SN74LVTH16241DLR
SN74LVTH16241DLR
    ROCHESTER(罗切斯特)
    BSSOP48
    BUS DRIVER, LVT SERIES
SN74LVTH16241DLR 数据手册
SN54LVTH16241,, SN74LVTH16241 3.3-V ABT 16-BIT BUFFERS/DRIVERS WITH 3-STATE OUTPUTS www.ti.com SCBS693D – MAY 1997 – REVISED NOVEMBER 2006 FEATURES • • • • • • • • • • • • Members of the Texas Instruments Widebus™ Family State-of-the-Art Advanced BiCMOS Technology (ABT) Design for 3.3-V Operation and Low Static-Power Dissipation Support Mixed-Mode Signal Operation (5-V Input and Output Voltages With 3.3-V VCC) Support Unregulated Battery Operation Down to 2.7 V Typical VOLP (Output Ground Bounce) VCC. The package thermal impedance is calculated in accordance with JESD 51. Recommended Operating Conditions (1) SN54LVTH16241 (2) SN74LVTH16241 MIN MAX MIN MAX 2.7 3.6 2.7 3.6 UNIT VCC Supply voltage VIH High-level input voltage VIL Low-level input voltage 0.8 0.8 V VI Input voltage 5.5 5.5 V IOH High-level output current –24 –32 mA IOL Low-level output current 48 64 mA ∆t/∆v Input transition rise or fall rate 10 10 ns/V ∆t/∆VCC Power-up ramp rate 200 TA Operating free-air temperature –55 (1) (2) 2 Outputs enabled 2 V µs/V 200 125 –40 V 85 °C All unused control inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. Product Preview Submit Documentation Feedback 5 SN54LVTH16241,, SN74LVTH16241 3.3-V ABT 16-BIT BUFFERS/DRIVERS WITH 3-STATE OUTPUTS www.ti.com SCBS693D – MAY 1997 – REVISED NOVEMBER 2006 Electrical Characteristics over recemmended operating free-air temperature range (unless otherwise noted) PARAMETER VIK VOH TEST CONDITIONS VCC = 2.7 V, II = –18 mA VCC = 2.7 V to 3.6 V, IOH = –100 µA VCC = 2.7 V, IOH = –8 mA VCC = 3 V VCC = 2.7 V VOL VCC = 3 V IOH = –24 mA SN54LVTH16241 (1) MIN TYP (2) SN74LVTH16241 MAX MIN TYP (2) –1.2 –1.2 VCC – 0.2 VCC – 0.2 2.4 2.4 IOH = –32 mA II Data inputs Ioff 0.2 0.2 IOL = 24 mA 0.5 0.5 IOL = 16 mA 0.4 0.4 IOL = 32 mA 0.5 0.5 IOL = 48 mA 0.55 10 10 VCC = 3.6 V, VI = VCC or GND ±1 ±1 1 1 VCC = 3 V II(hold) VI = 0 VI or VO = 0 to 4.5 V VI = 2 V VCC = 3.6 V (3), VI = 0 to 3.6 V IOZH VCC = 3.6 V, VO = 3 V IOZL VCC = 3.6 V, VO = 0.5 V –5 –5 ±100 ±100 75 75 –75 –75 µA µA µA 500 –750 5 5 µA –5 –5 µA IOZPU VCC = 0 to 1.5 V, VO = 0.5 V to 3 V, OE/OE = don't care ±100 (4) ±100 µA IOZPD VCC = 1.5 V to 0, VO = 0.5 V to 3 V, OE/OE = don't care ±100 (4) ±100 µA 0.19 0.19 ICC VCC = 3.6 V, IO = 0, VI = VCC or GND Outputs high Outputs low Outputs disabled 5 5 0.19 0.19 0.2 0.2 mA ∆ICC (5) VCC = 3 V to 3.6 V, One input at VCC – 0.6 V, Other inputs at VCC or GND Ci VI = 3 V or 0 4 4 pF Co VO = 3 V or 0 9 9 pF (1) (2) (3) (4) (5) 6 Data inputs VI = VCC VI = 0.8 V V 0.55 VI = 5.5 V VCC = 0, V 2 IOL = 100 µA VCC = 0 or 3.6 V, VCC = 3.6 V UNIT V 2 IOL = 64 mA Control inputs MAX Product Preview All typical values are at VCC = 3.3 V, TA = 25°C. This is the bus-hold maximum dynamic