LMC6482AIMX/S7002212 数据手册
LMC6062
www.ti.com
SNOS631D – NOVEMBER 1994 – REVISED MARCH 2013
LMC6062 Precision CMOS Dual Micropower Operational Amplifier
Check for Samples: LMC6062
FEATURES
DESCRIPTION
The LMC6062 is a precision dual low offset voltage,
micropower operational amplifier, capable of
precision single supply operation. Performance
characteristics include ultra low input bias current,
high voltage gain, rail-to-rail output swing, and an
input common mode voltage range that includes
ground. These features, plus its low power
consumption, make the LMC6062 ideally suited for
battery powered applications.
1
2
(Typical Unless Otherwise Noted)
Low Offset Voltage 100μV
Ultra Low Supply current 16μA/Amplifier
Operates from 4.5V to 15V Single Supply
Ultra Low Input Bias Current 10fA
Output Swing within 10mV of Supply Rail, 100k
Load
Input Common-Mode Range Includes V−
High Voltage Gain 140dB
Improved Latchup Immunity
APPLICATIONS
Instrumentation Amplifier
Photodiode and Infrared Detector Preamplifier
Transducer Amplifiers
Hand-Held Analytic Instruments
Medical Instrumentation
D/A Converter
Charge Amplifier for Piezoelectric Transducers
Other applications using the LMC6062 include
precision full-wave rectifiers, integrators, references,
sample-and-hold circuits, and true instrumentation
amplifiers.
This device is built with TI's advanced double-Poly
Silicon-Gate CMOS process.
For designs that require higher speed, see the
LMC6082 precision dual operational amplifier.
PATENT PENDING
Connection Diagram
Figure 1. 8-Pin PDIP/SOIC
Top View
1
2
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of
Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
All trademarks are the property of their respective owners.
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the Texas
Instruments standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 1994–2013, Texas Instruments Incorporated
LMC6062
www.ti.com
This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with
appropriate precautions. Failure to observe proper handling and installation procedures can cause damage.
ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more
susceptible to damage because very small parametric changes could cause the device not to meet its published specifications.
Absolute Maximum Ratings
(1) (2)
Differential Input Voltage
±Supply Voltage
(V+) +0.3V,
Voltage at Input/Output Pin
(V−) −0.3V
Supply Voltage (V − V )
16V
Output Short Circuit to V+
See
(3)
Output Short Circuit to V−
See
(4)
Lead Temperature (Soldering, 10 sec.)
260°C
Storage Temp. Range
−65°C to +150°C
Junction Temperature
150°C
ESD Tolerance
(5)
2 kV
Current at Input Pin
±10 mA
Current at Output Pin
±30 mA
Current at Power Supply Pin
40 mA
Power Dissipation
See
(1)
(2)
(3)
(4)
(5)
(6)
Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for
which the device is intended to be functional, but do not ensure specific performance limits. For ensured specifications and test
conditions, see the Electrical Characteristics. The ensured specifications apply only for the test conditions listed.
If Military/Aerospace specified devices are required, please contact the TI Sales Office/Distributors for availability and specifications
Do not connect output to V+, when V+ is greater than 13V or reliability witll be adversely affected.
Applies to both single-supply and split-supply operation. Continuos short circuit operation at elevated ambient temperature can result in
exceeding the maximum allowed junction temperature of 150°C. Output currents in excess of ±30 mA over long term may adversely
affect reliability.
Human body model, 1.5 kΩ in series with 100 pF.
The maximum power dissipation is a function of TJ(Max), θJA, and TA. The maximum allowable power dissipation at any ambient
temperature is PD = (TJ(Max) − TA)/θJA.
Operating Ratings
(1)
Temperature Range
−55°C ≤ TJ ≤ +125°C
LMC6062AM
−40°C ≤ TJ ≤ +85°C
LMC6062AI, LMC6082I
4.5V ≤ V+ ≤ 15.5V
Supply Voltage
Thermal Resistance (θJA)
(2)
8-Pin PDIP
115°C/W
8-Pin SOIC
193°C/W
Power Dissipation
(1)
(2)
(3)
(6)
See
(3)
All numbers apply for packages soldered directly into a PC board.
