Product
Folder
Sample &
Buy
Support &
Community
Tools &
Software
Technical
Documents
SN74LVCR2245A
SCAS581N – NOVEMBER 1996 – REVISED NOVEMBER 2014
SN74LVCR2245A Octal Bus Transceiver with 3-State Outputs
1 Features
2 Applications
1
Operates From 1.65 V to 3.6 V
Inputs Accept Voltages to 5.5 V
Max tpd of 6.3 ns at 3.3 V
All Outputs Have Equivalent 26-Ω Series
Resistors, So No External Resistors are Required
Typical VOLP (Output Ground Bounce)
< 0.8 V at VCC = 3.3 V, TA = 25°C
Typical VOHV (Output VOH Undershoot)
> 2 V at VCC = 3.3 V, TA = 25°C
Supports Mixed-Mode Signal Operation on
All Ports (5-V Input/Output Voltage
With 3.3-V VCC)
Ioff Supports Live Insertion, Partial-Power-Down
Mode, and Back-Drive Protection
Latch-Up Performance Exceeds 250 mA
Per JESD 17
ESD Protection Exceeds JESD 22
– 2000-V Human-Body Model
– 1000-V Charged-Device Model
Wearable Health and Fitness Devices
Network Switches
Servers
Tests and Measurements
3 Description
The SN74LVCR2245A device is an octal bus
transceiver is designed for 1.65-V to 3.6-V VCC
operation.
Device Information(1)
PART NUMBER
SN74LVCR2245A
PACKAGE
BODY SIZE (NOM)
SSOP (20)
8.65 mm × 3.90 mm
TVSSOP (20)
5.00 mm × 4.40 mm
VQFN (20)
4.50 mm × 3.50 mm
SOIC (20)
12.80 mm × 7.50 mm
TSSOP (20)
6.50 mm × 4.40 mm
(1) For all available packages, see the orderable addendum at
the end of the data sheet.
4 Simplified Schematic
DIR
OE
A1
B1
To Seven Other Channels
1
An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications,
intellectual property matters and other important disclaimers. PRODUCTION DATA.
SN74LVCR2245A
www.ti.com
Table of Contents
1
2
3
4
5
6
7
8
Features ..................................................................
Applications ...........................................................
Description .............................................................
Simplified Schematic.............................................
Revision History.....................................................
Pin Configuration and Functions .........................
Specifications.........................................................
1
1
1
1
2
3
5
7.1
7.2
7.3
7.4
7.5
7.6
7.7
7.8
7.9
5
5
6
6
7
7
8
8
8
Absolute Maximum Ratings ......................................
Handling Ratings ......................................................
Recommended Operating Conditions.......................
Thermal Information ..................................................
Electrical Characteristics...........................................
Switching Characteristics, –40°C to 85°C.................
Switching Characteristics, –40°C to 125°C...............
Operating Characteristics..........................................
Typical Characteristics ..............................................
Parameter Measurement Information .................. 9
9
Detailed Description ............................................ 10
9.1
9.2
9.3
9.4
Overview .................................................................
Functional Block Diagram .......................................
Feature Description.................................................
Device Functional Modes........................................
