CD74ACT112ME4
CD74ACT112ME4
    ROCHESTER(罗切斯特)
    SOIC16_150MIL
    J-K FLIP-FLOP
CD74ACT112ME4 数据手册
CD54ACT112, CD74ACT112 DUAL J-K NEGATIVE-EDGE-TRIGGERED FLIP-FLOPS WITH CLEAR AND PRESET SCHS323 – JANUARY 2003 D D D D D D CD54ACT112 . . . F PACKAGE CD74ACT112 . . . M PACKAGE (TOP VIEW) Inputs Are TTL-Voltage Compatible Speed of Bipolar F, AS, and S, With Significantly Reduced Power Consumption Balanced Propagation Delays ±24-mA Output Drive Current – Fanout to 15 F Devices SCR-Latchup-Resistant CMOS Process and Circuit Design Exceeds 2-kV ESD Protection Per MIL-STD-883, Method 3015 1CLK 1K 1J 1PRE 1Q 1Q 2Q GND 1 16 2 15 3 14 4 13 5 12 6 11 7 10 8 9 VCC 1CLR 2CLR 2CLK 2K 2J 2PRE 2Q description/ordering information The ’ACT112 devices contain two independent J-K negative-edge-triggered flip-flops. A low level at the preset (PRE) or clear (CLR) inputs sets or resets the outputs, regardless of the levels of the other inputs. When PRE and CLR are inactive (high), data at the J and K inputs meeting the setup-time requirements is transferred to the outputs on the negative-going edge of the clock pulse (CLK). Clock triggering occurs at a voltage level and is not directly related to the fall time of the clock pulse. Following the hold-time interval, data at the J and K inputs may be changed without affecting the levels at the outputs. These versatile flip-flops can perform as toggle flip-flops by tying J and K high. ORDERING INFORMATION –55°C to 125°C ORDERABLE PART NUMBER PACKAGE† TA SOIC – M Tube CD74ACT112M Tape and reel CD74ACT112M96 TOP-SIDE MARKING ACT112M CDIP – F Tube CD54ACT112F3A CD54ACT112F3A † Package drawings, standard packing quantities, thermal data, symbolization, and PCB design guidelines are available at www.ti.com/sc/package. FUNCTION TABLE (each flip-flop) INPUTS PRE CLR CLK OUTPUTS J K Q Q L H X X X H L H L X X X L L X X X L H‡ H H‡ H H ↓ L L Q0 Q0 H H ↓ H L H L H H ↓ L H L H H ↓ H H H Toggle H H H X X Q0 Q0 ‡ Output states are unpredictable if PRE and CLR go high simultaneously after both being low at the same time. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright  2003, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. On products compliant to MIL-PRF-38535, all parameters are tested unless otherwise noted. On all other products, production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 CD54ACT112, CD74ACT112 DUAL J-K NEGATIVE-EDGE-TRIGGERED FLIP-FLOPS WITH CLEAR AND PRESET SCHS323 – JANUARY 2003 logic diagram (positive logic) Q Q PRE CLR J K CLK absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 6 V Input clamp current, IIK (VI < 0 V or VI > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±20 mA Output clamp current, IOK (VO < 0 V or VO > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA Continuous output current, IO (VO > 0 V or VO < VCC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA Continuous current through VCC or GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±100 mA Package thermal impedance, θJA (see Note 2) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTES: 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 2. The package thermal impedance is calculated in accordance with JESD 51-7. recommended operating conditions (see Note 3) TA = 25°C –40°C to 85°C UNIT MIN MAX MIN MAX MIN MAX 4.5 5.5 4.5 5.5 4.5 5.5 VCC VIH Supply voltage VIL VI Low-level input voltage Input voltage 0 VO IOH Output voltage 0 High-level output current –24 IOL ∆t/∆v Low-level output current Input transition rise or fall rate High-level input voltage –55°C to 125°C 2 2 0.8 2 V 0.8 V VCC VCC V –24 –24 mA 24 24 24 mA 10 10 10 ns/V VCC VCC 0.8 V 0 0 VCC VCC 0 0 V NOTE 3: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 CD54ACT112, CD74ACT112 DUAL J-K NEGATIVE-EDGE-TRIGGERED FLIP-FLOPS WITH CLEAR AND PRESET SCHS323 – JANUARY 2003 electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS MIN VOH VOL II ICC DICC VI = VIH or VIL VI = VIH or VIL VI = VCC or GND VI = VCC or GND, –55°C to 125°C TA = 25°C VCC MAX MIN –40°C to 85°C MAX MIN UNIT MAX IOH = –50 µA IOH = –24 mA 4.5 V 4.4 4.5 V 