RI-I11-114B-01
RI-I11-114B-01
    ROCHESTER(罗切斯特)
    TELECOM CIRCUIT, 1-FUNC
RI-I11-114B-01 数据手册
Product Folder Sample & Buy Support & Community Tools & Software Technical Documents RI-I11-114A-01 RI-I11-114B-01 SCBS828C – DECEMBER 2005 – REVISED JUNE 2014 RI-I11-114x-01 Tag-it™ HF-I Standard Transponder Inlays Square Not Recommended for New Designs 1 Features 3 Description • • • • • Texas Instruments Tag-it™ HF-I standard transponder inlays consist of 13.56-MHz highfrequency (HF) transponders that are compliant with the ISO/IEC 15693 and ISO/IEC 18000-3 global open standards. These products offer a user-accessible memory of 256 bits, organized in eight blocks, and an optimized command set available in five different antenna shapes, with frequency offset for integration into paper, PVC, or other substrates. 1 ISO/IEC 15693-2, -3; ISO/IEC 18000-3 Compliant 13.56-MHz Operating Frequency 256-Bit User Memory in 8 blocks × 32-Bit Application Family Identifier (AFI) Fast Simultaneous Identification (Anti-Collision) 2 Applications • • • • • Product Authentication Library Supply-Chain Management Asset Management Ticketing/Stored Value The Tag-it HF-I standard transponder inlays are manufactured with TI’s patented laser tuning process to provide consistent read performance. Prior to delivery, the transponders undergo complete functional and parametric testing, in order to provide the high quality that customers have come to expect from TI. The Tag-it HF-I standard transponder inlays are well suited for a variety of applications including, but not limited to, product authentication, library, supply-chain management, asset management, and ticketing/stored value applications. space Device Information (1) (1) PART NUMBER PACKAGE BODY SIZE (NOM) RI-I11-114A-01 TFB 45.00 mm x 45.00 mm RI-I11-114B-01 TFB 45.00 mm x 45.00 mm For all available packages, see the orderable addendum at the end of the datasheet. 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Not Recommended for New Designs RI-I11-114A-01 RI-I11-114B-01 SCBS828C – DECEMBER 2005 – REVISED JUNE 2014 www.ti.com 4 Revision History Changes from Revision B (Sept 2011) to Revision C Page • Deleted Changed feature from 8 bits x 32-bit blocks to 8 blocks x 32-Bit ............................................................................. 1 • Changed spec from 8 bits x 32-bit blocks to 8 blocks x 32-Bit ............................................................................................. 3 2 Submit Documentation Feedback Copyright © 2005–2014, Texas Instruments Incorporated Product Folder Links: RI-I11-114A-01 RI-I11-114B-01 Not Recommended for New Designs RI-I11-114A-01 RI-I11-114B-01 www.ti.com SCBS828C – DECEMBER 2005 – REVISED JUNE 2014 5 Pin Configuration and Functions Memory Organization 32 bits Block Addr 0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 Lock Bits U U = User Lock User data (256 bits) 0x08 0x09 UID Number (64 bits) 0x0A AFI 6 Specifications Table 1. Specifications (1) PART NUMBER RI-I11-114A-01 Supported standard RI-I11-114B-01 ISO/IEC 15693-2, -3; ISO/IEC 18000-3 Recommended operating frequency 13.56 MHz Passive resonance frequency (at 25°C) Typical required activation field strength to read (at 25°C) Typical required activation field strength to write (at 25°C) 13.86 MHz ±200 kHz (includes frequency offset to compensate further integration into paper) 14.2 MHz ±200 kHz (includes frequency offset to compensate PVC lamination) 98 dBμA/m (2) 98 dBμA/m (3) 101 dBμA/m (2) 101 dBμA/m (3) Factory-programmed read-only number 