For operating at elevated temperatures the device must be derated based on the thermal resistance θJA with PD = (TJ–TA)/θJA.
DC Electrical Characteristics (1)
Unless otherwise specified, all limits ensured for TJ = 25°C. Boldface limits apply at the temperature extremes. V+ = 5V, V− =
0V, VCM = 1.5V, VO = 2.5V and RL > 1M unless otherwise specified.
Symbol
VOS
(1)
(2)
(3)
2
Parameter
Input Offset Voltage
Conditions
Typ (2)
100
LMC6062AM
LMC6062AI
LMC6062I
Limit (3)
Limit (3)
350
350
800
μV
1200
900
1300
Max
Limit (3)
Units
For ensured Military Temperature Range parameters, see RETSMC6062X.
Typical values represent the most likely parametric norm.
All limits are ensured by testing or statistical analysis.
Submit Documentation Feedback
Product Folder Links: LMC6062
LMC6062
www.ti.com
DC Electrical Characteristics(1) (continued)
Symbol
TCVOS
Parameter
Conditions
Typ (2)
LMC6062AM
Limit (3)
LMC6062AI
LMC6062I
Limit (3)
Limit (3)
Units
μV/°C
1.0
Average Drift
IB
Input Bias Current
IOS
0.010
Input Offset Current
Input Resistance
CMRR
Common Mode
0V ≤ VCM ≤ 12.0V
Rejection Ratio
V+ = 15V
Positive Power Supply
5V ≤ V+ ≤ 15V
Rejection Ratio
VO = 2.5V
Negative Power Supply
0V ≤ V− ≤ −10V
−PSRR
AV
85
Voltage Range
for CMRR ≥ 60 dB
RL = 100 kΩ (4)
RL = 25 kΩ
2
Max
pA
Tera Ω
66
dB
72
63
Min
75
75
66
dB
70
72
63
Min
84
84
74
dB
70
81
71
Min
−0.4
−0.1
−0.1
−0.1
V
Max
V+ − 1.9
V+ − 2.3
V+ − 2.3
V+ − 2.3
V
V+ − 2.6
V+ − 2.5
V+ − 2.5
Min
Sourcing
400
400
300
V/mV
200
300
200
Min
90
V/mV
4000
(4)
Sinking
3000
180
180
70
100
60
Min
Sourcing
3000
400
400
200
V/mV
150
150
80
Min
Sinking
2000
100
100
70
V/mV
35
50
35
Min
4.995
4.990
4.990
4.950
V
4.970
4.980
4.925
Min
0.010
0.010
0.050
V
0.030
0.020
0.075
Max
4.975
4.975
4.950
V
4.955
4.965
4.850
Min
0.020
0.020
0.050
V
0.045
0.035
0.150
Max
14.975
14.975
14.950
V
14.955
14.965
14.925
Min
0.025
0.025
0.050
V
0.050
0.035
0.075
Max
14.900
14.900
14.850
V
14.800
14.850
14.800
Min
0.050
0.050
0.100
V
0.200
0.150
0.200
Max
V+ = 5V
RL = 100 kΩ to 2.5V
0.005
V+ = 5V
4.990
RL = 25 kΩ to 2.5V
0.010
V+ = 15V
14.990
RL = 100 kΩ to 7.5V
0.010
V+ = 15V
14.965
RL = 25 kΩ to 7.5V
0.025
(4)
2
75
100
V+ = 5V and 15V
Output Swing
100
70
Voltage Gain
VO
Max
75
85
Input Common-Mode
Large Signal
4
>10
Rejection Ratio
VCM
4
0.005
RIN
+PSRR
pA
100
V+ = 15V, VCM = 7.5V and RL connected to 7.5V. For Sourcing tests, 7.5V ≤ VO ≤ 11.5V. For Sinking tests, 2.5V ≤ VO ≤ 7.5V.
