.
Register Address A[7:0] = 00h
SDATA
Register Data D[7:0] = 01h
SCLK
SEN
The SDOUT pin is in high-impedance state.
SDOUT
a) Enable serial readout (READOUT = 1)
Register Address A[7:0] = 45h
SDATA
A7
A6
A5
A4
A3
A2
Register Data D[7:0] = XX (don’t care)
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
SCLK
SEN
SDOUT
The SDOUT pin functions as serial readout (READOUT = 1).
b) Read contents of Register 45h. This register has been initialized with 04h (device is put into global power-down mode.)
Figure 45. Serial Readout Timing Diagram
36
ADS4229
www.ti.com
8.6 Register Maps
8.6.1 Serial Register Map
Table 10 summarizes the functions supported by the serial interface.
Table 10. Serial Interface Register Map (1)
REGISTER
ADDRESS
REGISTER DATA
A[7:0] (Hex)
D7
D6
D5
D4
D3
D2
D1
D0
00
RESET
READOUT
HIGH PERF
MODE 2
HIGH PERF
MODE 1
01
03
LVDS SWING
29
CH A GAIN
2B
DATA FORMAT
CH B GAIN
3D
3F
(1)
CH A TEST PATTERNS
ENABLE
OFFSET
CORR
CH B TEST PATTERNS
CUSTOM PATTERN D[11:6]
CUSTOM PATTERN D[5:0]
LVDS CMOS
CMOS CLKOUT STRENGTH
DIS OBUF
42
CLKOUT FALL POSN
CLKOUT RISE POSN
EN DIGITAL
STBY
LVDS
CLKOUT
STRENGTH
4A
HIGH FREQ
MODE CH B
58
HIGH FREQ
MODE CH A
LVDS DATA
STRENGTH
PDN GLOBAL
BF
CH A OFFSET PEDESTAL
C1
CH B OFFSET PEDESTAL
CF
FREEZE
OFFSET
CORR
EF
EN LOW
SPEED MODE
F1
EN LVDS SWING
F2
LOW SPEED
MODE CH A
2
HIGH PERF
MODE3
D5
HIGH PERF
MODE4
HIGH PERF
MODE5
D7
HIGH PERF
MODE6
HIGH PERF
MODE7
DB
HIGH PERF
MODE8
LOW SPEED
MODE CH B
Multiple functions in a register can be programmed in a single write operation. All registers default to '0' after reset.
37
ADS4229
www.ti.com
8.6.2 Description of Serial Registers
8.6.2.1 Register Address 00h (Default = 00h)
Figure 46. Register Address 00h (Default = 00h)
7
6
5
4
3
2
1
RESET
READOUT
Bits[7:2]
Always write '0'
Bit 1
RESET: Software reset applied
This bit resets all internal registers to the default values and self-clears to 0 (default = 1).
Bit 0
READOUT: Serial readout
This bit sets the serial readout of the registers.
0 = Serial readout of registers disabled; the SDOUT pin is placed in a high-impedance state.
1 = Serial readout enabled; the SDOUT pin functions as a serial data readout with CMOS logic
levels running from the DRVDD supply. See the Serial Register Readout section.
8.6.2.2 Register Address 01h (Default = 00h)
Figure 47. Register Address 01h (Default = 00h)
7
6
5
4
3
2
LVDS SWING
Bits[7:2]
1
LVDS SWING: LVDS swing programmability
These bits program the LVDS swing. Set the EN LVDS SWING bit to '1' before programming
swing.
000000 = Default LVDS swing; ±350 mV with external 100-Ω termination
011011 = LVDS swing increases to ±410 mV
110010 = LVDS swing increases to ±465 mV
010100 = LVDS swing increases to ±570 mV
111110 = LVDS swing increases to ±200 mV
001111 = LVDS swing increases to ±125 mV
Bits[1:0]
Always write '0'
8.6.2.3 Register Address 03h (Default = 00h)
Figure 48. Register Address 03h (Default = 00h)
7
6
5
4
3
2
1
HIGH PERF
MODE 2
HIGH PERF
MODE 1
Bits[7:2]
Always write '0'
Bits[1:0]
HIGH PERF MODE[2:1]: High-performance mode
00
01
10
11
38
Default performance
Do not use
Do not use
Obtain best performance across sample clock and input signal frequencies
ADS4229
www.ti.com
8.6.2.4 Register Address 25h (Default = 00h)
Figure 49. Register Address 25h (Default = 00h)
7
6
5
4
3
CH A GAIN
Bits[7:4]
2
CH A TEST PATTERNS
CH A GAIN: Channel A gain programmability
These bits set the gain programmability in 0.5-dB steps for channel A.
0000
0001
0010
0011
0100
0101
0110
0111
1000
1001
1010
1011
1100
0-dB gain (default after reset)
0.5-dB gain
1-dB gain
1.5-dB gain
2-dB gain
2.5-dB gain
3-dB gain
3.5-dB gain
4-dB gain
4.5-dB gain
5-dB gain
5.5-dB gain
6-dB gain
Bit 3
Always write '0'
Bits[2:0]
CH A TEST PATTERNS: Channel A data capture
These bits verify data capture for channel A.
000 = Normal operation
001 = Outputs all 0s
010 = Outputs all 1s
011 = Outputs toggle pattern.
For the ADS4229, the output data D[11:0] are an alternating sequence of 101010101010 and
010101010101.
100 = Outputs digital ramp.