current. It is the minimum overdrive current required to switch the input from one state to another. On products compliant to MIL-PRF-38535, this parameter is not production tested. This is the increase in supply current for each input that is at the specified TTL voltage level, rather than VCC or GND. Submit Documentation Feedback mA SN54LVTH16241,, SN74LVTH16241 3.3-V ABT 16-BIT BUFFERS/DRIVERS WITH 3-STATE OUTPUTS www.ti.com SCBS693D – MAY 1997 – REVISED NOVEMBER 2006 Switching Characteristics over recommended operating free-air temperature range, CL = 50 pF (unless otherwise noted) (see Figure 1) PARAMETER TO (OUTPUT) A Y OE or OE Y OE or OE Y SN54LVTH16241 (1) 3.7 4 1.2 2.6 3.5 3.8 1.1 3.7 4 1.2 2.2 3.5 3.8 1.1 4.7 5.3 1.2 3.2 4.5 5.1 1.1 4.7 5.2 1.2 3.2 4.5 4.9 1.9 5.5 6.1 2 3.7 5.3 5.9 1.9 5.2 5.7 2 3.4 4.9 5.4 tsk(LH) 0.5 0.5 tsk(HL) 0.5 0.5 tPZH tPZL tPHZ tPLZ MAX 1.1 MIN SN74LVTH16241 MIN tPHL MIN TYP (2) MAX MAX tPLH (1) (2) FROM (INPUT) MIN MAX UNIT ns ns ns ns Product Preview All typical values are at VCC = 3.3 V, TA = 25°C. Submit Documentation Feedback 7 SN54LVTH16241,, SN74LVTH16241 3.3-V ABT 16-BIT BUFFERS/DRIVERS WITH 3-STATE OUTPUTS www.ti.com SCBS693D – MAY 1997 – REVISED NOVEMBER 2006 PARAMETER MEASUREMENT INFORMATION 6V 500 W From Output Under Test S1 Open GND CL = 50 pF (see Note A) 500 W TEST S1 tPLH/tPHL tPLZ/tPZL tPHZ/tPZH Open 6V GND 2.7 V LOAD CIRCUIT Timing Input 1.5 V 0V tw tsu 2.7 V 1.5 V Input th 2.7 V 1.5 V Data Input 1.5 V 1.5 V 0V 0V VOLTAGE WAVEFORMS SETUP AND HOLD TIMES VOLTAGE WAVEFORMS PULSE DURATION 2.7 V Input 1.5 V 1.5 V 0V tPHL tPLH VOH Output 1.5 V 1.5 V VOL 1.5 V 1.5 V 1.5 V VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES INVERTING AND NONINVERTING OUTPUTS 1.5 V 0V tPLZ tPZL 3V 1.5 V Output Waveform 2 S1 at GND (see Note B) VOL + 0.3 V VOL tPHZ tPZH VOH Output Output Waveform 1 S1 at 6 V (see Note B) tPLH tPHL 2.7 V Output Control 1.5 V VOH – 0.3 V VOH »0 V VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES LOW- AND HIGH-LEVEL ENABLING NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low, except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high, except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR £ 10 MHz, ZO = 50 W, tr £ 2.5 ns, tf £ 2.5 ns. D. The outputs are measured one at a time, with one transition per measurement. Figure 1. Load Circuit and Voltage Waveforms 8 Submit Documentation Feedback PACKAGE OPTION ADDENDUM www.ti.com 10-Dec-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) (4/5) (6) SN74LVTH16241DGGR ACTIVE TSSOP DGG 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 LVTH16241 SN74LVTH16241DL ACTIVE SSOP DL 48 25 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 LVTH16241 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
SN74LVTH16241DLR 价格&库存
很抱歉,暂时无法提供与“SN74LVTH16241DLR”相匹配的价格&库存,您可以联系我们找货
