SDAS112B − APRIL 1982 − REVISED DECEMBER 1994
SN54ALS27A, SN54AS27 . . . J PACKAGE
SN74ALS27A, SN74AS27 . . . D OR N PACKAGE
(TOP VIEW)
Package Options Include Plastic
Small-Outline (D) Packages, Ceramic Chip
Carriers (FK), and Standard Plastic (N) and
Ceramic (J) 300-mil DIPs
1A
1B
2A
2B
2C
2Y
GND
description
These devices contain three independent 3-input
positive-NOR gates. They perform the Boolean
functions Y = A • B • C or Y = A + B + C in positive
logic.
INPUTS
C
OUTPUT
Y
H
X
X
L
X
H
X
L
X
X
H
L
L
L
L
H
13
3
12
4
11
5
10
6
9
7
8
2A
NC
2B
NC
2C
4
3 2 1 20 19
18
5
17
6
16
7
15
8
14
9 10 11 12 13
1Y
NC
3C
NC
3B
2Y
GND
NC
3Y
3A
B
2
VCC
1C
1Y
3C
3B
3A
3Y
SN54ALS27A, SN54AS27 . . . FK PACKAGE
(TOP VIEW)
FUNCTION TABLE
(each gate)
A
14
1B
1A
NC
VCC
The SN54ALS27A and SN54AS27 are
characterized for operation over the full military
temperature range of − 55°C to 125°C. The
SN74ALS27A and SN74AS27 are characterized
for operation from 0°C to 70°C.
1
1C
NC − No internal connection
logic symbol†
1A
1B
1C
2A
2B
2C
3A
3B
3C
1
2
logic diagram (positive logic)
≥1
1A
12
13
1Y
1B
1C
3
4
6
5
2A
2Y
2B
2C
9
10
8
11
3A
3Y
3B
3C
1
2
12
1Y
13
3
4
6
2Y
5
9
10
8
3Y
11
† This symbol is in accordance with ANSI/IEEE Std 91-1984
and IEC Publication 617-12.
Pin numbers shown are for the D, J, and N packages.
Copyright 1994, Texas Instruments Incorporated
• DALLAS, TEXAS 75265
• HOUSTON, TEXAS 77251−1443
POST OFFICE BOX 655303
POST OFFICE BOX 1443
1
absolute maximum ratings over operating free-air temperature range (unless otherwise noted)†
Supply voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 V
Input voltage, VI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 V
Operating free-air temperature range, TA: SN54ALS27A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −55°C to 125°C
SN74ALS27A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C
Storage temperature range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −65°C to 150°C
† Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and
functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not
implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
SN54ALS27A
VCC
VIH
Supply voltage
High-level input voltage
SN74ALS27A
MIN
NOM
MAX
MIN
NOM
MAX
4.5
5
5.5
4.5
5
5.5
2
2
UNIT
V
V
VIL
Low-level input voltage
0.8‡
0.7§
IOH
IOL
High-level output current
−0.4
−0.4
mA
Low-level output current
4
8
mA
70
°C
TA
‡ Applies over temperature range − 55°C to 70°C
§ Applies over temperature range 70°C to 125°C
−55
125
0.8
V
electrical characteristics over recommended operating free-air temperature range (unless
otherwise noted)
PARAMETER
SN54ALS27A
MIN TYP¶
MAX
TEST CONDITIONS
VIK
VOH
VCC = 4.5 V,
VCC = 4.5 V to 5.5 V,
II = −18 mA
IOH = − 0.4 mA
VOL
VCC = 4.5 V
IOL = 4 mA
IOL = 8 mA
II
IIH
VCC = 5.5 V,
VCC = 5.5 V,
VI = 7 V
VI = 2.7 V
IIL
IO#
VCC = 5.5 V,
VCC = 5.5 V,
VI = 0.4 V
VO = 2.25 V
ICCH
ICCL
VCC = 5.5 V,
VCC = 5.5 V,
VI = 0
VI = 4.5 V
SN74ALS27A
MIN TYP¶
MAX
−1.5
VCC − 2
−1.5
VCC − 2
0.25
0.4
V
V
0.25
0.4
0.35
0.5
0.1
−20
UNIT
0.1
V
mA
µA
−0.1
−0.1
mA
−112
mA
0.97
−112
1.8
−30
0.97
1.8
mA
2
4
2
4
mA
¶ All typical values are at VCC = 5 V, TA = 25°C.
# The output conditions have been chosen to produce a current that closely approximates one half of the true short-circuit output current, IOS.
2
POST OFFICE BOX 655303 DALLAS, TEXAS 75265
POST OFFICE BOX 1443 HOUSTON, TEXAS 77251−1443
switching characteristics (see Figure 1)
FROM
(INPUT)
PARAMETER
CL = 50 pF,
RL = 500 Ω,
TA = MIN to MAX†
TO
(OUTPUT)
SN54ALS27A
tPLH
tPHL
A, B, or C
Y
UNIT
SN74ALS27A
MIN
MAX
MIN
MAX
4
26
3
15
1
11
1
9
ns
† For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions.