101 = Outputs custom pattern; use registers 3Fh and 40h to set the custom pattern
110 = Unused
111 = Unused
8.6.2.5 Register Address 29h (Default = 00h)
Figure 50. Register Address 29h (Default = 00h)
7
6
5
3
DATA FORMAT
Bits[7:5]
Always write '0'
Bits[4:3]
DATA FORMAT: Data format selection
00
01
10
11
Bits[2:0]
2
1
Twos complement
Twos complement
Twos complement
Offset binary
Always write '0'
39
ADS4229
SBAS550C – JUNE 2011 – REVISED MAY 2015
www.ti.com
8.6.2.6 Register Address 2Bh (Default = 00h)
Figure 51. Register Address 2Bh (Default = 00h)
7
6
5
4
3
CH B GAIN
Bits[7:4]
2
CH B TEST PATTERNS
CH B GAIN: Channel B gain programmability
These bits set the gain programmability in 0.5-dB steps for channel B.
0000
0001
0010
0011
0100
0101
0110
0111
1000
1001
1010
1011
1100
0.5-dB gain
1-dB gain
1.5-dB gain
2-dB gain
2.5-dB gain
3-dB gain
3.5-dB gain
4-dB gain
4.5-dB gain
5-dB gain
5.5-dB gain
6-dB gain
Bit 3
Always write '0'
Bits[2:0]
CH B TEST PATTERNS: Channel B data capture
These bits verify data capture for channel B.
010101010101.
110 = Unused
111 = Unused
8.6.2.7 Register Address 3Dh (Default = 00h)
Figure 52. Register Address 3Dh (Default = 00h)
7
6
5
4
3
2
1
ENABLE OFFSET CORR
Bits[7:6]
Always write '0'
Bit 5
ENABLE OFFSET CORR: Offset correction setting
This bit enables the offset correction.
0 = Offset correction disabled
1 = Offset correction enabled
Bits[4:0]
40
Always write '0'
ADS4229
www.ti.com
8.6.2.8 Register Address 3Fh (Default = 00h)
Figure 53. Register Address 3Fh (Default = 00h)
7
6
5
4
3
2
1
CUSTOM
PATTERN D11
CUSTOM
PATTERN D10
CUSTOM
PATTERN D9
CUSTOM
PATTERN D8
CUSTOM
PATTERN D7
CUSTOM
PATTERN D6
Bits[7:6]
Always write '0'
Bits[5:0]
These are the six upper bits of the custom pattern available at the output instead of ADC data.
The ADS4229 custom pattern is 12-bit.
8.6.2.9 Register Address 40h (Default = 00h)
Figure 54. Register Address 40h (Default = 00h)
7
6
5
4
3
2
1
CUSTOM
PATTERN D5
CUSTOM
PATTERN D4
CUSTOM
PATTERN D3
CUSTOM
PATTERN D2
CUSTOM
PATTERN D1
CUSTOM
PATTERN D0
Bits[7:2]
These are the six lower bits of the custom pattern available at the output instead of ADC data.
The ADS4229 custom pattern is 12-bit; use the CUSTOM PATTERN D[11:0] register bits.
Bits[1:0]
Always write '0'
8.6.2.10 Register Address 41h (Default = 00h)
Figure 55. Register Address 41h (Default = 00h)
7
6
LVDS CMOS
Bits[7:6]
5
4
3
2
DIS OBUF
LVDS CMOS: Interface selection
These bits select the interface.
00 = DDR LVDS interface
01 = DDR LVDS interface
10 = DDR LVDS interface
11 = Parallel CMOS interface
Bits[5:4]
These bits control the strength of the CMOS output clock.
00 = Maximum strength (recommended)
01 = Medium strength
10 = Low strength
11 = Very low strength
Bits[3:2]
Always write '0'
Bits[1:0]
DIS OBUF
These bits power down data and clock output buffers for both the CMOS and LVDS output
interface. When powered down, the output buffers are in 3-state.
00 = Default
01 = Power-down data output buffers for channel B
10 = Power-down data output buffers for channel A
11 = Power-down data output buffers for both channels as well as the clock output buffer
41
ADS4229
www.ti.com
8.6.2.11 Register Address 42h (Default = 00h)
Figure 56. Register Address 42h (Default = 00h)
7
6
5
CLKOUT FALL POSN
Bits[7:6]
CLKOUT RISE POSN
2
1
EN DIGITAL
of the output clock advances by 450 ps
of the output clock advances by 150 ps
of the output clock is delayed by 550 ps
of the output clock is delayed by 150 ps
of the output clock advances by 100 ps
CLKOUT RISE POSN
In LVDS mode:
00 = Default
01 = The rising edge
10 = The rising edge
11 = The rising edge
In CMOS mode:
00 = Default
10 = Do not use
Bit 3
3
CLKOUT FALL POSN
In LVDS mode:
00 = Default
01 = The falling edge
10 = The falling edge
11 = The falling edge
In CMOS mode:
00 = Default
10 = Do not use
Bits[5:6]
4
of the output clock is delayed by 250 ps
EN DIGITAL: Digital function enable
0 = All digital functions disabled
1 = All digital functions (such as test patterns, gain, and offset correction) enabled
Bits[2:0]
Always write '0'
8.6.2.12 Register Address 45h (Default = 00h)
Figure 57. Register Address 45h (Default = 00h)
7
6
5
4
3
2
1
STBY
LVDS CLKOUT
STRENGTH
LVDS DATA
STRENGTH
PDN GLOBAL
Bit 7
STBY: Standby setting
1 = Both channels are put in standby; wakeup time from this mode is fast (typically 50 µs).
