SN74LVT574DBR
SN74LVT574DBR
    ROCHESTER(罗切斯特)
    SSOP20_208MIL
    BUS DRIVER, LVT SERIES
SN74LVT574DBR 数据手册
SN54LVT574, SN74LVT574 3.3-V ABT OCTAL EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH 3-STATE OUTPUTS SCBS139D − MAY 1992 − REVISED JULY 1995 D D D D D D 1 20 2 19 3 18 4 17 5 16 6 15 7 14 8 13 9 12 10 11 VCC 1Q 2Q 3Q 4Q 5Q 6Q 7Q 8Q CLK SN54LVT574 . . . FK PACKAGE (TOP VIEW) 3D 4D 5D 6D 7D 1Q D OE 1D 2D 3D 4D 5D 6D 7D 8D GND 2D 1D OE VCC D Technology (ABT) Design for 3.3-V Operation and Low Static Power Dissipation Support Mixed-Mode Signal Operation (5-V Input and Output Voltages With 3.3-V VCC) Support Unregulated Battery Operation Down to 2.7 V Typical VOLP (Output Ground Bounce) < 0.8 V at VCC = 3.3 V, TA = 25°C ESD Protection Exceeds 2000 V Per MIL-STD-883C, Method 3015; Exceeds 200 V Using Machine Model (C = 200 pF, R = 0) Latch-Up Performance Exceeds 500 mA Per JEDEC Standard JESD-17 Bus-Hold Data Inputs Eliminate the Need for External Pullup Resistors Support Live Insertion Package Options Include Plastic Small-Outline (DW), Shrink Small-Outline (DB), and Thin Shrink Small-Outline (PW) Packages, Ceramic Chip Carriers (FK), Ceramic Flat (W) Packages, and Ceramic (J) DIPs SN54LVT574 . . . J OR W PACKAGE SN74LVT574 . . . DB, DW, OR PW PACKAGE (TOP VIEW) 4 3 2 1 20 19 18 5 17 6 16 7 15 8 14 9 10 11 12 13 2Q 3Q 4Q 5Q 6Q 8D GND CLK 8Q 7Q D State-of-the-Art Advanced BiCMOS description These octal flip-flops are designed specifically for low-voltage (3.3-V) VCC operation, but with the capability to provide a TTL interface to a 5-V system environment. The eight flip-flops of the ′LVT574 are edge-triggered D-type flip-flops. On the positive transition of the clock (CLK) input, the Q outputs are set to the logic levels set up at the data (D) inputs. A buffered output-enable (OE) input can be used to place the eight outputs in either a normal logic state (high or low logic levels) or a high-impedance state. In the high-impedance state, the outputs neither load nor drive the bus lines significantly. The high-impedance state and increased drive provide the capability to drive bus lines without need for interface or pullup components. OE does not affect the internal operations of the flip-flops. Old data can be retained or new data can be entered while the outputs are in the high-impedance state. Active bus-hold circuitry is provided to hold unused or floating data inputs at a valid logic level. To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver. The SN74LVT574 is available in TI’s shrink small-outline package (DB), which provides the same I/O pin count and functionality of standard small-outline packages in less than half the printed-circuit-board area. The SN54LVT574 is characterized for operation over the full military temperature range of −55°C to 125°C. The SN74LVT574 is characterized for operation from − 40°C to 85°C. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright © 1995, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 SN54LVT574, SN74LVT574 3.3-V ABT OCTAL EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH 3-STATE OUTPUTS SCBS139D − MAY 1992 − REVISED JULY 1995 FUNCTION TABLE (each flip-flop) INPUTS OE CLK D OUTPUT Q L ↑ H H L ↑ L L L H or L X Q0 H X X Z logic symbol† OE CLK 1D 2D 3D 4D 5D 6D 7D 8D † 1 11 2 logic diagram (positive logic) EN OE C1 1D 19 3 18 4 17 5 16 6 15 7 14 8 13 9 12 CLK 1 11 1Q C1 2Q 3Q 1D 2 19 1Q 1D 4Q 5Q 6Q 7Q To Seven Other Channels 8Q This symbol is in accordance with ANSI/IEEE Std 91-1984 and