CD54/74AC280,
CD54/74ACT280
Data sheet acquired from Harris Semiconductor
SCHS250A
9-Bit Odd/Even Parity Generator/Checker
August 1998 - Revised May 2000
Features
data inputs is HIGH. Odd parity is indicated (∑O output is
HIGH) when an odd number of data inputs is HIGH. Parity
checking for words larger than nine bits can be accomplished by tying the ∑E output to any input of an additional
’AC280, ’ACT280 parity checker.
• Buffered Inputs
• Typical Propagation Delay
- 10ns at VCC = 5V, TA = 25oC, CL = 50pF
• Exceeds 2kV ESD Protection per MIL-STD-883,
Method 3015
Ordering Information
PART
NUMBER
• SCR-Latchup-Resistant CMOS Process and Circuit
Design
TEMP.
RANGE (oC)
CD54AC280F3A
• Speed of Bipolar FAST™/AS/S with Significantly
Reduced Power Consumption
-55 to 125
14 Ld CERDIP
0 to 70oC, -40 to 85,
CD74AC280E
PACKAGE
14 Ld PDIP
-55 to 125
• Balanced Propagation Delays
-55 to 125
CD74AC280M
• AC Types Feature 1.5V to 5.5V Operation and
Balanced Noise Immunity at 30% of the Supply
CD54ACT280F3A
• ±24mA Output Drive Current
- Fanout to 15 FAST™ ICs
- Drives 50Ω Transmission Lines
-55 to 125
14 Ld CERDIP
CD74ACT280E
14 Ld SOIC
14 Ld PDIP
-55 to 125
-55 to 125
CD74ACT280M
Description
14 Ld SOIC
NOTES:
1. When ordering, use the entire part number. Add the suffix 96 to
obtain the variant in the tape and reel.
The ’AC280 and ’ACT280 are 9-bit odd/even parity generator/checkers that utilize Advanced CMOS Logic technology.
Both even and odd parity outputs are available for checking
or generating parity for words up to nine bits long. Even parity is indicated (∑E output is HIGH) when an even number of
2. Wafer and die for this part number is available which meets all electrical specifications. Please contact your local TI sales office or customer service for ordering information.
Pinout
Functional Diagram
CD54AC280, CD54ACT280
(CERDIP)
CD74AC280, CD74ACT280
(PDIP, SOIC)
TOP VIEW
I0
I1
I6 1
I2
14 VCC
I7 2
13 I5
NC 3
12 I4
I8 4
11 I3
I3
10 I2
∑O 6
9 I1
GND 7
8 I0
9
10
5
11
I6
I7
I8
6
13
1
∑ ODD
1
2
4
CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures.
FAST™ is a Trademark of Fairchild Semiconductor.
Copyright © 2000, Texas Instruments Incorporated
∑ EVEN
12
I4
I5
∑E 5
8
GND = 7
VCC = 14
NC = 3
CD54/74AC280, CD54/74ACT280
F
Absolute Maximum Ratings
Thermal Information
DC Supply Voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . -0.5V to 6V
DC Input Diode Current, IIK
For VI < -0.5V or VI > VCC + 0.5V . . . . . . . . . . . . . . . . . . . . . .±20mA
DC Output Diode Current, IOK
For VO < -0.5V or VO > VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±50mA
DC Output Source or Sink Current per Output Pin, IO
For VO > -0.5V or VO < VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±50mA
DC VCC or Ground Current, ICC or IGND (Note 3) . . . . . . . . .±100mA
Thermal Resistance (Typical, Note 5)
θJA (oC/W)
PDIP Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
___
SOIC Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
___
Maximum Junction Temperature (Plastic Package) . . . . . . . . . . 150oC
Maximum Storage Temperature Range . . . . . . . . . .-65oC to 150oC
Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . . 300oC
Operating Conditions
Temperature Range, TA . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC
Supply Voltage Range, VCC (Note 4)
AC Types. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .1.5V to 5.5V
ACT Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4.5V to 5.5V
DC Input or Output Voltage, VI, VO . . . . . . . . . . . . . . . . . 0V to VCC
Input Rise and Fall Slew Rate, dt/dv
AC Types, 1.5V to 3V . . . . . . . . . . . . . . . . . . . . . . . . . 50ns (Max)
AC Types, 3.6V to 5.5V . . . . . . . . . . . . . . . . . . . . . . . . 20ns (Max)
ACT Types, 4.5V to 5.5V. . . . . . . . . . . . . . . . . . . . . . . 10ns (Max)
CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation
of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied.