Bit 6
LVDS CLKOUT STRENGTH: LVDS output clock buffer strength setting
0 = LVDS output clock buffer at default strength to be used with 100-Ω external termination
1 = LVDS output clock buffer has double strength to be used with 50-Ω external termination
Bit 5
LVDS DATA STRENGTH
0 = All LVDS data buffers at default strength to be used with 100-Ω external termination
1 = All LVDS data buffers have double strength to be used with 50-Ω external termination
Bits[4:3]
Always write '0'
Bit 2
PDN GLOBAL
42
ADS4229
www.ti.com
1 = Total power down; all ADC channels, internal references, and output buffers are powered
down. Wakeup time from this mode is slow (typically 100 µs).
Bits[1:0]
Always write '0'
8.6.2.13 Register Address 4Ah (Default = 00h)
Figure 58. Register Address 4Ah (Default = 00h)
7
6
5
4
3
2
1
HIGH FREQ MODE CH B
Bits[7:1]
Always write '0'
Bit 0
HIGH FREQ MODE CH B: High-frequency mode for channel B
0 = Default
1 = Use this mode for high input frequencies greater than 200 MHz
8.6.2.14 Register Address 58h (Default = 00h)
Figure 59. Register Address 58h (Default = 00h)
7
6
5
4
3
2
1
HIGH FREQ MODE CH A
Bits[7:1]
Always write '0'
Bit 0
HIGH FREQ MODE CH A: High-frequency mode for channel A
0 = Default
8.6.2.15 Register Address BFh (Default = 00h)
Figure 60. Register Address BFh (Default = 00h)
7
6
5
4
Bits[7:4]
3
2
1
CH A OFFSET PEDESTAL: Channel A offset pedestal selection
When the offset correction is enabled, the final converged value after the offset is corrected is the
ADC midcode value. A pedestal can be added to the final converged value by programming these
bits. See the Offset Correction section. Channels can be independently programmed for different
offset pedestals by choosing the relevant register address.
For the ADS4229, the pedestal ranges from –8 to +7, so the output code can vary from midcode-8
to midcode+7 by adding pedestal D7-D4.
Program bits D[7:4]
0111 = Midcode+7
0110 = Midcode+6
0101 = Midcode+5
0000 = Midcode
1111 = Midcode-1
1110 = Midcode-2
1101 = Midcode-3
1000 = Midcode-8
Bits[3:0]
Always write '0'
43
ADS4229
www.ti.com
8.6.2.16 Register Address C1h (Default = 00h)
Figure 61. Register Address C1h (Default = 00h)
7
6
5
4
Bits[7:4]
3
2
1
CH B OFFSET PEDESTAL: Channel B offset pedestal selection
When offset correction is enabled, the final converged value after the offset is corrected is the ADC
midcode value. A pedestal can be added to the final converged value by programming these bits;
see the Offset Correction section. Channels can be independently programmed for different offset
to midcode+7 by adding pedestal D[7:4].
Program Bits D[7:4]
0111 = Midcode+7
0110 = Midcode+6
0101 = Midcode+5
0000 = Midcode
1111 = Midcode-1
1110 = Midcode-2
1101 = Midcode-3
1000 = Midcode-8
Bits[3:0]
Always write '0'
8.6.2.17 Register Address CFh (Default = 00h)
Figure 62. Register Address CFh (Default = 00h)
7
6
FREEZE OFFSET CORR
Bit 7
5
4
3
2
1
FREEZE OFFSET CORR: Freeze offset correction setting
This bit sets the freeze offset correction estimation.
0 = Estimation of offset correction is not frozen (the EN OFFSET CORR bit must be set)
1 = Estimation of offset correction is frozen (the EN OFFSET CORR bit must be set); when frozen,
the last estimated value is used for offset correction of every clock cycle. See the Offset Correction
section.
Bit 6
Always write '0'
Bits[5:2]
The offset correction loop time constant in number of clock cycles. Refer to the Offset Correction
section.
Bits[1:0]
44
Always write '0'
ADS4229
www.ti.com
8.6.2.18 Register Address EFh (Default = 00h)
Figure 63. Register Address EFh (Default = 00h)
7
6
5
4
3
2
1
EN LOW SPEED MODE
Bits[7:5]
Always write '0'
Bit 4
EN LOW SPEED MODE: Enable control of low-speed mode through serial register bits
This bit enables the control of the low-speed mode using the LOW SPEED MODE CH B and LOW
SPEED MODE CH A register bits.
0 = Low-speed mode is disabled
1 = Low-speed mode is controlled by serial register bits
Bits[3:0]
Always write '0'
8.6.2.19 Register Address F1h (Default = 00h)
Figure 64. Register Address F1h (Default = 00h)
7
6
5
4
3
2
1
EN LVDS SWING
Bits[7:2]
Always write '0'
Bits[1:0]
EN LVDS SWING: LVDS swing enable
These bits enable LVDS swing control using the LVDS SWING register bits.
00 = LVDS swing control using the LVDS SWING register bits is disabled
01 = Do not use
10 = Do not use
11 = LVDS swing control using the LVDS SWING register bits is enabled
8.6.2.20 Register Address F2h (Default = 00h)
Figure 65. Register Address F2h (Default = 00h)
7
6
5
4
3
2
1
LOW SPEED MODE CH A
Bits[7:4]
Always write '0'
Bit 3
LOW SPEED MODE CH A: Channel A low-speed mode enable
This bit enables the low-speed mode for channel A. Set the EN LOW SPEED MODE bit to '1'
before using this bit.