3
LMC6062
www.ti.com
Symbol
IO
Parameter
Output Current
Conditions
Sourcing, VO = 0V
LMC6062AI
LMC6062I
Limit (3)
Limit (3)
Limit (3)
16
16
13
mA
8
10
8
Min
16
16
16
mA
7
8
8
Min
15
15
15
mA
9
10
10
Min
35
mA
7
8
8
Min
32
38
38
46
μA
60
46
56
Max
47
47
57
μA
70
55
66
Max
Typ (2)
22
V+ = 5V
Sinking, VO = 5V
IO
Output Current
21
Sourcing, VO = 0V
25
V+ = 15V
Sinking, VO = 13V
IS
Supply Current
(5)
Both Amplifiers
V+ = +5V, VO = 1.5V
Both Amplifiers
40
V+ = +15V, VO = 7.5V
(5)
LMC6062AM
Units
Do not connect output to V+, when V+ is greater than 13V or reliability will be adversely affected.
AC Electrical Characteristics (1)
Unless otherwise specified, all limits ensured for TJ = 25°C, Boldface limits apply at the temperature extremes. V+ = 5V, V− =
Symbol
SR
Parameter
Slew Rate
Conditions
See
(4)
Typ (2)
35
LMC6062AM LMC6062AI LMC6062I
Limit (3)
Units
Limit (3)
Limit (3)
V/ms
8
10
7
Min
GBW
Gain-Bandwidth Product
100
kHz
θm
Phase Margin
50
Deg
155
dB
(5)
Amp-to-Amp Isolation
See
en
Input-Referred Voltage Noise
F = 1 kHz
83
nV/√Hz
in
Input-Referred Current Noise
F = 1 kHz
0.0002
pA/√Hz
T.H.D.
Total Harmonic Distortion
F = 1 kHz, AV = −5
0.01
RL = 100 kΩ, VO = 2 VPP
±5V Supply
(1)
(2)
(3)
(4)
(5)
4
V+ = 15V. Connected as Voltage Follower with 10V step input. Number specified is the slower of the positive and negative slew rates.
Input referred V+ = 15V and RL = 100 kΩ connected to 7.5V. Each amp excited in turn with 100 Hz to produce VO = 12 VPP.
LMC6062
www.ti.com
Typical Performance Characteristics
VS = ±7.5V, TA = 25°C, Unless otherwise specified
Distribution of LMC6062 Input Offset Voltage
(TA = +25°C)
(TA = −55°C)
Figure 2.
Figure 3.
(TA = +125°C)
Input Bias Current
vs.
Temperature
Figure 4.
Figure 5.
Supply Current
vs.
Supply Voltage
Input Voltage
vs.
Output Voltage
Figure 6.
Figure 7.
5
LMC6062
www.ti.com
Typical Performance Characteristics (continued)
6
Common Mode Rejection Ratio
vs.
Frequency
Power Supply Rejection Ratio
vs.
Frequency
Figure 8.
Figure 9.
Input Voltage Noise
vs.
Frequency
Output Characteristics Sourcing Current
Figure 10.
Figure 11.
Output Characteristics Sinking Current
Gain and Phase Response
vs.
Temperature
(−55°C to +125°C)
Figure 12.
Figure 13.
LMC6062
www.ti.com
vs.
Capacitive Load
with RL = 20 kΩ
vs.
Capacitive Load
with RL = 500 kΩ
Figure 14.
Figure 15.
Open Loop Frequency Response
Inverting Small Signal Pulse Response
Figure 16.
Figure 17.
Inverting Large Signal Pulse Response
Non-Inverting Small Signal Pulse Response
Figure 18.
Figure 19.
7
LMC6062
www.ti.com
8
Non-Inverting Large Signal Pulse Response
Crosstalk Rejection
vs.
Frequency
Figure 20.
Figure 21.
Stability
vs
Capacitive Load, RL = 20 kΩ
Stability
vs.
Capacitive Load RL = 1 MΩ
Figure 22.
Figure 23.
LMC6062
www.ti.com
APPLICATIONS HINTS
AMPLIFIER TOPOLOGY
The LMC6062 incorporates a novel op-amp design topology that enables it to maintain rail-to-rail output swing
even when driving a large load. Instead of relying on a push-pull unity gain output buffer stage, the output stage
is taken directly from the internal integrator, which provides both low output impedance and large gain. Special
feed forward compensation design techniques are incorporated to maintain stability over a wider range of
operating conditions than traditional micropower op amps. These features make the LMC6062 both easier to
design with, and provide higher speed than products typically found in this ultra low power class.