IEC Publication 617-12. absolute maximum ratings over operating free-air temperature range (unless otherwise noted)‡ Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.5 V to 4.6 V Input voltage range, VI (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.5 V to 7 V Voltage range applied to any output in the high state or power-off state, VO (see Note 1) . . . . −0.5 V to 7 V Current into any output in the low state, IO: SN54LVT574 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 96 mA SN74LVT574 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 128 mA Current into any output in the high state, IO (see Note 2): SN54LVT574 . . . . . . . . . . . . . . . . . . . . . . . . . 48 mA SN74LVT574 . . . . . . . . . . . . . . . . . . . . . . . . . 64 mA Input clamp current, IIK (VI < 0) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −50 mA Output clamp current, IOK (VO < 0) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −50 mA Maximum power dissipation at TA = 55°C (in still air) (see Note 3): DB package . . . . . . . . . . . . . . . . . . . . 0.6 W DW package . . . . . . . . . . . . . . . . . . . 1.6 W PW package . . . . . . . . . . . . . . . . . . . 0.7 W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −65°C to 150°C ‡ Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTES: 1. The input and output negative-voltage ratings may be exceeded if the input and output clamp-current ratings are observed. 2. This current flows only when the output is in the high state and VO > VCC. 3. The maximum package power dissipation is calculated using a junction temperature of 150°C and a board trace length of 750 mils. For more information, refer to the Package Thermal Considerations application note in the 1994 ABT Advanced BiCMOS Technology Data Book, literature number SCBD002B. 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN54LVT574, SN74LVT574 3.3-V ABT OCTAL EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH 3-STATE OUTPUTS SCBS139D − MAY 1992 − REVISED JULY 1995 recommended operating conditions (see Note 4) SN54LVT574 SN74LVT574 MIN MAX MIN MAX 2.7 3.6 2.7 3.6 UNIT VCC Supply voltage VIH High-level input voltage VIL Low-level input voltage 0.8 0.8 VI Input voltage 5.5 5.5 V IOH High-level output current −24 −32 mA IOL Low-level output current 48 64 mA Δt /Δv Input transition rise or fall rate 10 10 ns / V TA Operating free-air temperature 85 °C 2 Outputs enabled −55 2 125 −40 V V V NOTE 4: Unused control inputs must be held high or low to prevent them from floating. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 3 SN54LVT574, SN74LVT574 3.3-V ABT OCTAL EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH 3-STATE OUTPUTS SCBS139D − MAY 1992 − REVISED JULY 1995 electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) SN54LVT574 PARAMETER VIK VOH TEST CONDITIONS MIN TYP† SN74LVT574 MAX MIN VCC = 2.7 V, II = −18 mA VCC = MIN to MAX‡, IOH = −100 μA VCC −0.2 VCC −0.2 VCC = 2.7 V, IOH = − 8 mA 2.4 2.4 −1.2 IOH = − 24 mA VCC = 3 V VOL VCC = 3 V VCC = 0 or 6V VCC = 3 3.6 0.2 0.2 IOL = 24 mA 0.5 0.5 IOL = 16 mA 0.4 0.4 IOL = 32 mA 0.5 0.5 IOL = 48 mA 0.55 VI = 0 Ioff VCC = 0, Control inputs Data inputs 50 10 ±1 ±1 1 1 −5 −5 ± 100 VI or VO = 0 to 4.5 V VI = 0.8 V II(hold) VCC = 3 V IOZH VCC = 3.6 V, VO = 3 V IOZL VCC = 3.6 V, VO = 0.5 V ICC VCC = 3.6 V, VI = VCC or GND IO = 0, VI = 2 V V 0.55 VI = 5.5 V VI = VCC V 2 IOL = 100 μA VI = VCC or GND II UNIT V 2 IOL = 64 mA MAX‡, MAX −1.2 IOH = − 32 mA VCC = 2 2.7 7V TYP† Data inputs 75 75 −75 −75 μA μA