0 = Low-speed mode is disabled for channel A
1 = Low-speed mode is enabled for channel A
Bits[2:0]
Always write '0'
8.6.2.21 Register Address 2h (Default = 00h)
Figure 66. Register Address 2h (Default = 00h)
7
6
5
4
3
2
1
HIGH PERF
MODE3
Bit 7
Always write '0'
Bit 6
HIGH PERF MODE3
HIGH PERF MODE3 to HIGH PERF MODE8 must be set to '1' to ensure best performance at high
sampling speed (greater than 160 MSPS)
Submit Documentation Feedback
Copyright © 2011–2015, Texas Instruments Incorporated
Product Folder Links: ADS4229
45
ADS4229
Bits[5:0]
www.ti.com
Always write '0'
8.6.2.22 Register Address D5h (Default = 00h)
Figure 67. Register Address D5h (Default = 00h)
7
6
Bits[7:5]
Always write '0'
Bit 4
HIGH PERF MODE4
5
4
3
2
1
HIGH PERF
MODE4
HIGH PERF
MODE5
Bit 3
HIGH PERF MODE5
Bits[2:0]
Always write '0'
8.6.2.23 Register Address D7h (Default = 00h)
Figure 68. Register Address D7h (Default = 00h)
7
6
Bits[7:4]
Always write '0'
Bit 3
HIGH PERF MODE6
4
3
2
1
HIGH PERF
MODE6
HIGH PERF
MODE7
Bit 2
HIGH PERF MODE7
Bits[1:0]
Always write '0'
8.6.2.24 Register Address DBh (Default = 00h)
Figure 69. Register Address DBh (Default = 00h)
7
5
4
3
2
1
HIGH PERF
MODE80
LOW SPEED MODE CH B
Bits[7:6]
Always write '0'
Bit 5
HIGH PERF MODE8
Bits[4:1]
Always write '0'
Bit 0
LOW SPEED MODE CH B: Channel B low-speed mode enable
This bit enables the low-speed mode for channel B. Set the EN LOW SPEED MODE bit to '1'
0 = Low-speed mode is disabled for channel B
1 = Low-speed mode is enabled for channel B
46
ADS4229
www.ti.com
9 Application and Implementation
NOTE
Information in the following applications sections is not part of the TI component
specification, and TI does not warrant its accuracy or completeness. TI’s customers are
responsible for determining suitability of components for their purposes. Customers should
validate and test their design implementation to confirm system functionality.
9.1 Application Information
The ADS4229 dual-channel 12-bit ADC is designed for use in communications receivers designed to receive
modern communication signals such as LTE, WIMAX, W-CDMA, and high-order QAM signals. A typical diversity
receiver example is shown in Figure 70, where the antennas are placed at some distance to optimize
performance in the presence of multipath fading. The path includes a low noise amplifier (LNA), RF mixer, and a
digital variable gain amplifier (DVGA). Filtering is used throughout the path to remove blocking signals and
mixing products and to prevent aliasing during sampling.
LNA
RF Mixer
DVGA
ADS4229
Ch A
LO Source
Clock
ADS4229
Ch B
Figure 70. Diversity Communications Receiver
9.1.1 Theory of Operation
At every rising edge of the input clock, the analog input signal of each channel is simultaneously sampled. The
sampled signal in each channel is converted by a pipeline of low-resolution stages. In each stage, the
sampled/held signal is converted by a high-speed, low-resolution, flash sub-ADC. The difference between the
stage input and the quantized equivalent is gained and propagates to the next stage. At every clock, each
succeeding stage resolves the sampled input with greater accuracy. The digital outputs from all stages are
combined in a digital correction logic block and digitally processed to create the final code after a data latency of
16 clock cycles. The digital output is available as either DDR LVDS or parallel CMOS and coded in either straight
offset binary or binary twos complement format. The dynamic offset of the first stage sub-ADC limits the
maximum analog input frequency to approximately 400 MHz (with 2-VPP amplitude) or approximately 600 MHz
(with 1-VPP amplitude).
47
ADS4229
www.ti.com
Application Information (continued)
9.1.2 Analog Input
The analog input consists of a switched-capacitor-based, differential sample-and-hold (S/H) architecture. This
differential topology results in very good ac performance even for high input frequencies at high sampling rates.
The INP and INM pins must be externally biased around a common-mode voltage of 0.95 V, available on the
VCM pin. For a full-scale differential input, each input pin (INP and INM) must swing symmetrically between
VCM + 0.5 V and VCM – 0.5 V, resulting in a 2-VPP differential input swing. The input sampling circuit has a high
3-dB bandwidth that extends up to 550 MHz (measured from the input pins to the sampled voltage). Figure 71
shows an equivalent circuit for the analog input.
Sampling
Switch
LPKG
2 nH
INP
10 W
CBOND
1 pF
100 W
RESR
200 W
CPAR2 RON
1 pF 15 W
CSAMP
2 pF
3 pF
3 pF
LPKG
2 nH
INM
Sampling
Capacitor
RCR Filter
10 W
CBOND
1 pF
CPAR1
0.5 pF
RON
10 W
100 W
RON
15 W
CPAR2
1 pF
RESR
200 W
CSAMP
2 pF
Sampling
Capacitor
Sampling
Switch
Figure 71. Analog Input Equivalent Circuit
9.1.2.1 Drive Circuit Requirements
For optimum performance, the analog inputs must be driven differentially. This operation improves the commonmode noise immunity and even-order harmonic rejection. A 5-Ω to 15-Ω resistor in series with each input pin is
recommended to damp out ringing caused by package parasitics.
SFDR performance can be limited as a result of several reasons, including the effects of sampling glitches;
nonlinearity of the sampling circuit; and nonlinearity of the quantizer that follows the sampling circuit. Depending
on the input frequency, sample rate, and input amplitude, one of these factors generally plays a dominant part in
limiting performance. At very high input frequencies (greater than approximately 300 MHz), SFDR is determined
largely by the device sampling circuit nonlinearity. At low input amplitudes, the quantizer nonlinearity usually
limits performance.