10
10
10
10
10 Application and Implementation........................ 11
10.1 Application Information.......................................... 11
10.2 Typical Application ............................................... 11
11 Power Supply Recommendations ..................... 12
12 Layout................................................................... 12
12.1 Layout Guidelines ................................................. 12
12.2 Layout Example .................................................... 12
13 Device and Documentation Support ................. 13
13.1 Trademarks ........................................................... 13
13.2 Electrostatic Discharge Caution ............................ 13
13.3 Glossary ................................................................ 13
14 Mechanical, Packaging, and Orderable
Information ........................................................... 13
5 Revision History
Changes from Revision M (March 2005) to Revision N
Page
Added Applications, Device Information table, Pin Functions table, Handling Ratings table, Thermal Information
table, Typical Characteristics, Feature Description section, Device Functional Modes, Application and
Implementation section, Power Supply Recommendations section, Layout section, Device and Documentation
Support section, and Mechanical, Packaging, and Orderable Information section................................................................ 1
Deleted Ordering Information table. ....................................................................................................................................... 1
Changed Ioff bullet in Features section. .................................................................................................................................. 1
Changed MAX operating temperature to 125°C in Recommended Operating Conditions table. ......................................... 6
Added –40°C to 125°C temperature range to Electrical Characteristics table. ...................................................................... 7
Changed Switching Characteristics, –40°C to 85°C table. .................................................................................................... 7
Added Switching Characteristics, –40°C to 125°C table. ...................................................................................................... 8
2
Submit Documentation Feedback
Copyright © 1996–2014, Texas Instruments Incorporated
Product Folder Links: SN74LVCR2245A
SN74LVCR2245A
www.ti.com
6 Pin Configuration and Functions
DB, DBQ, DGV, DW, NS, OR PW PACKAGE
(TOP VIEW)
3
18
4
17
5
16
6
15
7
14
8
13
9
12
10
11
VCC
OE
B1
B2
B3
B4
B5
B6
B7
B8
A1
A2
A3
A4
A5
A6
A7
A8
VCC
19
1
19 OE
3
18 B1
4
17 B2
16 B3
15 B4
5
6
14 B5
13 B6
7
8
12 B7
9
10
11
B8
DIR
1
GND
DIR
A1
A2
A3
A4
A5
A6
A7
A8
GND
RGY PACKAGE
(TOP VIEW)
Pin Functions
PIN
NO.
NAME
TYPE
DESCRIPTION
1
DIR
I
2
A1
I/O
A1 Input or Output
3
A2
I/O
A2 Input or Output
4
A3
I/O
A3 Input or Output
5
A4
I/O
A4 Input or Output
6
A5
I/O
A5 Input or Output
7
A6
I/O
A6 Input or Output
8
A7
I/O
A7 Input or Output
9
A8
I/O
A8 Input or Output
10
GND
Ground Pin
11
B8
I/O
B8 Input or Output
12
B7
I/O
B7 Input or Output
13
B6
I/O
B6 Input or Output
14
B5
I/O
B5 Input or Output
15
B4
I/O
B4 Input or Output
16
B3
I/O
B3 Input or Output
17
B2
I/O
B2 Input or Output
18
B1
I/O
B1 Input or Output
19
OE
I
VCC
Direction Pin
Output Enable
Power Pin
3
SN74LVCR2245A
www.ti.com
GQN OR ZQN PACKAGE
(TOP VIEW)
1
2
3
4
A
B
C
D
E
Table 1. Pin Assignments
4
1
2
3
4
A
A1
DIR
VCC
OE
B
A3
B2
A2
B1
C
A5
A4
B4
B3
D
A7
B6
A6
B5
E
GND
A8
B8
B7
SN74LVCR2245A
www.ti.com
7 Specifications
7.1 Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted) (1)
VCC
MIN
MAX
Supply voltage range
–0.5
6.5
UNIT
V
(2)
VI
Input voltage range
–0.5
6.5
V
VO
Voltage range applied to any output in the high-impedance or power-off state (2)
–0.5
6.5
V
VO
Voltage range applied to any output in the high or low state (2)
–0.5
VCC + 0.5
V
IIK
Input clamp current
VI < 0
–50
mA
IOK
Output clamp current
VO < 0
–50
mA
IO
Continuous output current
±50
mA
±100
mA
(3)
Continuous current through VCC or GND
(1)
(2)
(3)
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating
Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
The input negative-voltage and output voltage ratings may be exceeded if the input and output current ratings are observed.
The value of VCC is provided in the Recommended Operating Conditions table.
7.2 Handling Ratings
Tstg
V(ESD)
(1)
(2)
MIN
MAX
UNIT
–65
150
°C
Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all
pins (1)
Charged device model (CDM), per JEDEC specification
JESD22-C101, all pins (2)
Storage temperature range
Electrostatic discharge
V
JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process.
JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
5
SN74LVCR2245A
www.ti.com
7.3 Recommended Operating Conditions
VCC
Supply voltage
VIH
High-level input voltage
Operating
Data retention only
MIN
MAX
1.65
3.6
1.5
VCC = 1.65 V to 1.95 V
Low-level input voltage
VI
Input voltage
1.7
VCC = 2.7 V to 3.6 V
2
Output voltage
IOH
High-level output current
0.7
Low-level output current
Δt/Δv
Input transition rise or fall rate
TA
Operating free-air temperature
5.5
High or low state
VCC
3-state
VCC = 1.65 V
–2
VCC = 2.3 V
–4
VCC = 2.7 V
–8
V
V
mA
–12
VCC = 1.65 V
2
VCC = 2.3 V
4
VCC = 2.7 V
8
VCC = 3 V
(1)
V
0.8
VCC = 3 V
IOL
V
0.35 × VCC
VCC = 2.3 V to 2.7 V
VO
V
0.65 × VCC
VIL
UNIT
mA
12
–40
10
ns/V
125
°C
All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report,
Implications of Slow or Floating CMOS Inputs (SCBA004).
7.4 Thermal Information
THERMAL METRIC (1)
DW
DBQ
DGV
DB
NS
PW
RGY
RθJA
Junction-to-ambient thermal resistance
88.3
94.7
114.7
94.5
74.7
102.5
41.4
RθJC(top)
Junction-to-case (top) thermal
resistance
51.1
47.9
29.8
56.2
40.5
35.9
47.7
RθJB
Junction-to-board thermal resistance
50.9
45.0
56.2
49.7
42.3
53.5
17.1
ψJT
Junction-to-top characterization
parameter
20.0
11.0
0.8
18.1
14.3
2.2
1.4
ψJB
Junction-to-board characterization
parameter
50.5
44.6
55.5
49.2
41.9
52.9
17.1
RθJC(bot)
Junction-to-case (bottom) thermal
resistance
9.8
(1)
6
UNIT
°C/W
For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report (SPRA953).
SN74LVCR2245A
www.ti.com
7.5 Electrical Characteristics
over recommended operating free-air temperature range (unless otherwise noted)
PARAMET
ER
TEST CONDITIONS
1.65 V to
3.6 V
IOZ
(2)
UNIT
2.3 V
1.7
1.7
1.7
2.7 V
2.2
2.2
2.2
IOH = –6 mA
3V
2.4
2.4
2.4
IOH = –8 mA
2.7 V
2
2
2
IOH = –12 mA
3V
2
2
2
IOL = 100 μA
1.65 V to
3.6 V
0.2
0.2
0.2
1.65 V
0.45
0.45
0.45
2.3 V
0.7
0.7
0.7
2.7 V
0.4
0.4
0.4
IOL = 6 mA
3V
0.55
0.55
0.55
IOL = 8 mA
2.7 V
0.6
0.6
0.6
IOL = 12 mA
3V
0.8
0.8
0.8
3.6 V
±5
±5
±5
μA
VI or VO = 5.5 V
±10
±10
±10
μA
VO = 0 to 5.5 V
3.6 V
±10
±10
±10
μA
10
10
10
10
10
10
500
500
500
VI = 0 to 5.5 V
IO = 0
One input at VCC – 0.6 V,
Other inputs at VCC or GND
Ci
Contr
ol
inputs
Cio
A or B
VO = VCC or GND
ports
(1)
(2)
(3)
MAX
1.2
3.6 V ≤ VI ≤ 5.5 V (3)
ΔICC
MIN TYP (1)
MAX
1.2
VI = VCC or GND
ICC
MIN TYP
–40°C to 125°C
1.2
IOL = 4 mA
Ioff
MAX
(1)
1.65 V
IOL = 2 mA
Contr
ol
inputs
–40°C to 85°C
VCC –
0.2
IOH = –4 mA
II
MIN TYP
(1)
VCC –
0.2
IOH = –2 mA
VOL
TA = 25°C
VCC –
0.2
IOH = –100 μA
VOH
VCC
VI = VCC or GND
3.6 V
2.7 V to
3.6 V
V
V
μA
μA
3.3 V
4
pF
3.3 V
5.5
pF
All typical values are at VCC = 3.3 V, TA = 25°C.