NOTES:
3. For up to 4 outputs per device, add ±25mA for each additional output.
4. Unless otherwise specified, all voltages are referenced to ground.
5. θJA is measured with the component mounted on an evaluation PC board in free air.
DC Electrical Specifications
TEST
CONDITIONS
PARAMETER
-40oC TO
85oC
25oC
-55oC TO
125oC
SYMBOL
VI (V)
IO (mA)
VCC
(V)
MIN
MAX
MIN
MAX
MIN
MAX
UNITS
VIH
1.5
1.2
1.2
1.2
V
AC TYPES
High Level Input Voltage
Low Level Input Voltage
High Level Output Voltage
VIL
VOH
VIH or VIL
3
2.1
2.1
2.1
V
5.5
3.85
3.85
3.85
V
1.5
0.3
0.3
0.3
V
3
0.9
0.9
0.9
V
5.5
1.65
1.65
1.65
V
-0.05
1.5
1.4
1.4
1.4
V
-0.05
3
2.9
2.9
2.9
V
-0.05
4.5
4.4
4.4
4.4
V
-4
3
2.58
2.48
2.4
V
-24
4.5
3.94
3.8
3.7
V
-75
(Note 6, 7)
5.5
3.85
V
-50
(Note 6, 7)
5.5
3.85
V
2
(Continued)
TEST
CONDITIONS
PARAMETER
Low Level Output Voltage
-40oC TO
85oC
25oC
-55oC TO
125oC
SYMBOL
VI (V)
IO (mA)
VCC
(V)
MIN
MAX
MIN
MAX
MIN
MAX
UNITS
VOL
VIH or VIL
0.05
1.5
0.1
0.1
0.1
V
0.05
3
0.1
0.1
0.1
V
0.05
4.5
0.1
0.1
0.1
V
12
3
0.36
0.44
0.5
V
24
4.5
0.36
0.44
0.5
V
75
(Note 6, 7)
5.5
1.65
V
50
(Note 6, 7)
5.5
1.65
V
II
VCC or
GND
5.5
±0.1
±1
±1
µA
ICC
VCC or
GND
8
80
160
µA
VIH
4.5 to
5.5
2
2
2
V
VIL
4.5 to
5.5
0.8
0.8
0.8
V
VOH
VIH or VIL
-0.05
4.5
4.4
4.4
4.4
V
-24
4.5
3.94
3.8
3.7
V
-75
(Note 6, 7)
5.5
3.85
V
-50
(Note 6, 7)
5.5
3.85
V
0.05
4.5
0.1
0.1
0.1
V
24
4.5
0.36
0.44
0.5
V
75
(Note 6, 7)
5.5
1.65
V
50
(Note 6, 7)
5.5
1.65
V
Input Leakage Current
Quiescent Supply Current
MSI
ACT TYPES
MSI
Additional Supply Current per
Input Pin TTL Inputs High
1 Unit Load
VOL
VIH or VIL
II
VCC or
GND
5.5
±0.1
±1
±1
µA
ICC
VCC or
GND
8
80
160
µA
∆ICC
VCC
-2.1
4.5 to
5.5
2.4
2.8
3
mA
NOTES:
6. Test one output at a time for a 1-second maximum duration. Measurement is made by forcing current and measuring voltage to minimize
power dissipation.