Glitches are caused by the opening and closing of the sampling switches. The driving circuit should present a
low source impedance to absorb these glitches. Otherwise, glitches could limit performance, primarily at low
input frequencies (up to approximately 200 MHz). It is also necessary to present low impedance (less than 50 Ω)
for the common-mode switching currents. This configuration can be achieved by using two resistors from each
input terminated to the common-mode voltage (VCM pin).
The device includes an internal R-C filter from each input to ground. The purpose of this filter is to absorb the
sampling glitches inside the device itself. The cutoff frequency of the R-C filter involves a trade-off. A lower cutoff
frequency (larger C) absorbs glitches better, but it reduces the input bandwidth. On the other hand, with a higher
cutoff frequency (smaller C), bandwidth support is maximized. However, the sampling glitches must then be
supplied by the external drive circuit. This tradeoff has limitations as a result of the presence of the package
bond-wire inductance.
48
ADS4229
www.ti.com
In the ADS4229, the R-C component values have been optimized while supporting high input bandwidth (up to
550 MHz). However, in applications with input frequencies up to 200 MHz to 300 MHz, the filtering of the glitches
can be improved further using an external R-C-R filter; see Figure 74 and Figure 75.
In addition, the drive circuit may have to be designed to provide a low insertion loss over the desired frequency
range and matched impedance to the source. Furthermore, the ADC input impedance must be considered.
Figure 72 and Figure 73 show the impedance (ZIN = RIN || CIN) looking into the ADC input pins.
5
Differential Input Capacitance (pF)
Differential Input Resistance (kW)
100
10
1
0.1
4.5
4
3.5
3
2.5
2
1.5
0.01
1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
Input Frequency (GHz)
Figure 72. ADC Analog Input Resistance (RIN) Across
Frequency
Figure 73. ADC Analog Input Capacitance (CIN) Across
Frequency
9.1.2.2 Driving Circuit
Figure 74, Figure 75, and Figure 76 show examples of driving circuit configurations optimized for low bandwidth
(to support low input frequencies), high bandwidth (to support higher input frequencies), and very high
bandwidth, respectively. Note that each of the drive circuits has been terminated by 50 Ω near the ADC side. The
transformers (such as ADTL1-1WT or WBC1-1) can be used up to 270 MHz IF. For very high IF (> 270 MHz),
transformer ADTL2-18 can be used. The termination is accomplished by a 25-Ω resistor from each input to the
0.95-V common-mode (VCM) from the device. This architecture allows the analog inputs to be biased around the
required common-mode voltage.
The mismatch in the transformer parasitic capacitance (between the windings) results in degraded even-order
harmonic performance. Connecting two identical RF transformers back-to-back helps minimize this mismatch;
good performance is obtained for high-frequency input signals. An optional termination resistor pair may be
required between the two transformers, as shown in Figure 74, Figure 75, and Figure 76. The center point of this
termination is connected to ground to improve the balance between the P and M sides. The values of the
terminations between the transformers and on the secondary side must be chosen to obtain an effective 50 Ω (in
the case of 50-Ω source impedance).
0.1 mF
T1
5W
INx_P
T2
0.1 mF
0.1 mF
25 W
25 W
3.3 pF
25 W
RIN
CIN
25 W
INx_M
1:1
1:1
0.1 mF
5W
VCM
Device
Figure 74. Drive Circuit With Low Bandwidth (for Low Input Frequencies Less Than 150 MHz)
49
ADS4229
www.ti.com
0.1 mF
T1
5W
INx_P
T2
0.1 mF
0.1 mF
25 W
50 W
3.3 pF
25 W
RIN
CIN
50 W
INx_M
1:1
1:1
5W
0.1 mF
VCM
Device
Figure 75. Drive Circuit With High Bandwidth (for High Input Frequencies Greater Than 150 MHz and
Less Than 270 MHz)
0.1 mF
T1
5W
INx_P
T2
0.1 mF
0.1 mF
25 W
RIN
CIN
25 W
INx_M
1:1
1:1
5W
0.1 mF
VCM
Device
Figure 76. Drive Circuit With Very High Bandwidth (Greater Than 270 MHz)
All of these examples show 1:1 transformers being used with a 50-Ω source. As explained in the Drive Circuit
Requirements section, this configuration helps to present a low source impedance to absorb the sampling
glitches. With a 1:4 transformer, the source impedance is 200 Ω. The higher source impedance is unable to
absorb the sampling glitches effectively and can lead to degradation in performance (compared to using 1:1
transformers).
In almost all cases, either a band-pass or low-pass filter is required to obtain the desired dynamic performance,
as shown in Figure 77. Such filters present low source impedance at the high frequencies corresponding to the
sampling glitch and help avoid performance losses associated with the high source impedance.
5W
T1
0.1 mF
Differential
Input Signal
Band-Pass
or
Low-Pass
Filter
0.1 mF
INx_P
100 W
RIN
CIN
100 W
INx_M
1:4
5W
VCM
Device
Figure 77. Drive Circuit With a 1:4 Transformer
50
ADS4229
www.ti.com
9.1.3 Clock Input
The ADS4229 clock inputs can be driven differentially (sine, LVPECL, or LVDS) or single-ended (LVCMOS), with
little or no difference in performance between them. The common-mode voltage of the clock inputs is set to VCM
using internal 5-kΩ resistors. This setting allows the use of transformer-coupled drive circuits for sine-wave clock
or ac-coupling for LVPECL and LVDS clock sources are shown in Figure 78, Figure 79, and Figure 80. The
internal clock buffer is shown in Figure 81.