For I/O ports, the parameter IOZ includes the input leakage current.
This applies in the disabled state only.
7.6 Switching Characteristics, –40°C to 85°C
over recommended operating free-air temperature range (unless otherwise noted) (see Figure 3)
FROM
(INPUT)
TO
(OUTPUT)
tpd
A or B
B or A
ten
OE
tdis
OE
PARAMETER
VCC = 1.8 V
± 0.15 V
MAX
MIN
VCC = 3.3 V
± 0.3 V
VCC = 2.7 V
UNIT
MAX
MIN
MAX
MIN
MAX
10.9
7.9
1
7.3
1.5
6.3
ns
A or B
12.6
9.6
1
9.5
1.5
8.2
ns
A or B
12.1
7.8
1
8.5
1.7
7.8
ns
1
1
1
ns
tsk(o)
MIN
VCC = 2.5 V
± 0.2 V
1
7
SN74LVCR2245A
www.ti.com
7.7 Switching Characteristics, –40°C to 125°C
VCC = 1.8 V
± 0.15 V
VCC = 2.5 V
± 0.2 V
FROM
(INPUT)
TO
(OUTPUT)
tpd
A or B
B or A
12.4
ten
OE
A or B
14.1
tdis
OE
A or B
13.6
1
PARAMETER
MIN
MAX
tsk(o)
MIN
VCC = 3.3 V
± 0.3 V
VCC = 2.7 V
MAX
MIN
UNIT
MAX
MIN
MAX
10
8.3
1.5
7.3
ns
11.7
10.5
1.5
9.2
ns
9.9
9.5
1.7
8.8
ns
1
1
1.5
ns
7.8 Operating Characteristics
TA = 25°C
TEST
CONDITIONS
PARAMETER
Outputs enabled
Power dissipation capacitance
per transceiver
Cpd
Outputs disabled
VCC = 1.8 V
VCC = 2.5 V
VCC = 3.3 V
TYP
TYP
TYP
43
43
48
1
1
4
f = 10 MHz
UNIT
pF
7.9 Typical Characteristics
4
6
TPD in ns
3.5
5
3
TPD (ns)
TPD (ns)
4
3
2.5
2
1.5
2
1
1
0.5
TPD in ns
1
1.5
2
VCC (V)
2.5
3
-50
D002
Figure 1. TPD Across VCC at 25°C
8
3.5
Temperature (qC)
100
150
D001
Figure 2. TPD Across Temperature at 3.3 V
SN74LVCR2245A
www.ti.com
8 Parameter Measurement Information
VLOAD
S1
RL
From Output
Under Test
CL
(see Note A)
Open
GND
RL
TEST
S1
tPLH/tPHL
tPLZ/tPZL
tPHZ/tPZH
Open
VLOAD
GND
LOAD CIRCUIT
INPUTS
VCC
1.8 V ± 0.15 V
2.5 V ± 0.2 V
2.7 V
3.3 V ± 0.3 V
VI
tr/tf
VCC
VCC
2.7 V
2.7 V
≤2 ns
≤2 ns
≤2.5 ns
≤2.5 ns
VM
VLOAD
CL
RL
V∆
VCC/2
VCC/2
1.5 V
1.5 V
2 × VCC
2 × VCC
6V
6V
30 pF
30 pF
50 pF
50 pF
1 kΩ
500 Ω
500 Ω
500 Ω
0.15 V
0.15 V
0.3 V
0.3 V
VI
Timing Input
VM
0V
tw
tsu
VI
Input
VM
VM
th
VI
Data Input
VM
VM
0V
0V
VOLTAGE WAVEFORMS
PULSE DURATION
VOLTAGE WAVEFORMS
SETUP AND HOLD TIMES
VI
VM
Input
VM
0V
VOH
VM
Output
VM
VOL
VM
0V
VLOAD/2
VM
tPZH
VOH
Output
VM
tPLZ
Output
Waveform 1
S1 at VLOAD
(see Note B)
tPLH
tPHL
VM
tPZL
tPHL
tPLH
VI
Output
Control
VM
VOL
VOLTAGE WAVEFORMS
PROPAGATION DELAY TIMES
INVERTING AND NONINVERTING OUTPUTS
VOL + V∆
VOL
tPHZ
Output
Waveform 2
S1 at GND
(see Note B)
VM
VOH − V∆
VOH
≈0 V
VOLTAGE WAVEFORMS
ENABLE AND DISABLE TIMES
LOW- AND HIGH-LEVEL ENABLING
NOTES: A. CL includes probe and jig capacitance.
