SN74AVCB164245KR
SN74AVCB164245KR
    ROCHESTER(罗切斯特)
    56-VFBGA
    BUS TRANSCEIVER
SN74AVCB164245KR 数据手册
SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS www.ti.com SCES394D – JUNE 2002 – REVISED JUNE 2005 • FEATURES • • • • • Member of the Texas Instruments Widebus™ Family DOC™ Circuitry Dynamically Changes Output Impedance, Resulting in Noise Reduction Without Speed Degradation Dynamic Drive Capability Is Equivalent to Standard Outputs With IOH and IOL of ±24 mA at 2.5-V VCC Control Inputs VIH/VIL Levels Are Referenced to VCCB Voltage If Either VCC Input Is at GND, Both Ports Are in the High-Impedance State • • • • Overvoltage-Tolerant Inputs/Outputs Allow Mixed-Voltage-Mode Data Communications Ioff Supports Partial-Power-Down Mode Operation Fully Configurable Dual-Rail Design Allows Each Port to Operate Over Full 1.4-V to 3.6-V Power-Supply Range Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II ESD Protection Exceeds JESD 22 – 2000-V Human-Body Model (A114-A) – 200-V Machine Model (A115-A) – 1000-V Charged-Device Model (C101) DESCRIPTION This 16-bit (dual-octal) noninverting bus transceiver uses two separate configurable power-supply rails. The A port is designed to track VCCA. VCCA accepts any supply voltage from 1.4 V to 3.6 V. The B port is designed to track VCCB. VCCB accepts any supply voltage from 1.4 V to 3.6 V. This allows for universal low-voltage bidirectional translation between any of the 1.5-V, 1.8-V, 2.5-V, and 3.3-V voltage nodes. The SN74AVCB164245 is designed for asynchronous communication between data buses. The device transmits data from the A bus to the B bus or from the B bus to the A bus, depending on the logic level at the direction-control (DIR) input. The output-enable (OE) input can be used to disable the outputs so the buses are effectively isolated. The SN74AVCB164245 is designed so that the control pins (1DIR, 2DIR, 1OE, and 2OE) are supplied by VCCB. To ensure the high-impedance state during power up or power down, OE should be tied to VCCB through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver. This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down. If either VCC input is at GND, both ports are in the high-impedance state. ORDERING INFORMATION PACKAGE (1) TA –40°C to 85°C (1) ORDERABLE PART NUMBER FBGA – GRD Tape and reel 74AVCB164245GRDR FBGA – ZRD (Pb-Free) Tape and reel 74AVCB164245ZRDR TSSOP – DGG Tape and reel SN74AVCB164245GR TVSOP – DGV Tape and reel SN74AVCB164245VR VFBGA – GQL Tape and reel SN74AVCB164245KR VFBGA – ZQL (Pb-Free) Tape and reel 74AVCB164245ZQLR TOP-SIDE MARKING WB4245 AVCB164245 WB4245 WB4245 Package drawings, standard packing quantities, thermal data, symbolization, and PCB design guidelines are available at www.ti.com/sc/package. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Widebus, DOC are trademarks of Texas Instruments. PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of the Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. Copyright © 2002–2005, Texas Instruments Incorporated SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS SCES394D – JUNE 2002 – REVISED JUNE 2005 TERMINAL ASSIGNMENTS DGG OR DGV PACKAGE (TOP VIEW) 1DIR 1B1 1B2 GND 1B3 1B4 VCCB 1B5 1B6 GND 1B7 1B8 2B1 2B2 GND 2B3 2B4 VCCB 2B5 2B6 GND 2B7 2B8 2DIR 2 1 48 2 47 3 46 4 45 5 44 6 43 7 42 8 41 9 40 10 39 11 38 12 37 13 36 14 35 15 34 16 33 17 32 18 31 19 30 20 29 21 28 22 27 23 26 24 25 1OE 1A1 1A2 GND 1A3 1A4 VCCA 1A5 1A6 GND 1A7 1A8 2A1 2A2 GND 2A3 2A4 VCCA 2A5 2A6 GND 2A7 2A8 2OE www.ti.com SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS www.ti.com SCES394D – JUNE 2002 – REVISED JUNE 2005 TERMINAL ASSIGNMENTS (56-Ball GQL/ZQL Package) (1) GQL OR ZQL PACKAGE (TOP VIEW) 1 2 3 4 5 6 A B C D E F G H J K (1) 1 2 3 4 5 6 A 1DIR NC NC NC NC 1OE B 1B2 1B1 GND GND 1A1 1A2 C 1B4 1B3 VCCB VCCA 1A3 1A4 D 1B6 1B5 GND GND 1A5 1A6 E 1B8 1B7 1A7 1A8 F 2B1 2B2 2A2 2A1 G 2B3 2B4 GND GND 2A4 2A3 H 2B5 2B6 VCCB VCCA 2A6 2A5 J 2B7 2B8 GND GND 2A8 2A7 K 2DIR NC NC NC NC 2OE NC - No internal connection GRD OR ZRD PACKAGE (TOP VIEW) 1 2 3 4 5 6 TERMINAL ASSIGNMENTS (54-Ball GRD/ZRD Package) (1) A B 1 2 3 4 5 6 A 1B1 NC 1DIR 1OE NC 1A1 B 1B3 1B2 NC NC 1A2 1A3 C 1B5 1B4 VCCB VCCA 1A4 1A5 C D 1B7 1B6 GND GND 1A6 1A7 D E 2B1 1B8 GND GND 1A8 2A1 E F G H (1) F 2B3 2B2 GND GND 2A2 2A3 G 2B5 2B4 VCCB VCCA 2A4 2A5 H 2B7 2B6 NC NC 2A6 2A7 J 2B8 NC 2DIR 2OE NC 2A8 NC - No internal connection xxxxx J xxxxx xxxxx xxxxx xxxxx FUNCTION TABLE (EACH 8-BIT SECTION) INPUTS OPERATION OE DIR L L B data to A bus L H A data to B bus H X Isolation 3 SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS www.ti.com SCES394D – JUNE 2002 – REVISED JUNE 2005 LOGIC DIAGRAM (POSITIVE LOGIC) 1DIR 1 2DIR 48 1A1 25 1OE 47 2A1 2 24 2OE 36 13 1B1 2B1 To Seven Other Channels To Seven Other Channels Pin numbers shown are for the DGG and DGV packages. Absolute Maximum Ratings (1) over operating free-air temperature range (unless otherwise noted) VCCA VCCB VI MIN MAX –0.5 4.6 I/O ports (A port) –0.5 4.6 I/O ports (B port) –0.5 4.6 Control inputs –0.5 4.6 A port –0.5 4.6 B port –0.5 4.6 A port –0.5 VCCA + 0.5 B port –0.5 VCCB + 0.5 Supply voltage range Input voltage range (2) UNIT V V VO Voltage range applied to any output in the high-impedance or power-off state (2) VO Voltage range applied to any output in the high or low state (2) (3) IIK Input clamp current VI < 0 –50 mA IOK Output clamp current VO < 0 –50 mA IO Continuous output current 50 mA 100 mA Continuous current through VCCA, VCCB, or GND θJA Package thermal impedance (4) Tstg Storage temperature range DGG package 70 DGV package 58 GQL/ZQL package 28 GRD/ZRD package (1) (2) (3) (4) 4 V V °C/W 36 –65 150 °C Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under "recommended operating conditions" is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The input and output negative-voltage ratings may be exceeded if the input and output current ratings are observed. The output positive-voltage rating may