COMPENSATING FOR INPUT CAPACITANCE
It is quite common to use large values of feedback resistance for amplifiers with ultra-low input current, like the
LMC6062.
Although the LMC6062 is highly stable over a wide range of operating conditions, certain precautions must be
met to achieve the desired pulse response when a large feedback resistor is used. Large feedback resistors and
even small values of input capacitance, due to transducers, photodiodes, and circuit board parasitics, reduce
phase margins.
When high input impedances are demanded, guarding of the LMC6062 is suggested. Guarding input lines will
not only reduce leakage, but lowers stray input capacitance as well. (See PRINTED-CIRCUIT-BOARD LAYOUT
FOR HIGH-IMPEDANCE WORK).
The effect of input capacitance can be compensated for by adding a capacitor. Place a capacitor, Cf, around the
feedback resistor (as in Figure 24 ) such that:
(1)
or
R1 CIN ≤ R2 Cf
(2)
Since it is often difficult to know the exact value of CIN, Cf can be experimentally adjusted so that the desired
pulse response is achieved. Refer to the LMC660 and the LMC662 for a more detailed discussion on
compensating for input capacitance.
Figure 24. Canceling the Effect of Input Capacitance
CAPACITIVE LOAD TOLERANCE
All rail-to-rail output swing operational amplifiers have voltage gain in the output stage. A compensation capacitor
is normally included in this integrator stage. The frequency location of the dominate pole is affected by the
resistive load on the amplifier. Capacitive load driving capability can be optimized by using an appropriate
resistive load in parallel with the capacitive load (see typical curves).
Direct capacitive loading will reduce the phase margin of many op-amps. A pole in the feedback loop is created
by the combination of the op-amp's output impedance and the capacitive load. This pole induces phase lag at the
unity-gain crossover frequency of the amplifier resulting in either an oscillatory or underdamped pulse response.
With a few external components, op amps can easily indirectly drive capacitive loads, as shown in Figure 25.
9
LMC6062
www.ti.com
Figure 25. LMC6062 Noninverting Gain of 10 Amplifier, Compensated to Handle Capacitive Loads
In the circuit of Figure 25, R1 and C1 serve to counteract the loss of phase margin by feeding the high frequency
component of the output signal back to the amplifier's inverting input, thereby preserving phase margin in the
overall feedback loop.
Capacitive load driving capability is enhanced by using a pull up resistor to V+ (Figure 26). Typically a pull up
resistor conducting 10 μA or more will significantly improve capacitive load responses. The value of the pull up
resistor must be determined based on the current sinking capability of the amplifier with respect to the desired
output swing. Open loop gain of the amplifier can also be affected by the pull up resistor (see Electrical
Characteristics).
Figure 26. Compensating for Large Capacitive Loads
with a Pull Up Resistor
PRINTED-CIRCUIT-BOARD LAYOUT FOR HIGH-IMPEDANCE WORK
It is generally recognized that any circuit which must operate with less than 1000 pA of leakage current requires
special layout of the PC board. When one wishes to take advantage of the ultra-low bias current of the
LMC6062, typically less than 10 fA, it is essential to have an excellent layout. Fortunately, the techniques of
obtaining low leakages are quite simple. First, the user must not ignore the surface leakage of the PC board,
even though it may sometimes appear acceptably low, because under conditions of high humidity or dust or
contamination, the surface leakage will be appreciable.
To minimize the effect of any surface leakage, lay out a ring of foil completely surrounding the LMC6062's inputs
and the terminals of capacitors, diodes, conductors, resistors, relay terminals etc. connected to the op-amp's
inputs, as in Figure 27. To have a significant effect, guard rings should be placed on both the top and bottom of
the PC board. This PC foil must then be connected to a voltage which is at the same voltage as the amplifier
inputs, since no leakage current can flow between two points at the same potential. For example, a PC board
trace-to-pad resistance of 1012Ω, which is normally considered a very large resistance, could leak 5 pA if the
trace were a 5V bus adjacent to the pad of the input. This would cause a 100 times degradation from the
LMC6062's actual performance. However, if a guard ring is held within 5 mV of the inputs, then even a
resistance of 1011Ω would cause only 0.05 pA of leakage current. See Figure 28 for typical connections of guard
rings for standard op-amp configurations.