B. Waveform 1 is for an output with internal conditions such that the output is low, except when disabled by the output control.
Waveform 2 is for an output with internal conditions such that the output is high, except when disabled by the output control.
C. All input pulses are supplied by generators having the following characteristics: PRR≤ 10 MHz, ZO = 50 Ω.
D. The outputs are measured one at a time, with one transition per measurement.
E. tPLZ and t PHZ are the same as tdis .
F. t PZL and t PZH are the same as ten .
G. tPLH and t PHL are the same as tpd .
H. All parameters and waveforms are not applicable to all devices.
Figure 3. Load Circuit and Voltage Waveforms
9
SN74LVCR2245A
www.ti.com
9 Detailed Description
9.1 Overview
This octal bus transceiver is designed for 1.65-V to 3.6-V VCC operation.
The SN74LVCR2245A device is designed for asynchronous communication between data buses. The device
transmits data from the A bus to the B bus or from the B bus to the A bus, depending on the logic level at the
direction-control (DIR) input. The output-enable (OE) input can be used to disable the device so the buses are
effectively isolated.
All outputs, which are designed to sink up to 12 mA, include equivalent 26-Ω resistors to reduce overshoot and
undershoot.
Inputs can be driven from either 3.3-V or 5-V devices. This feature allows the use of this device as a translator in
a mixed 3.3-V/5-V system environment.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs,
preventing damaging current backflow through the device when it is powered down.
To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pullup
resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
9.2 Functional Block Diagram
DIR
OE
A1
B1
Figure 4. Logic Diagram (Positive Logic)
9.3 Feature Description
Wide operating voltage range
– Operates from 1.65 V to 3.6 V
Allows down-voltage translation
– Inputs accept voltages to 5.5 V
Ioff feature
– Allows voltages on the inputs and outputs when VCC is 0 V
9.4 Device Functional Modes
Table 2. Function Table
INPUTS
10
OPERATION
OE
DIR
L
L
B data to A bus
L
H
A data to B bus
H
X
Isolation
SN74LVCR2245A
www.ti.com
This 8-bit octal noninverting bus transceiver is designed for 1.65-V to 3.6-V VCC operation. This device is fully
specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing
damaging current backflow through the device when it is powered down. To ensure the high-impedance state
during power up or power down, OE should be tied to VCC through a pullup resistor; the minimum value of the
Regulated 3.3 V
OE
VCC
DIR
A1
B1
A8
B8
µC or
system logic
µC
system logic
LEDs
GND
Figure 5. Typical Application Schematic
10.2.1 Design Requirements
This device uses CMOS technology and has balanced output drive. Care should be taken to avoid bus
contention because it can drive currents that would exceed maximum limits. The high drive will also create fast
edges into light loads, so routing and load conditions should be considered to prevent ringing.
10.2.2 Detailed Design Procedure
1. Recommended Input Conditions
– For rise time and fall time specifciations, see Δt/ΔV in the Recommended Operating Conditions table.
– For specified High and low levels, see VIH and VIL in the Recommended Operating Conditions table.
– Inputs are overvoltage tolerant allowing them to go as high as 5.5 V at any valid VCC.