be exceeded up to 4.6 V maximum if the output current rating is observed. The package thermal impedance is calculated in accordance with JESD 51-7. www.ti.com SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS SCES394D – JUNE 2002 – REVISED JUNE 2005 Recommended Operating Conditions (1) (2) (3) over operating free-air temperature range (unless otherwise noted) MIN MAX VCCA Supply voltage VCCI 1.4 3.6 V VCCB Supply voltage 1.4 3.6 V VIH High-level input voltage VIL Low-level input voltage VIH High-level input voltage VIL Low-level input voltage VI Input voltage VO Output voltage IOH Data inputs Data inputs Control inputs (referenced to VCCB) Control inputs (referenced to VCCB) VCCI × 0.65 1.95 V to 2.7 V 1.7 2.7 V to 3.6 V 2 1.4 V to 1.95 V VCCI × 0.35 1.95 V to 2.7 V 0.7 2.7 V to 3.6 V 0.8 1.4 V to 1.95 V VCCB × 0.65 1.95 V to 2.7 V 1.7 2.7 V to 3.6 V 2 1.4 V to 1.95 V VCCB × 0.35 1.95 V to 2.7 V 0.7 2.7 V to 3.6 V 0.8 0 VCCO 3-state 0 3.6 Input transition rise or fall rate TA Operating free-air temperature 1.4 V to 1.6 V –2 1.65 V to 1.95 V –4 2.3 V to 2.7 V –8 3 V to 3.6 V –12 1.4 V to 1.6 V 2 1.65 V to 1.95 V 4 2.3 V to 2.7 V 8 3 V to 3.6 V 12 –40 V V Active state Low-level output current UNIT V 3.6 ∆t/∆v (1) (2) (3) 1.4 V to 1.95 V 0 High-level output current IOL VCCO V V V mA mA 5 ns/V 85 °C VCCI is the VCC associated with the data input port. VCCO is the VCC associated with the data output port. All unused data inputs of the device must be held at VCCI or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. 5 SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS www.ti.com SCES394D – JUNE 2002 – REVISED JUNE 2005 Electrical Characteristics (1) (2) over operating free-air temperature range (unless otherwise noted) PARAMETER VOH VOL II Control inputs A port Ioff B port TEST CONDITIONS B port A port ICCA MIN TYP (3) MAX VI = VIH 1.4 V to 3.6 V 1.4 V to 3.6 V IOH = –2 mA VI = VIH 1.4 V 1.4 V IOH = –4 mA VI = VIH 1.65 V 1.65 V 1.2 IOH = –8 mA VI = VIH 2.3 V 2.3 V 1.75 IOH = –12 mA VI = VIH 3V 3V 2.3 IOH = 100 µA VI = VIL 1.4 V to 3.6 V 1.4 V to 3.6 V 0.2 IOH = 2 mA VI = VIL 1.4 V 1.4 V 0.35 IOH = 4 mA VI = VIL 1.65 V 1.65 V 0.45 IOH = 8 mA VI = VIL 2.3 V 2.3 V 0.55 IOH = 12 mA VI = VIL 3V 3V 0.7 1.4 V to 3.6 V 3.6 V ±2.5 0V 0 to 3.6 V ±10 0 to 3.6 V 0V ±10 3.6 V 3.6 V ±12.5 0V 3.6 V ±12.5 3.6 V 0V ±12.5 1.6 V 1.6 V 20 1.95 V 1.95 V 20 2.7 V 2.7 V 30 0V 3.6 V –40 3.6 V 0V 40 3.6 V 3.6 V 40 VI = VCCB or GND VI or VO = 0 to 3.6 V VO = VCCO or GND, VI = VCCI or GND VI = VCCI or GND, ICCB VCCB IOH = –100 µA A or B ports IOZ (4) VCCA VI = VCCI or GND, OE = VIH OE = don't care IO = 0 IO = 0 UNIT VCCO – 0.2 1.05 V 1.6 V 1.6 V 20 1.95 V 1.95 V 20 2.7 V 2.7 V 30 0V 3.6 V 40 3.6 V 0V –40 3.6 V 3.6 V 40 V µA µA µA µA µA Ci Control inputs VI = 3.3 V or GND 3.3 V 3.3 V 4 pF Cio A or B ports VO = 3.3 V or GND 3.3 V 3.3 V 5 pF (1) (2) (3) (4) 6 VCCO is the VCC associated with the output port. VCCI is the VCC associated with the input port. All typical