0.1 mF
CLKP
Differential
Sine-Wave
Clock Input
RT
0.1 mF
CLKM
Device
(1)
RT = termination resister, if necessary.
Figure 78. Differential Sine-Wave Clock Driving Circuit
0.1 mF
Zo
CLKP
Typical LVDS
Clock Input
100 W
0.1 mF
Zo
CLKM
Device
Figure 79. LVDS Clock Driving Circuit
Zo
0.1 mF
CLKP
150 W
Typical LVPECL
Clock Input
100 W
Zo
0.1 mF
CLKM
Device
150 W
Figure 80. LVPECL Clock Driving Circuit
51
ADS4229
www.ti.com
Clock Buffer
LPKG
2 nH
20 W
CLKP
CBOND
1 pF
RESR
100 W
LPKG
2 nH
5 kW
CEQ
2 pF
20 W
CEQ
VCM
5 kW
CLKM
CBOND
1 pF
RESR
100 W
NOTE: CEQ is 1 pF to 3 pF and is the equivalent input capacitance of the clock buffer.
Figure 81. Internal Clock Buffer
A single-ended CMOS clock can be ac-coupled to the CLKP input, with CLKM connected to ground with a 0.1-μF
capacitor, as shown in Figure 82. For best performance, the clock inputs must be driven differentially, thereby
reducing susceptibility to common-mode noise. For high input frequency sampling, it is recommended to use a
clock source with very low jitter. Band-pass filtering of the clock source can help reduce the effects of jitter. There
is no change in performance with a non-50% duty cycle clock input.
0.1 mF
CMOS
Clock Input
CLKP
VCM
0.1 mF
CLKM
Device
Figure 82. Single-Ended Clock Driving Circuit
52
ADS4229
www.ti.com
9.2 Typical Application
An example schematic for a typical application of the ADS4229 is shown in Figure 83.
22 O
22 O
22 O
AVDD
SPI Controller
22 O
0.1
F
0.1
F
22 O
DRVDD
To FPGA
ADC
Driver
50 O
5O
0.1
F
0.1
F
50 O
5O
50 O
50 O
0.1
F
AVDD
0.1
F
LVPECL Clock
Driver
FPGA
0.1
F
240 O
240 O
100 O
0.1
F
50 O
50 O
5O
50 O
0.1
F
ADC
Driver
50 O
0.1
F
5O
To FPGA
0.1
F
0.1
F
AVDD
DRVDD
Figure 83. Example Schematic for ADS4229
9.2.1 Design Requirements
Example design requirements are listed in Table 11 for the ADC portion of the signal chain. These do not
necessary reflect the requirements of an actual system, but rather demonstrate why the ADS4229 may be
chosen for a system based on a set of requirements.
Table 11. Example Design Requirements for ADS4229
DESIGN PARAMETER
Sampling rate
Input frequency
SNR
SFDR
Input full scale voltage
Channel-to-channel isolation
Overload recovery time
Digital interface
Power consumption
EXAMPLE DESIGN REQUIREMENT
ADS4229 CAPABILITY
≥ 245.76 Msps to allow 80 MHz of unaliased bandwidth
Max sampling rate: 250 Msps
> 250 MHz to accommodate full 2nd nyquist zone
operation
Large signal –3 dB bandwidth: 400 MHz
> 65 dBFS at –1 dFBS, 170 MHz
69.8 dBFS at –1 dBFS, 170 MHz
> 75 dBc at –1 dFBS, 170 MHz
80 dBc at –1 dBFS, 170 MHz
2 Vpp
2 Vpp
< 80 dB
95 dB
< 3 clock cycles
1 clock cycle
Parallel LVDS
Parallel LVDS
< 300 mW per channel
273 mW per channel
53
ADS4229
www.ti.com
9.2.2 Detailed Design Procedure
9.2.2.1 Analog Input
The analog inputs of the ADS4229 are typically driven by a fully differential amplifier. The amplifier must have
sufficient bandwidth for the frequencies of interest. The noise and distortion performance of the amplifier will
affect the combined performance of the ADC and amplifier. The amplifier is often AC coupled to the ADC to allow
both the amplifier and ADC to operate at the optimal common mode voltages. It is possible to DC couple the
amplifier to the ADC if required. An alternate approach is to drive the ADC using transformers. DC coupling
cannot be used with the transformer approach.
9.2.2.2 Common Mode Voltage Output (VCM)
The common mode voltage output is shared between both ADC channels. To maintain optimal isolation, an LC
filter may need to be placed on the VCM node between the channels (not shown in schematic). At a minimum, a
bypass capacitor should be placed on the node that has sufficiently low impedance at the desired operating
frequencies. Note the VCM pin maximum output current in the electrical tables when using VCM in alternate
ways.
9.2.2.3 Clock Driver
The ADS4229 supports both LVDS and CMOS interfaces. The LVDS interface should be used for best
performance when operating at maximum sampling rate. The LVDS outputs can be connected directly to the
FPGA without any additional components. When using CMOS outputs resistors should be placed in series with
the outputs to reduce the output current spikes to limit the performance degradation. The resistors should be
large enough to limit current spikes but not so large as to significantly distort the digital output waveform. An
external CMOS buffer should be used when driving distances greater than a few inches to reduce ground bounce
within the ADC.
9.2.2.4 Digital Interface
within the ADC.
9.2.3 Application Curve
Power (dBFS)
Figure 83 shows the results of a 10-MHz LTE signal centered at 184.32 MHz captured by the ADS4229.
