Data sheet acquired from Harris Semiconductor
SCHS098D − Revised October 2003
The CD40107B is a dual 2-input NAND
buffer/driver containing two independent
2-input NAND buffers with open-drain single
n-channel transistor outputs. This device
features a wired-OR capability and high output
sink current capability (136 mA typ. at
VDD = 10 V, VDS = 1 V). The CD40107B is
supplied in 8-lead hermetic dual-in-line ceramic
packages (F3A suffix), 8-lead dual-in-line
plastic packages (E suffix), 8-lead small-outline
packages (M, M96, MT, and PSR suffixes), and
8-lead thin shrink small-outline packages (PW
and PWR suffixes).
Copyright © 2003, Texas Instruments Incorporated
PACKAGE OPTION ADDENDUM
www.ti.com
2-Dec-2023
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
Device Marking
(3)
Samples
(4/5)
(6)
CD40107BE
ACTIVE
PDIP
P
8
50
RoHS & Green
NIPDAU
N / A for Pkg Type
-55 to 125
CD40107BE
Samples
CD40107BF
ACTIVE
CDIP
J
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
CD40107BF
Samples
CD40107BF3A
ACTIVE
CDIP
J
14
25
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
CD40107BF3A
Samples
CD40107BM
ACTIVE
SOIC
D
8
75
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
CM0107
Samples
CD40107BM96
ACTIVE
SOIC
D
8
2500
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
CM0107
Samples
CD40107BPSR
ACTIVE
SO
PS
8
2000
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
CM0107B
Samples
CD40107BPW
LIFEBUY
TSSOP
PW
8
150
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
CM0107B
CD40107BPWR
ACTIVE
TSSOP
PW
8
2000
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-55 to 125
CM0107B
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
很抱歉,暂时无法提供与“CD40107BMT”相匹配的价格&库存,您可以联系我们找货