values are at TA = 25°C. For I/O ports, the parameter IOZ includes the input leakage current. SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS www.ti.com SCES394D – JUNE 2002 – REVISED JUNE 2005 Switching Characteristics over recommended operating free-air temperature range, VCCA = 1.5 V ± 0.1 V (see Figure 2) PARAMETER tpd FROM (INPUT) TO (OUTPUT) A B ten OE tdis OE VCCB = 1.5 V 0.1 V VCCB = 1.8 V 0.15 V VCCB = 2.5 V 0.2 V VCCB = 3.3 V 0.3 V MIN MAX MIN MAX MIN MAX MIN MAX B 1.7 6.7 1.9 6.3 1.8 5.5 1.7 5.8 A 1.8 6.8 2.2 7.4 2.1 7.6 2.1 7.3 A 2.5 8.4 2.4 7.4 2.1 5.2 1.9 4.2 B 2.1 9 2.9 9.8 3.2 10 3 9.8 A 2.2 6.9 2.3 6.1 1.3 3.6 1.3 3 B 2.1 7.1 2.3 6.4 1.7 5.1 1.6 4.8 UNIT ns ns ns Switching Characteristics over recommended operating free-air temperature range, VCCA = 1.8 V ± 0.15 V (see Figure 2) PARAMETER tpd FROM (INPUT) TO (OUTPUT) A B ten OE tdis OE VCCB = 1.5 V 0.1 V VCCB = 1.8 V 0.15 V VCCB = 2.5 V 0.2 V VCCB = 3.3 V 0.3 V MIN MAX MIN MAX MIN MAX MIN MAX B 1.7 6.7 1.8 6 1.7 4.7 1.6 4.3 A 1.4 5.5 1.8 6 1.8 5.8 1.8 5.5 A 2.6 8.5 2.5 7.5 2.2 5.3 1.9 4.2 B 1.8 7.6 2.6 7.7 2.6 7.6 2.6 7.4 A 2.3 7 2.3 6.1 1.3 3.6 1.3 3 B 1.8 7 2.5 6.3 1.8 4.7 1.7 4.4 UNIT ns ns ns Switching Characteristics over recommended operating free-air temperature range, VCCA = 2.5 V ± 0.2 V (see Figure 2) PARAMETER tpd FROM (INPUT) TO (OUTPUT) A B B A ten OE tdis OE VCCB = 1.5 V 0.1 V MIN VCCB = 1.8 V 0.15 V VCCB = 2.5 V 0.2 V VCCB = 3.3 V 0.3 V MAX MIN MAX MIN MAX MIN MAX 1.6 6 1.8 5.6 1.5 4 1.4 3.4 1.3 4.6 1.7 4.4 1.5 4 1.4 3.7 A 3.1 8.5 2.5 7.5 2.2 5.3 1.9 4.2 B 1.7 5.7 2.2 5.5 2.2 5.3 2.2 5.1 A 2.4 7 3 6.1 1.4 3.6 1.2 3 B 1.2 5.8 1.9 5 1.4 3.6 1.3 3.3 UNIT ns ns ns Switching Characteristics over recommended operating free-air temperature range, VCCA = 3.3 V ± 0.3 V (see Figure 2) PARAMETER tpd FROM (INPUT) TO (OUTPUT) A B ten OE tdis OE VCCB = 1.5 V 0.1 V VCCB = 1.8 V 0.15 V VCCB = 2.5 V 0.2 V VCCB = 3.3 V 0.3 V MIN MAX MIN MAX MIN MAX MIN MAX B 1.5 5.9 1.7 5.4 1.5 3.7 1.4 3.1 A 1.3 4.5 1.6 3.8 1.5 3.3 1.4 3.1 A 2.6 8.3 2.5 7.4 2.2 5.2 1.9 4.1 B 1.6 4.9 2 4.5 2 4.3 1.9 4.1 A 2.3 7 3 6 1.3 3.5 1.2 3.5 B 1.3 6.9 2.1 5.5 1.6 3.8 1.5 3.5 UNIT ns ns ns 7 SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS www.ti.com SCES394D – JUNE 2002 – REVISED JUNE 2005 Operating Characteristics VCCA and VCCB = 3.3 V, TA = 25°C PARAMETER TEST CONDITIONS Power dissipation capacitance per transceiver, A-port input, B-port output CpdA (VCCA) CpdB (VCCB) TYP Outputs enabled Outputs disabled CL = 0, 7 f = 10 MHz Power dissipation capacitance per transceiver, B-port input, A-port output Outputs enabled Outputs disabled 7 Power dissipation capacitance per transceiver, A-port input, B-port output Outputs enabled 20 Power dissipation capacitance per transceiver, B-port input, A-port output Outputs enabled Outputs disabled UNIT 14 CL = 0, 20 7 f = 10 MHz 14 Outputs disabled pF pF 7 Output Description The DOC™ circuitry is implemented, which, during the transition, initially lowers the output