-20
-30
-40
-50
-60
-70
-80
-90
-100
-110
-120
-130
Ref. Power = –11.98 dFBS
24.576
49.152
73.728
Frequency (MHz)
98.304
122.88
D001
Lower Adj. = 69.92 dBc
Lower Alt. = 70.28 dBc
Upper Adj. = 69.92 dBc
Upper Alt. = 70.17 dBc
Figure 84. 10-MHz LTE Signal Captured by ADS4229
54
ADS4229
www.ti.com
10 Power Supply Recommendations
The ADS4229 has two power supplies, one analog (AVDD) and one digital (DRVDD) supply. Both supplies have
a nominal voltage of 1.8 V. The AVDD supply is noise sensitive and the digital supply is not.
10.1 Sharing DRVDD and AVDD Supplies
For best performance the AVDD supply should be driven by a low noise linear regulator (LDO) and separated
from the DRVDD supply. It is possible to have AVDD and DRVDD share a single supply but they should be
isolated by a ferrite bead and bypass capacitors, in a PI-filter configuration, at a minimum. The digital noise will
be concentrated at the sampling frequency and harmonics of the sampling frequency and could contain noise
related to the sampled signal. While developing schematics, it is a good idea to leave extra placeholders for
additional supply filtering.
10.2 Using DC/DC Power Supplies
10.3 Power Supply Bypassing
Because the ADS4229 already includes internal decoupling, minimal external decoupling can be used without
loss in performance. Note that decoupling capacitors can help filter external power-supply noise; thus, the
optimum number of capacitors depends on the actual application. A 0.1-uF capacitor is recommended near each
supply pin. The decoupling capacitors should be placed very close to the converter supply pins.
11 Layout
11.1 Layout Guidelines
11.1.1 Grounding
A single ground plane is sufficient to give good performance, provided the analog, digital, and clock sections of
the board are cleanly partitioned. See the ADS4226 Evaluation Module (SLAU333) for details on layout and
grounding.
11.1.2 Exposed Pad
In addition to providing a path for heat dissipation, the PowerPAD is also electrically connected internally to the
digital ground. Therefore, it is necessary to solder the exposed pad to the ground plane for best thermal and
electrical performance. For detailed information, see application notes QFN Layout Guidelines (SLOA122) and
QFN/SON PCB Attachment (SLUA271).
11.1.3 Routing Analog Inputs
It is advisable to route differential analog input pairs (INP_x and INM_x) close to each other. To minimize the
possibility of coupling from a channel analog input to the sampling clock, the analog input pairs of both channels
should be routed perpendicular to the sampling clock; see the ADS4226 Evaluation Module (SLAU333) for
reference routing. Figure 85 shows a snapshot of the PCB layout from the ADS42xxEVM.
11.1.4 Routing Digital Outputs
The digital outputs should be routed away from the analog inputs and any noise sensitive circuits. Avoid routing
the digital outputs in parallel to any analog trace. The digital outputs should be routed over a solid ground plane
all the way to the FPGA. Keep the digital traces as short as possible to reduce EMI emissions. The traces should
be matched length to maintain timing, however mismatches in the trace lengths can be taken into account by
including the delay differences in the FPGA timing constraints.
55
ADS4229
www.ti.com
11.2 Layout Example
INP_A
INM_A
CLKP
CLKM
INP_B
INM_B
ADS42xx
Channel B
Channel A
Clock
Figure 85. ADS42xxEVM PCB Layout
56
ADS4229
www.ti.com
12 Device and Documentation Support
12.1 Device Support
12.1.1 Development Support
12.1.1.1 Definition of Specifications
Analog Bandwidth – The analog input frequency at which the power of the fundamental is reduced by 3 dB with
respect to the low-frequency value.
Aperture Delay – The delay in time between the rising edge of the input sampling clock and the actual time at
which the sampling occurs. This delay is different across channels. The maximum variation is specified as
aperture delay variation (channel-to-channel).
Aperture Uncertainty (Jitter) – The sample-to-sample variation in aperture delay.
Clock Pulse Width/Duty Cycle – The duty cycle of a clock signal is the ratio of the time the clock signal remains
at a logic high (clock pulse width) to the period of the clock signal. Duty cycle is typically expressed as a
percentage. A perfect differential sine-wave clock results in a 50% duty cycle.
Maximum Conversion Rate – The maximum sampling rate at which specified operation is given. All parametric
testing is performed at this sampling rate unless otherwise noted.
Minimum Conversion Rate – The minimum sampling rate at which the ADC functions.
Differential Nonlinearity (DNL) – An ideal ADC exhibits code transitions at analog input values spaced exactly
1LSB apart. The DNL is the deviation of any single step from this ideal value, measured in units of LSBs.
Integral Nonlinearity (INL) – The INL is the deviation of the ADC transfer function from a best fit line determined
by a least squares curve fit of that transfer function, measured in units of LSBs.
Gain Error – Gain error is the deviation of the ADC actual input full-scale range from its ideal value. The gain
error is given as a percentage of the ideal input full-scale range. Gain error has two components: error as a
result of reference inaccuracy (EGREF) and error as a result of the channel (EGCHAN). Both errors are specified
independently as EGREF and EGCHAN.
To a first-order approximation, the total gain error is ETOTAL ~ EGREF + EGCHAN.
For example, if ETOTAL = ±0.5%, the full-scale input varies from (1 – 0.5/100) x FSideal to (1 + 0.5/100) x FSideal.
Offset Error – The offset error is the difference, given in number of LSBs, between the ADC actual average idle
channel output code and the ideal average idle channel output code. This quantity is often mapped into millivolts.
Temperature Drift – The temperature drift coefficient (with respect to gain error and offset error) specifies the
change per degree Celsius of the parameter from TMIN to TMAX. It is calculated by dividing the maximum deviation
of the parameter across the TMIN to TMAX range by the difference TMAX – TMIN.