7. Test verifies a minimum 50Ω transmission-line-drive capability at 85oC, 75Ω at 125oC.
ACT Input Load Table
INPUT
UNIT LOAD
All
1.43
NOTE: Unit load is ∆ICC limit specified in DC Electrical Specifications
Table, e.g., 2.4mA max at 25oC.
3
Switching Specifications Input tr, tf = 3ns, CL = 50pF (Worst Case)
-40oC TO 85oC
-55oC TO 125oC
SYMBOL
VCC (V)
MIN
TYP
MAX
MIN
TYP
MAX
UNITS
tPLH, tPHL
1.5
239
263
ns
3.3
(Note 9)
7.5
26
7.3
29
ns
5
(Note 10)
5.4
19.1
5.3
21
ns
1.5
227
250
ns
3.3
7.2
25
7
28
ns
5
5.2
18.2
5
ns
CI
10
10
pF
CPD
(Note 11)
115
115
pF
Propagation Delay,
Any Input to ∑O
tPLH, tPHL
5
(Note 10)
5.6
19.6
5.4
21.6
ns
Propagation Delay,
Any Input to ∑E
tPLH, tPHL
5
5.6
19.6
5.4
21.6
ns
Input Capacitance
CI
10
10
pF
CPD
(Note 11)
115
115
pF
PARAMETER
AC TYPES
Propagation Delay,
Any Input to ∑O
Propagation Delay,
Any Input to ∑E
tPLH, tPHL
Input Capacitance
Power Dissipation Capacitance
ACT TYPES
NOTES:
8. Limits tested 100%
9. 3.3V Min is at 3.6V, Max is at 3V.
10. 5V Min is at 5.5V, Max is at 4.5V.
11. CPD is used to determine the dynamic power consumption per package.
AC: PD = VCC2 fi (CPD + CL)
ACT: PD = VCC2 fi (CPD + CL) + VCC ∆ICC where fi = input frequency, CL = output load capacitance, VCC = supply voltage.
tr = 3ns
OUTPUT
tf = 3ns
RL (NOTE)
500Ω
INPUT
LEVEL
In
0V
VS
VS
10%
DUT
10%
tPHL
ΣO
OUTPUT
LOAD
tPLH
NOTE: For AC Series Only: When VCC = 1.5V, RL = 1kΩ.
VS
VS
CL
50pF
0V
tPLH
ΣE
VS
tPHL
AC
ACT
VCC
3V
Input Switching Voltage, VS
0.5 VCC
1.5V
Output Switching Voltage, VS
0.5 VCC
0.5 VCC
Input Level
VS
0V
FIGURE 1.
FIGURE 2. PROPAGATION DELAY TIMES
4
PACKAGE OPTION ADDENDUM
www.ti.com
2-Dec-2023
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
Device Marking
(3)
Samples
(4/5)
(6)
CD54AC280F3A
ACTIVE
CDIP
J
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
CD54AC280F3A
Samples
CD54ACT280F3A
ACTIVE
CDIP
J
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
CD54ACT280F3A
Samples
CD74AC280E
ACTIVE
PDIP
N
14
25
RoHS & Green
NIPDAU
N / A for Pkg Type
-55 to 125
CD74AC280E
Samples
CD74AC280M
LIFEBUY
SOIC
D
14
50
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
AC280M
CD74AC280M96
ACTIVE
SOIC
D
14
2500
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
AC280M
Samples
CD74AC280M96G4
ACTIVE
SOIC
D
14
2500
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
AC280M
Samples
CD74ACT280E
ACTIVE
PDIP
N
14
25
RoHS & Green
NIPDAU
N / A for Pkg Type
-55 to 125
CD74ACT280E
Samples
CD74ACT280M
LIFEBUY
SOIC
D
14
50
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
ACT280M
CD74ACT280M96
ACTIVE
SOIC
D
14
2500
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
ACT280M
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