absolute maximum ratings over operating free-air temperature range (unless otherwise noted)‡
Operating free-air temperature range, TA: SN54AS27 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −55°C to 125°C
SN74AS27 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C
‡ Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and
SN54AS27
SN74AS27
MIN
NOM
MAX
MIN
NOM
MAX
4.5
5
5.5
4.5
5
5.5
UNIT
VCC
VIH
Supply voltage
VIL
IOH
0.8
0.8
V
−2
−2
mA
IOL
TA
mA
70
°C
2
2
−55
125
V
V
otherwise noted)
PARAMETER
SN54AS27
MIN TYP§
MAX
TEST CONDITIONS
VIK
VOH
VCC = 4.5 V,
II = −18 mA
IOH = − 2 mA
VOL
II
VCC = 4.5 V,
VCC = 5.5 V,
IOL = 20 mA
VI = 7 V
IIH
IIL
IO¶
VCC = 5.5 V,
VCC = 5.5 V,
VI = 2.7 V
VI = 0.4 V
VCC = 5.5 V,
VCC = 5.5 V,
VO = 2.25 V
VI = 0
ICCH
ICCL
SN74AS27
MIN TYP§
MAX
−1.2
VCC − 2
−1.2
VCC − 2
0.35
0.5
0.35
0.5
V
0.1
mA
µA
−0.5
−0.5
mA
−112
mA
6.4
mA
−112
4
V
V
0.1
−30
UNIT
6.4
−30
4
VCC = 5.5 V,
VI = 4.5 V
10.6
17.1
10.6
17.1
mA
§ All typical values are at VCC = 5 V, TA = 25°C.
¶ The output conditions have been chosen to produce a current that closely approximates one half of the true short-circuit output current, IOS.
3
PARAMETER
tPLH
tPHL
FROM
(INPUT)
TO
(OUTPUT)
A, B, or C
Y
CL = 50 pF,
RL = 500 Ω,
TA = MIN to MAX†
SN54AS27
SN74AS27
MIN
MAX
MIN
MAX
1
6.5
1
5.5
1
5
1
4.5
4
UNIT
ns
PARAMETER MEASUREMENT INFORMATION
SERIES 54ALS/74ALS AND 54AS/74AS DEVICES
7V
RL = R1 = R2
VCC
S1
RL
R1
Test
Point
From Output
Under Test
CL
(see Note A)
From Output
Under Test
RL
Test
Point
CL
(see Note A)
CL
(see Note A)
LOAD CIRCUIT FOR
BI-STATE
TOTEM-POLE OUTPUTS
3.5 V
High-Level
Pulse
1.3 V
R2
LOAD CIRCUIT
FOR 3-STATE OUTPUTS
LOAD CIRCUIT
FOR OPEN-COLLECTOR OUTPUTS
3.5 V
Timing
Input
Test
Point
From Output
Under Test
1.3 V
1.3 V
0.3 V
0.3 V
tsu
Data
Input
tw
th
3.5 V
1.3 V
3.5 V
Low-Level
Pulse
1.3 V
0.3 V
1.3 V
0.3 V
VOLTAGE WAVEFORMS
SETUP AND HOLD TIMES
VOLTAGE WAVEFORMS
PULSE DURATIONS
3.5 V
Output
Control
(low-level
enabling)
1.3 V
1.3 V
0.3 V
tPZL
Waveform 1
S1 Closed
(see Note B)
tPLZ
3.5 V
Input
tPZH
1.3 V
0.3 V
tPHL
tPLH
VOH
In-Phase
Output
VOL
0.3 V
1.3 V
1.3 V
VOL
tPLH
tPHL
VOH
1.3 V
1.3 V
[3.5 V
1.3 V
tPHZ
Waveform 2
S1 Open
(see Note B)
1.3 V
VOH
Out-of-Phase
Output
(see Note C)
0.3 V
[0 V
1.3 V
1.3 V
VOL
VOLTAGE WAVEFORMS
PROPAGATION DELAY TIMES
VOLTAGE WAVEFORMS
ENABLE AND DISABLE TIMES, 3-STATE OUTPUTS
NOTES: A. CL includes probe and jig capacitance.
B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control.
Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control.
C. When measuring propagation delay items of 3-state outputs, switch S1 is open.
D. All input pulses have the following characteristics: PRR ≤ 1 MHz, tr = tf = 2 ns, duty cycle = 50%.
E. The outputs are measured one at a time with one transition per measurement.
Figure 1. Load Circuits and Voltage Waveforms
5
PACKAGE OPTION ADDENDUM
www.ti.com
2-Dec-2023
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
Device Marking
(3)
Samples
(4/5)
(6)
5962-86838012A
ACTIVE
LCCC
FK
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
596286838012A
SNJ54ALS
27AFK
5962-8683801DA
ACTIVE
CFP
W
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
5962-8683801DA
SNJ54ALS27AW
Samples
JM38510/37302BCA
ACTIVE
CDIP
J
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
JM38510/
37302BCA
Samples
M38510/37302BCA
ACTIVE
CDIP
J
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
JM38510/
37302BCA
Samples
SN54ALS27AJ
ACTIVE
CDIP
J
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
SN54ALS27AJ
Samples
Samples
SN74ALS27AD
LIFEBUY
SOIC
D
14
50
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
0 to 70
ALS27A
SN74ALS27ADR
ACTIVE
SOIC
D
14
2500
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
0 to 70
ALS27A
Samples
SN74ALS27AN
ACTIVE
PDIP
N
14
25
RoHS & Green
NIPDAU
N / A for Pkg Type
0 to 70
SN74ALS27AN
Samples
SN74ALS27ANSR
ACTIVE
SO
NS
14
2000
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
0 to 70
ALS27A
Samples
SN74AS27D
LIFEBUY
SOIC
D
14
50
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
0 to 70
AS27
SN74AS27N
ACTIVE
PDIP
N
14
25
RoHS & Green
NIPDAU
N / A for Pkg Type
0 to 70
SN74AS27N
SNJ54ALS27AFK
ACTIVE
LCCC
FK
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
596286838012A
SNJ54ALS
27AFK
SNJ54ALS27AJ
ACTIVE
CDIP
J
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
SNJ54ALS27AJ
Samples
SNJ54ALS27AW
ACTIVE
CFP
W
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
5962-8683801DA
SNJ54ALS27AW
Samples
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
Addendum-Page 1
Samples
Samples
www.ti.com
2-Dec-2023
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