Signal-to-Noise Ratio – SNR is the ratio of the power of the fundamental (PS) to the noise floor power (PN),
excluding the power at dc and the first nine harmonics.
SNR = 10Log10
PS
PN
(2)
SNR is either given in units of dBc (dB to carrier) when the absolute power of the fundamental is used as the
reference, or dBFS (dB to full-scale) when the power of the fundamental is extrapolated to the converter fullscale range.
Signal-to-Noise and Distortion (SINAD) – SINAD is the ratio of the power of the fundamental (PS) to the power
of all the other spectral components including noise (PN) and distortion (PD), but excluding dc.
SINAD = 10Log10
PS
PN + PD
(3)
57
ADS4229
www.ti.com
Device Support (continued)
SINAD is either given in units of dBc (dB to carrier) when the absolute power of the fundamental is used as the
Effective Number of Bits (ENOB) – ENOB is a measure of the converter performance as compared to the
theoretical limit based on quantization noise.
ENOB =
SINAD - 1.76
6.02
(4)
Total Harmonic Distortion (THD) – THD is the ratio of the power of the fundamental (PS) to the power of the
first nine harmonics (PD).
THD = 10Log10
PS
PN
(5)
THD is typically given in units of dBc (dB to carrier).
Spurious-Free Dynamic Range (SFDR) – The ratio of the power of the fundamental to the highest other
spectral component (either spur or harmonic). SFDR is typically given in units of dBc (dB to carrier).
Two-Tone Intermodulation Distortion – IMD3 is the ratio of the power of the fundamental (at frequencies f1
and f2) to the power of the worst spectral component at either frequency 2f1 – f2 or 2f2 – f1. IMD3 is either given
in units of dBc (dB to carrier) when the absolute power of the fundamental is used as the reference, or dBFS (dB
to full-scale) when the power of the fundamental is extrapolated to the converter full-scale range.
DC Power-Supply Rejection Ratio (DC PSRR) – DC PSSR is the ratio of the change in offset error to a change
in analog supply voltage. The dc PSRR is typically given in units of mV/V.
AC Power-Supply Rejection Ratio (AC PSRR) – AC PSRR is the measure of rejection of variations in the
supply voltage by the ADC. If ΔVSUP is the change in supply voltage and ΔVOUT is the resultant change of the
ADC output code (referred to the input), then:
DVOUT
PSRR = 20Log 10
(Expressed in dBc)
DVSUP
(6)
Voltage Overload Recovery – The number of clock cycles taken to recover to less than 1% error after an
overload on the analog inputs. This is tested by separately applying a sine wave signal with 6 dB positive and
negative overload. The deviation of the first few samples after the overload (from the expected values) is noted.
Common-Mode Rejection Ratio (CMRR) – CMRR is the measure of rejection of variation in the analog input
common-mode by the ADC. If ΔVCM_IN is the change in the common-mode voltage of the input pins and ΔVOUT is
the resulting change of the ADC output code (referred to the input), then:
DVOUT
CMRR = 20Log10
(Expressed in dBc)
DVCM
(7)
Crosstalk (only for multi-channel ADCs) – This is a measure of the internal coupling of a signal from an
adjacent channel into the channel of interest. It is specified separately for coupling from the immediate
neighboring channel (near-channel) and for coupling from channel across the package (far-channel). It is usually
measured by applying a full-scale signal in the adjacent channel. Crosstalk is the ratio of the power of the
coupling signal (as measured at the output of the channel of interest) to the power of the signal applied at the
adjacent channel input. It is typically expressed in dBc.
12.2 Documentation Support
12.2.1 Related Documentation
For related documentation see the following:
• QFN Layout Guidelines (SLOA122)
• QFN/SON PCB Attachment (SLUA271)
• ADS4226 Evaluation Module (SLAU333)
58
ADS4229
www.ti.com
12.3 Community Resources
The following links connect to TI community resources. Linked contents are provided "AS IS" by the respective
contributors. They do not constitute TI specifications and do not necessarily reflect TI's views; see TI's Terms of
Use.
TI E2E™ Online Community TI's Engineer-to-Engineer (E2E) Community. Created to foster collaboration
among engineers. At e2e.ti.com, you can ask questions, share knowledge, explore ideas and help
solve problems with fellow engineers.
Design Support TI's Design Support Quickly find helpful E2E forums along with design support tools and
contact information for technical support.
12.4 Trademarks
PowerPAD, E2E are trademarks of Texas Instruments.
All other trademarks are the property of their respective owners.
12.5 Electrostatic Discharge Caution
These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam
during storage or handling to prevent electrostatic damage to the MOS gates.
12.6 Glossary
SLYZ022 — TI Glossary.
This glossary lists and explains terms, acronyms, and definitions.
13 Mechanical, Packaging, and Orderable Information
The following pages include mechanical, packaging, and orderable information. This information is the most
current data available for the designated devices. This data is subject to change without notice and revision of
this document. For browser-based versions of this data sheet, refer to the left-hand navigation.
59
PACKAGE OPTION ADDENDUM
www.ti.com
3-Oct-2023
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
Device Marking
(3)
Samples
(4/5)
(6)
ADS4229IRGCR
ACTIVE
VQFN
RGC
64
2000
RoHS & Green
NIPDAUAG
Level-3-260C-168 HR
-40 to 85
AZ4229
Samples
ADS4229IRGCT
ACTIVE
VQFN
RGC
64
250
RoHS & Green
NIPDAUAG
Level-3-260C-168 HR
-40 to 85
AZ4229
Samples
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