3.94 IOH = –50 mA† IOH = –75 mA† 5.5 V IOL = 50 µA IOL = 24 mA IOL = 50 mA† 4.5 V 0.1 0.1 0.1 4.5 V 0.36 0.5 0.44 IOL = 75 mA† 5.5 V 4.4 3.7 3.8 V 3.85 5.5 V 3.85 5.5 V IO = 0 1.65 V 1.65 5.5 V ±0.1 ±1 ±1 µA 5.5 V 4 80 40 µA 2.4 3 2.8 mA 4.5 V to 5.5 V VI = VCC – 2.1 V 4.4 Ci 10 10 10 pF † Test one output at a time, not exceeding 1-second duration. Measurement is made by forcing indicated current and measuring voltage to minimize power dissipation. Test verifies a minimum 50-Ω transmission-line drive capability at 85°C and 75-Ω transmission-line drive capability at 125°C. ACT INPUT LOAD TABLE INPUT UNIT LOAD J or CLK 1 K 0.53 CLR or PRE 0.58 Unit Load is ∆ICC limit specified in electrical characteristics table (e.g., 2.4 mA at 25°C). timing requirements over recommended operating conditions (unless otherwise noted) –55°C to 125°C MIN fclock Clock frequency tw Pulse duration tsu th Setup time, before CLK↓ J or K Hold time, after CLK↓ J or K trec Recovery time, before CLK↓ CLR↑ or PRE↑ MAX –40°C to 85°C MIN 100 POST OFFICE BOX 655303 UNIT MAX 114 MHz CLK high or low 5 4.4 CLR or PRE low 5.5 4.8 4 3.5 ns 1 1 ns 2.5 2.2 ns • DALLAS, TEXAS 75265 ns 3 CD54ACT112, CD74ACT112 DUAL J-K NEGATIVE-EDGE-TRIGGERED FLIP-FLOPS WITH CLEAR AND PRESET SCHS323 – JANUARY 2003 switching characteristics over recommended operating free-air temperature range, VCC = 5 V ± 0.5 V, CL = 50 pF (unless otherwise noted) (see Figure 1) PARAMETER FROM (INPUT) TO (OUTPUT) fmax tPLH tPHL –55°C to 125°C MIN MAX 100 CLK Q or Q CLR or PRE CLK Q or Q CLR or PRE –40°C to 85°C MIN UNIT MAX 114 MHz 2.6 10.3 2.7 9.4 3.1 12.2 3.2 11.1 2.6 10.3 2.7 9.4 3.1 12.2 3.2 11.1 ns ns operating characteristics, VCC = 5 V, TA = 25°C PARAMETER Cpd 4 Power dissipation capacitance POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 TYP UNIT 56 pF CD54ACT112, CD74ACT112 DUAL J-K NEGATIVE-EDGE-TRIGGERED FLIP-FLOPS WITH CLEAR AND PRESET SCHS323 – JANUARY 2003 PARAMETER MEASUREMENT INFORMATION S1 R1 = 500 Ω From Output Under Test 2 × VCC Open GND CL = 50 pF (see Note A) R2 = 500 Ω TEST S1 tPLH/tPHL tPLZ/tPZL tPHZ/tPZH Open 2 × VCC GND tw 3V 1.5 V Input LOAD CIRCUIT 1.5 V 0V VOLTAGE WAVEFORMS PULSE DURATION CLR Input 3V Reference Input 3V 1.5 V 1.5 V 0V 0V trec Data Input 3V 1.5 V CLK th tsu 1.5 V 10% 90% 90% tr 0V VOLTAGE WAVEFORMS RECOVERY TIME 3V 1.5 V 10% 0 V tf VOLTAGE WAVEFORMS SETUP AND HOLD AND INPUT RISE AND FALL TIMES 3V Input 1.5 V 1.5 V 0V tPLH In-Phase Output 50% 10% 90% 90% tr 90% 1.5 V 1.5 V 0V tPHL tPHL Out-of-Phase Output 3V Output Control VOH 50% VCC 10% VOL tf tPLH 50% VCC 10% tf 50% 10% 90% VOH VOL tr VOLTAGE WAVEFORMS PROPAGATION DELAY AND OUTPUT TRANSITION TIMES Output Waveform 1 S1 at 2 × VCC (see Note B) tPLZ tPZL 20% VCC tPHZ tPZH Output Waveform 2 S1 at GND (see Note B) ≈VCC 20% VCC VOL 80% VCC VOH 80% VCC ≈0 V VOLTAGE WAVEFORMS OUTPUT ENABLE AND DISABLE TIMES NOTES: A. CL includes probe and test-fixture capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr = 3 ns, tf = 3 ns. Phase relationships between waveforms are arbitrary. D. For clock inputs, fmax is measured with the input duty cycle at 50%. E. The outputs are measured one at a time with one input transition per measurement. F. tPLH and tPHL are the same as tpd. G. tPZL and tPZH are the same as ten. H. tPLZ and tPHZ are the same as tdis. I. All parameters and waveforms are not applicable to all devices. Figure 1. Load Circuit and Voltage Waveforms POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 5 PACKAGE OPTION ADDENDUM www.ti.com 18-Nov-2023 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) Samples (4/5) (6) CD54ACT112F3A ACTIVE CDIP J 16 25 Non-RoHS & Green SNPB N / A for Pkg Type -55 to 125 CD54ACT112F3A CD74ACT112M LIFEBUY SOIC D 16 40 RoHS & Green NIPDAU Level-1-260C-UNLIM -55 to 125 ACT112M CD74ACT112M96 ACTIVE SOIC D 16 2500 RoHS & Green NIPDAU Level-1-260C-UNLIM -55 to 125 ACT112M CD74ACT112MG4 LIFEBUY SOIC D 16 40 RoHS & Green NIPDAU Level-1-260C-UNLIM -55 to 125 ACT112M (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74ACT112ME4 价格&库存
很抱歉,暂时无法提供与“CD74ACT112ME4”相匹配的价格&库存,您可以联系我们找货