2. Recommend Output Conditions
– Load currents should not exceed 50 mA per output and 100 mA total for the part.
– Outputs should not be pulled above VCC.
11
SN74LVCR2245A
www.ti.com
Typical Application (continued)
10.2.3 Application Curves
300
250
ICC (V)
200
150
100
ICC 1.8 V
ICC 2.5 V
ICC 3.3 V
50
40
Frequency (MHz)
50
60
D003
Figure 6. ICC vs Frequency
The power supply can be any voltage between the MIN and MAX supply voltage rating located in the
Each VCC pin should have a good bypass capacitor to prevent power disturbance. For devices with a single
supply, 0.1 μF is recommended. If there are multiple VCC pins, 0.01 μF or 0.022 μF is recommended for each
power pin. It is acceptable to parallel multiple bypass caps to reject different frequencies of noise. A 0.1 μF and
1 μF are commonly used in parallel. The bypass capacitor should be installed as close to the power pin as
possible for best results.
12 Layout
When using multiple bit logic devices, inputs should not float. In many cases, functions or parts of functions of
digital logic devices are unused. Some examples are when only two inputs of a triple-input AND gate are used,
or when only 3 of the 4-buffer gates are used. Such input pins should not be left unconnected because the
undefined voltages at the outside connections result in undefined operational states.
Specified in Figure 7 are rules that must be observed under all circumstances. All unused inputs of digital logic
devices must be connected to a high or low bias to prevent them from floating. The logic level that should be
applied to any particular unused input depends on the function of the device. Generally they will be tied to GND
or VCC, whichever makes more sense or is more convenient. It is acceptable to float outputs unless the part is a
transceiver. If the transceiver has an output enable pin, it will disable the outputs section of the part when
asserted. This will not disable the input section of the I/Os so they also cannot float when disabled.
12.2 Layout Example
Vcc
Unused Input
Input
Output
Unused Input
Output
Input
Figure 7. Layout Diagram
12
SN74LVCR2245A
www.ti.com
13.1 Trademarks
All trademarks are the property of their respective owners.
These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam
during storage or handling to prevent electrostatic damage to the MOS gates.
13.3 Glossary
SLYZ022 — TI Glossary.
This glossary lists and explains terms, acronyms, and definitions.
14 Mechanical, Packaging, and Orderable Information
The following pages include mechanical, packaging, and orderable information. This information is the most
current data available for the designated devices. This data is subject to change without notice and revision of
this document. For browser-based versions of this data sheet, refer to the left-hand navigation.
13
PACKAGE OPTION ADDENDUM
www.ti.com
20-Jan-2021
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
Device Marking
(3)
(4/5)
(6)
SN74LVCR2245ADBQR
ACTIVE
SSOP
DBQ
RoHS & Green
NIPDAU
Level-2-260C-1 YEAR
-40 to 125
LVCR2245A
SN74LVCR2245ADBR
ACTIVE
SSOP
DB
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LER245A
SN74LVCR2245ADGVR
ACTIVE
TVSOP
DGV
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LER245A
SN74LVCR2245ADW
ACTIVE
SOIC
DW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LVCR2245A
SN74LVCR2245ADWR
ACTIVE
SOIC
DW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LVCR2245A
SN74LVCR2245ANSR
ACTIVE
SO
NS
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LVCR2245A
SN74LVCR2245APW
ACTIVE
TSSOP
PW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LER245A
SN74LVCR2245APWE4
ACTIVE
TSSOP
PW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LER245A
SN74LVCR2245APWR
ACTIVE
TSSOP
PW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LER245A
SN74LVCR2245APWRE4
ACTIVE
TSSOP
PW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LER245A
SN74LVCR2245APWT
ACTIVE
TSSOP
PW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 125
LER245A
SN74LVCR2245ARGYR
ACTIVE
VQFN
RGY
RoHS & Green
NIPDAU
Level-2-260C-1 YEAR
-40 to 125
LER245A
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