64 bits Memory (user programmable) 256 bits organized in 8 blocks × 32-Bit Typical programming cycles (at 25°C) 100,000 Data retention time (at 55°C) >10 years Simultaneous identification of tags Up to 50 tags per second (reader/antenna dependent) Antenna size 45 mm × 45 mm (~1.77 in × ~1.77 in) Foil width 48 mm ± 0.5 mm (1.89 in ± 0.02 in) Foil pitch 50.8 mm +0.1 mm/–0.4 mm (2 in) Thickness Chip area: 0.34 mm ±0.02 Antenna area (Al both sides): 0.085 mm ±0.01 Antenna area (Al one side): 0.075 mm ±0.008 Base material Substrate: PET (polyethylenetherephtalate); Antenna: aluminum Operating temperature –25°C to 70°C Storage temperature (single inlay) –40°C to 85°C (warpage may occur at upper temperature range) Storage temperature (on reel) –40°C to 40°C Single-row tape wound on cardboard reel with 500-mm diameter Reel outer width: approximately 60 mm (about 2.36 inches) Reel inner width: approximately 50 mm (about 1.97 inches) Hub diameter: 76.2 mm (3 in) Delivery Typical quantity of good units per reel (1) (2) (3) 5000 For highest possible read-out coverage, operate readers at a modulation depth of 20% or higher. After integration into paper After PVC lamination Copyright © 2005–2014, Texas Instruments Incorporated Product Folder Links: RI-I11-114A-01 RI-I11-114B-01 Submit Documentation Feedback 3 Not Recommended for New Designs RI-I11-114A-01 RI-I11-114B-01 SCBS828C – DECEMBER 2005 – REVISED JUNE 2014 www.ti.com Table 2. Supported Command Set REQUEST REQUEST MODE (1) REQUEST CODE INVENTORY ADDRESSED NON-ADDRESSED AFI OPT. FLAG ISO 15693 Mandatory and Optional Commands Inventory 0x01 ✓ – – ✓ 0 Stay Quiet 0x02 – ✓ – – 0 Read_Single_Block 0x20 – ✓ ✓ – 1 Write_Single_Block 0x21 – ✓ ✓ – 1 Lock_Block 0x22 – ✓ ✓ – 1 (1) 4 ✓ = Implemented, – = Not applicable Submit Documentation Feedback Copyright © 2005–2014, Texas Instruments Incorporated Product Folder Links: RI-I11-114A-01 RI-I11-114B-01 Not Recommended for New Designs RI-I11-114A-01 RI-I11-114B-01 www.ti.com SCBS828C – DECEMBER 2005 – REVISED JUNE 2014 7 Device and Documentation Support 7.1 Documentation Support 7.1.1 Related Links The table below lists quick access links. Categories include technical documents, support and community resources, tools and software, and quick access to sample or buy. Table 3. Related Links PARTS PRODUCT FOLDER SAMPLE & BUY TECHNICAL DOCUMENTS TOOLS & SOFTWARE SUPPORT & COMMUNITY RI-I11-114A-01 Click here Click here Click here Click here Click here RI-I11-114B-01 Click here Click here Click here Click here Click here 7.2 Trademarks Tag-it is a trademark of Texas Instruments. 7.3 Electrostatic Discharge Caution These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. 7.4 Glossary SLYZ022 — TI Glossary. This glossary lists and explains terms, acronyms, and definitions. 8 Mechanical, Packaging, and Orderable Information The following pages include mechanical packaging and orderable information. This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the left-hand navigation. Copyright © 2005–2014, Texas Instruments Incorporated Product Folder Links: RI-I11-114A-01 RI-I11-114B-01 Submit Documentation Feedback 5 PACKAGE OPTION ADDENDUM www.ti.com 1-Jun-2017 PACKAGING INFORMATION Orderable Device Status (1) RI-I11-114B-01 OBSOLETE Package Type Package Pins Package Drawing Qty RFIDN TFB 0 Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) TBD Call TI Call TI Op Temp (°C) Device Marking (4/5) -25 to 70 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
RI-I11-114B-01 价格&库存
很抱歉,暂时无法提供与“RI-I11-114B-01”相匹配的价格&库存,您可以联系我们找货