impedance to effectively drive the load and, subsequently, raises the impedance to reduce noise. Figure 1 shows typical VOL vs IOL and VOH vs IOH curves to illustrate the output impedance and drive capability of the circuit. At the beginning of the signal transition, the DOC circuit provides a maximum dynamic drive that is equivalent to a high-drive standard-output device. For more information, refer to the TI application reports, AVC Logic Family Technology and Applications, literature number SCEA006, and Dynamic Output Control (DOC™) Circuitry Technology and Applications, literature number SCEA009. 3.2 TA = 25°C Process = Nominal − Output Voltage − V 2.8 2.4 VCC = 3.3 V 2.0 1.6 VCC = 2.5 V 1.2 OH VCC = 1.8 V 0.8 V VOL − Output Voltage − V 2.8 TA = 25°C Process = Nominal 2.4 2.0 1.6 1.2 0.8 VCC = 3.3 V 0.4 0.4 0 17 34 51 68 85 102 119 IOL − Output Current − mA 136 153 170 VCC = 2.5 V −160 −144 −128 −112 −96 −80 −64 −48 IOH − Output Current − mA Figure 1. Typical Output Voltage vs Output Current 8 VCC = 1.8 V −32 −16 0 SN74AVCB164245 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS www.ti.com SCES394D – JUNE 2002 – REVISED JUNE 2005 PARAMETER MEASUREMENT INFORMATION 2 × VCCO S1 RL From Output Under Test Open GND CL (see Note A) TEST S1 tpd tPLZ/tPZL tPHZ/tPZH Open 2 × VCCO GND RL tw LOAD CIRCUIT VCCI VCCI/2 Input VCCO CL RL VTP 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 15 pF 30 pF 30 pF 30 pF 2 kΩ 1 kΩ 500 Ω 500 Ω 0.1 V 0.15 V 0.15 V 0.3 V VCCI/2 0V VOLTAGE WAVEFORMS PULSE DURATION VCCB Output Control (low-level enabling) VCCB/2 VCCB/2 0V tPZL VCCI Input VCCI/2 VCCI/2 0V tPLH Output tPHL VCCO/2 VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES VOH VCCO/2 VOL tPLZ VCCO Output Waveform 1 S1 at 2 × VCCO (see Note B) VCCO/2 VOL + VTP VOL tPZH Output Waveform 2 S1 at GND (see Note B) tPHZ VCCO/2 VOH − VTP VOH 0V VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low, except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high, except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR10 MHz, ZO = 50 Ω, dv/dt ≥ 1 V/ns. D. The outputs are measured one at a time, with one transition per measurement. E. tPLZ and tPHZ are the same as tdis. F. tPZL and tPZH are the same as ten. G. tPLH and tPHL are the same as tpd. H. VCCI is the VCC associated with the input port. I. VCCO is the VCC associated with the output port. Figure 2. Load Circuit and Voltage Waveforms 9 PACKAGE OPTION ADDENDUM www.ti.com 14-Oct-2022 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) Samples (4/5) (6) 74AVCB164245GRE4 ACTIVE TSSOP DGG 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 AVCB164245 Samples SN74AVCB164245GR ACTIVE TSSOP DGG 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 AVCB164245 Samples SN74AVCB164245VR ACTIVE TVSOP DGV 48 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 85 WB4245 Samples (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
SN74AVCB164245KR 价格&库存
很抱歉,暂时无法提供与“SN74AVCB164245KR”相匹配的价格&库存,您可以联系我们找货