10
LMC6062
www.ti.com
Figure 27. Example of Guard Ring in P.C. Board Layout
(a) Inverting Amplifier
(b) Non-Inverting Amplifier
(c) Follower
Figure 28. Typical Connections of Guard Rings
The designer should be aware that when it is inappropriate to lay out a PC board for the sake of just a few
circuits, there is another technique which is even better than a guard ring on a PC board: Don't insert the
amplifier's input pin into the board at all, but bend it up in the air and use only air as an insulator. Air is an
excellent insulator. In this case you may have to forego some of the advantages of PC board construction, but
the advantages are sometimes well worth the effort of using point-to-point up-in-the-air wiring. See Figure 29.
Latchup
CMOS devices tend to be susceptible to latchup due to their internal parasitic SCR effects. The (I/O) input and
output pins look similar to the gate of the SCR. There is a minimum current required to trigger the SCR gate
lead. The LMC6062 and LMC6082 are designed to withstand 100 mA surge current on the I/O pins. Some
resistive method should be used to isolate any capacitance from supplying excess current to the I/O pins. In
addition, like an SCR, there is a minimum holding current for any latchup mode. Limiting current to the supply
pins will also inhibit latchup susceptibility.
11
LMC6062
www.ti.com
(Input pins are lifted out of PC board and soldered directly to components. All other pins connected to PC board).
Figure 29. Air Wiring
Typical Single-Supply Applications
(V+ = 5.0 VDC)
The extremely high input impedance, and low power consumption, of the LMC6062 make it ideal for applications
that require battery-powered instrumentation amplifiers. Examples of these types of applications are hand-held
pH probes, analytic medical instruments, magnetic field detectors, gas detectors, and silicon based pressure
transducers.
Figure 30 shows an instrumentation amplifier that features high differential and common mode input resistance
(>1014Ω), 0.01% gain accuracy at AV = 100, excellent CMRR with 1 kΩ imbalance in bridge source resistance.
Input current is less than 100 fA and offset drift is less than 2.5 μV/°C. R2 provides a simple means of adjusting
gain over a wide range without degrading CMRR. R7 is an initial trim used to maximize CMRR without using
super precision matched resistors. For good CMRR over temperature, low drift resistors should be used.
If R1 = R5, R3 = R6, and R4 = R7; then
∴AV ≈ 100 for circuit shown (R2 = 9.822k).
Figure 30. Instrumentation Amplifier
12
LMC6062
www.ti.com
Figure 31. Low-Leakage Sample and Hold
Figure 32. 1 Hz Square Wave Oscillator
13
LMC6062
www.ti.com
REVISION HISTORY
Changes from Revision C (March 2013) to Revision D
14
Page
Changed layout of National Data Sheet to TI format .......................................................................................................... 13
PACKAGE OPTION ADDENDUM
www.ti.com
7-Dec-2023
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
Device Marking
(3)
Samples
(4/5)
(6)
LMC6062AIM/NOPB
LIFEBUY
SOIC
D
8
95
RoHS & Green
SN
Level-1-260C-UNLIM
-40 to 85
LMC60
62AIM
LMC6062AIMX/NOPB
ACTIVE
SOIC
D
8
2500
RoHS & Green
SN
Level-1-260C-UNLIM
-40 to 85
LMC60
62AIM
LMC6062I MDC
LIFEBUY
DIESALE
Y
RoHS & Green
Call TI
Level-1-NA-UNLIM
-40 to 85
LMC6062IM/NOPB
LIFEBUY
SOIC
D
8
95
RoHS & Green
SN
Level-1-260C-UNLIM
-40 to 85
LMC60
62IM
LMC6062IMX/NOPB
ACTIVE
SOIC
D
8
2500
RoHS & Green
SN
Level-1-260C-UNLIM
-40 to 85
LMC60
62IM
Samples
LMC6062IN/NOPB
ACTIVE
PDIP
P
8
40
RoHS & Green
NIPDAU
Level-1-NA-UNLIM
-40 to 85
LMC6062
IN
Samples
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