A 1 1 μA −1 −1 μA Outputs high 0.13 0.39 0.13 0.19 Outputs low 8.7 14 8.7 12 0.13 0.39 0.13 0.19 Outputs disabled μA mA ΔICC§ VCC = 3 V to 3.6 V, One input at VCC − 0.6 V, Other inputs at VCC or GND Ci VI = 3 V or 0 4 4 pF Co VO = 3 V or 0 8 8 pF 0.3 0.2 mA † All typical values are at VCC = 3.3 V, TA = 25°C. ‡ For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions. § This is the increase in supply current for each input that is at the specified TTL voltage level rather than V CC or GND. timing requirements over recommended operating free-air temperature range (unless otherwise noted) (see Figure 1) SN54LVT574 VCC = 3.3 V ± 0.3 V fclock Clock frequency tw Pulse duration, CLK high or low tsu Setup time, data before CLK↑ th Hold time, data after CLK↑ 4 MIN MAX 0 150 SN74LVT574 VCC = 2.7 V MIN MAX 0 150 VCC = 3.3 V ± 0.3 V MIN MAX 0 150 VCC = 2.7 V MIN MAX 0 150 UNIT MHz 3.3 3.3 3.3 3.3 ns 2 2.4 2 2.4 ns 0.9 0.9 0.3 0 ns POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN54LVT574, SN74LVT574 3.3-V ABT OCTAL EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH 3-STATE OUTPUTS SCBS139D − MAY 1992 − REVISED JULY 1995 switching characteristics over recommended operating free-air temperature range, CL = 50 pF (unless otherwise noted) (see Figure 1) SN54LVT574 PARAMETER FROM (INPUT) TO (OUTPUT) VCC = 3.3 V ± 0.3 V MIN fmax tPLH tPHL tPZH tPZL tPHZ tPLZ † MAX 150 CLK Q OE Q OE Q SN74LVT574 VCC = 2.7 V MIN MAX 150 VCC = 3.3 V ± 0.3 V MIN TYP† VCC = 2.7 V MAX 150 MIN UNIT MAX 150 MHz 1 5.9 6.6 1.7 3.6 5.4 6.2 1 6.1 6.8 2.4 4.3 5.9 6.6 0.5 5.9 7.1 1 2.9 4.8 5.9 0.5 5.3 6.4 1.3 3.4 5.1 6.2 0.7 5.9 6.6 1.9 4 5.5 5.9 0.5 5.1 5.1 1.7 3.2 4.5 4.5 ns ns ns All typical values are at VCC = 3.3 V, TA = 25°C. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 5 SN54LVT574, SN74LVT574 3.3-V ABT OCTAL EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH 3-STATE OUTPUTS SCBS139D − MAY 1992 − REVISED JULY 1995 PARAMETER MEASUREMENT INFORMATION 6V S1 500 Ω From Output Under Test Open GND CL = 50 pF (see Note A) 500 Ω TEST S1 tPLH/tPHL tPLZ/tPZL tPHZ/tPZH Open 6V GND 2.7 V LOAD CIRCUIT FOR OUTPUTS 1.5 V Timing Input 0V tw tsu 2.7 V Input 1.5 V 1.5 V th 2.7 V 1.5 V Data Input 1.5 V 0V 0V VOLTAGE WAVEFORMS PULSE DURATION VOLTAGE WAVEFORMS SETUP AND HOLD TIMES 2.7 V 1.5 V Input 1.5 V 0V VOH 1.5 V Output 1.5 V VOL tPLH tPHL VOH Output 1.5 V 1.5 V VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES INVERTING AND NONINVERTING OUTPUTS 1.5 V 1.5 V 0V tPZL tPHL tPLH 2.7 V Output Control tPLZ Output Waveform 1 S1 at 6 V (see Note B) Output Waveform 2 S1 at GND (see Note B) 1.5 V tPZH 3V VOL + 0.3 V VOL tPHZ 1.5 V VOH − 0.3 V VOH [0V VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES LOW- AND HIGH-LEVEL ENABLING NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz, ZO = 50 Ω, tr ≤ 2.5 ns, tf ≤ 2.5 ns. D. The outputs are measured one at a time with one transition per measurement. Figure 1. Load Circuit and Voltage Waveforms 6 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 PACKAGE OPTION ADDENDUM www.ti.com 10-Dec-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) (4/5) (6) SN74LVT574DW ACTIVE SOIC DW 20 25 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 LVT574 SN74LVT574DWR ACTIVE SOIC DW 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 LVT574 SN74LVT574PWR ACTIVE TSSOP PW 20 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 LX574 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
SN74LVT574DBR 价格&库存
很抱歉,暂时无法提供与“SN74LVT574DBR”相匹配的价格&库存,您可以联系我们找货
